Who said Yaris was slow?
Your logic is right... the higher the number the leanest,
However your point of reference is wrong... 14,7:1 would be the perfect number at idle or when crusing, not under boost. Under boos you need to run much richer than that to be on the safe side... Ideally these guys should be around 12:1 under boost... that is why they say a 13.5 or a 14 is dangerously lean... |
#2 | |
When we have forced induction usually the largest the exhaust the better (within a range of course) You need to remeber that no car is the same as no Dyno is the same... Weather condition and other factors could have affected your final output. Anyways.... isn't 20whp withing the range of the tipical gains offered by the blitz unit? I mean... in you car that is a 23% increase in HP... The tq still looks a little weak... but still within range... I can see these kits putting 10-15whp more with a tune... if there would only be an easy way to tune it...
The blitz fuel controller does that and only that -- it does not adjust timing.
#4 | |
Has anyone tried to disconnect the black box and see what happens? Ideally would hve to be some one with a wideband installed. That would answer the question if the black box is actually doing anything at all... |
#5 | |||
Yah true. When I did the dyno run, it had to have been atleast 85 degrees (HOT!). I don't think my 2.25" headerback exhaust would have me lose HP, definately torque, but NOT as bad as it is showing. Quote:
We aren't capable of doing that unless we have a standalone ecu, correct? Last edited by PETERPOOP; 03-24-2009 at 12:26 AM. |
I used to have 1700 posts
bigger problem
i undid my pvc valve to make hooking up my boost gauge easier and there is a ridiculous amount of oil coming out of my engine and into the manifold. something has to be very wrong
#7 | |
aka SDMF
lol. well make a new thread. :P
i figured everyone was already looking in this thread
true. good luck
Bathroom + Laptop = <3
Why is everyone having problems with this kit now :( :( :(
Because nothing can be easy! Especially FI! doh
its aftermarket shit, its never easy. but thats y we do it
i know its normal to have a little bit of oil coming through, but i have a shit ton WAY more than normal |
and by the way my afr go to the 12 range at WOT but tend to stay in the 14 at 1 to 5 pounds of boost
Well you're definately not running as lean as noogie and I. I ordered a scangauge II from garm tonight. Hopefully I'll get it soon and have more accurate readings.
![]() ![]() Drives: 2006 Mazda3 Sedan Join Date: Jun 2007
What is it you're trying to monitor with the Scangauge?
urrently planning a group dyno day with some other tuners in the area within the next month u'll get ur readings as well as graphs
| AFR running extra rich at WOT? | eTiMaGo | Performance Modifications | 15 | 03-10-2007 11:10 AM |
