#1 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
I am getting better at calculating the right sized pump and injectors. The biggest problem is that many of the calculations start with your desired HP output. So... I put in 400 HP. Now I have to put in a more realistic number. So... what do you think is a realistic crank HP that a tuned Blitz kit should be able to put out? BTW, I've been looking at this OBD II software package. http://www.auterraweb.com/dynoscan.html I'll also check out the ones that were posted recently.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
I think its called PBSD (post boost stress disorder). I barely remember last December, when all my friends were enjoying holiday festivities while I wandered around in a daze, smelling of gas and babbling incoherently about induction system leaks
Hell if I know the max hp at the crank! why not enter a value like 150 or 175 and see what you get. Have you thought of trying to talk to someone at RC Injection btw? They are right there in Torrance, maybe you can get some inside info.
Yes. I'll give them a call. Did I say part of my dream included a fuel line popping off and spraying 91 Octane inside the car while I am full boost? I think I'll order the OBD logger by Wednesday once I research the different ones.
#4 | |
Lurker supreme!
Drives: old and boosted! Join Date: Nov 2006
2006 Red Blitzed RS 5-door |
bbwwwwaahahhahhahaa I also keep the magical tool kit and extinguisher in my car!
as well as other ritual objects like the domo-kun shrine I made ![]() ![]() does anyone know if those flat hydraulic jacks are worth the money? they look like they should fit under lowered cars?
Good info on fuel injector sizing
Q: When do I need to upgrade the injectors for my car?
A: The factory fuel injection system operates slightly rich from the factory. Because of this, certain engine upgrades such as low restriction air intake/exhaust systems and/or slight increases in boost pressure can usually be taken care of by the factory fuel injection system. When airflow increases are substantial and the factory injectors are unable to keep up, larger injectors and/or fuel pressure increases are required. The factory fuel injection system can usually accommodate an injector that flows about 15-20% more than stock without compromising the idle quality or the low RPM drivability. If the air flow increase/horsepower target requires an injector that exceeds a 20% increase over stock, there are several options. 1. Re-program the factory ECU specifically for the new larger sized injectors. 2. Add a piggyback fuel computer that will allow you to control the larger injectors. 3. Use a stand alone engine management system to control the larger injectors.
Interesting. Where did it go to on the fuel controller connector?
Here's the wiring diagram that I just pulled off their website. It looks like my V1.3 wiring diagram.
![]() ![]() Drives: 2007 Yaris Supercharged Join Date: Nov 2008
hey guys... i just got my aem wideband installed.... im getting readings at wot 11-12
and when off at wot 12.5-13.... thinking of getting some injector off an 09 tc or corrolla... the 2az-fe engine...... |
#9 | |
Just wait, Noogie is going to be running larger injectors soon and he's going to let us know how it goes. *My gauges came in today! YEEEE. Don't know when I'll get to install them though... ![]() ![]()
im jealous of your WOT readings! ahhh! I should be getting my wideband soon
#11 | |
Garm, what size are the tc injectors. What AFR were you reading at idle?
I think it was mentioned earlier in this thread or another, but it was said that the car would run worst with tc injectors. If anything, only would be good at WOT, but at idle and normal driving, TC would be too much.
If blitz doesn't offer us different fuel controllers with some success, when I get the greddy ultimate, i am going to talk to the tuner and try throw in some tc or matrix/carolla injectors with the 1zz throttle body and tune it accordingly. |
#14 | |
I'm not sure on the size, noogie -- throw them on and see how your car runs so we can settle this. I was normal AFR at idle, 13-14. Did fine on the dyno too, except at WOT over 5k rpm
#15 |
true, this is true.
tC injectors seem like a big jump to go and "try" out. Might be safer going to carolla/matrix injectors , seeing how those run, and if everything is fine, maybe move up to tCs? Go for it noogie! haha
#16 |
I used to have 1700 posts
kcalb is going boosted with blitz very very soon and i know he has a set of tc injectors. im sure if he has issues he will swap out injectors and let us know the outcome.
#17 |
if the car runs ok and there is an a/f gauge to watch, trying them out should be ok if done carefully.
I don't know how much larger the tC injectors are but they aren't huge. I am pretty sure that the Greddy turbo kit for the tC comes with 330cc injectors -- so the stock ones must be smaller than that.
#18 |
I'm test fitting injectors from RC Engineering into the motor on Friday. It's only a fit check to make sure everything bolts down because the injectors are physically bigger than the stock ones. If they fit, I'm working with them to decide whether to install 240cc, 270cc, or 310cc injectors.
That's why I keep asking people what size injectors they are installing and whether they are having any problems at idle or under light throttle.
| AFR running extra rich at WOT? | eTiMaGo | Performance Modifications | 15 | 03-10-2007 11:10 AM |
