Old 05-13-2009, 02:21 PM   #1
IsLNdbOi
IsLNdbOi's Avatar
Originally Posted by MGargano View Post
I had the same problem with the new dash trim and a Pioneer AVH-P4000DVD. My head unit has that non-removable trim piece around it as well. Just use a dremel tool/sand paper/file to trim the plastic dash trim until it fits. Took me about 30 minutes but finally I got it to snap into place and it looks awesome. Don't give up because it can be done with a little patience. The pieces you file/sand cannot be seen once the dash trim is in place, so don't worry about that.
Wait so what did you have to file? The parts of the HU I circled in red or the trim piece from Scott? If it was the trim piece from Scott, what part of it did you file?
In doing some searching, I see mention of it being common to have to trim to fit the FH-P8000BT. I couldn't find actual dimensions for that ring. Usually the installation manual has the detailed dimensions, but not for that Pioneer.
Scott, add me to the list (if you have one) for the next group buy. I'd like another one of these since I damaged the first one. The damages could be easily fixed by sanding and repainting, but I don't have the time or skills for that.
IsLNdbOi is offline
Old 05-13-2009, 02:46 PM   #2
OK - I'll add you to the list. Looking at your pictures, I think that what you will need to trim is the scratched area, so you may be OK, other than the scratch on the outer part of the right side.
Can you pop off the existing trim and take a picture with the new trim aligned, so we can see how much trimming needs to happen for your HU?
Looking at peoples' responses thus far, it looks like Pioneer and Kenwood units have required some amount of modification to fit. Eclipse HUs seem to fit without a problem. As people install theirs, please post your HU make/model and experience with the installation, and I'll start compiling the data on the first page of the thread, so we'll know what works out of the box, and what requires modification to work.
CTScott is offline
Old 05-13-2009, 03:59 PM   #3
pariahdecss
Yarisomniac
pariahdecss's Avatar
Drives: 2009 5spd LB
Yes my HU is a Kenwood DNX7120 and I had to trim the new trim piece (not the headunit) about 10mm on the back lip to make it fit - for those that are really picky the color of the new piece for my '09 LB is not a 100% match against the center AC/Air center gauge cluster trim but I am fine with that. The new trim piece is lighter than the slightly darker/smokier USDM center gauge panel.
. . . but it still looks hella better than the MetraŽ gap filler crap kit
pariahdecss is offline
Old 05-14-2009, 11:23 AM   #4
Danish Yaris
Drives: Toyota Yaris 1,8 TS 5dr. 2007
Hi
That´s because the radiopanel is made for the non faceliftet model which is a lighter silver in color.
Regards Steven.
Danish Yaris is offline
Old 05-13-2009, 04:31 PM   #5
I just popped mine off to take some measurements. My Eclipse AVN2210p (which is actually the radio that Toyota made this piece because of) has a wider trim ring, which is about 1" in from the face. You can see it in the picture below. The wider ring is 179mm x 97mm. The narrower section is 170mm x 94mm.
The new trim piece's opening is 174mm x 100mm (6 7/8" x 3 15/16"). This is 6mm narrower than Double DIN spec, which probably explains why some HU's fit without a problem and others don't.
Also, the lip of the new trim piece extends 10mm deeper than the original did (see the pic below).
CTScott is offline
Old 05-13-2009, 05:07 PM   #6
IsLNdbOi
IsLNdbOi's Avatar
Thanks Scott. Keep me on the list. I'll try taking pics. later. I just find it a PITA to remove the trim pieces and panels to take the HU out.
IsLNdbOi is offline
Old 05-13-2009, 05:19 PM   #7
Grab the vertical trim pieces low, on the outside (by the storage pockets) and pull outward. They come off much easier from bottom to top.
CTScott is offline
Old 05-13-2009, 06:03 PM   #8
enviri
enviri's Avatar
Drives: 2010 Yaris
scott add me to the list too, its time for me to start getting a system.
enviri is offline
Old 05-13-2009, 06:13 PM   #9
It has arrived in Canada!
Will try to install tomorrow night. HU will be JVC.
WeeYari is offline
Old 05-14-2009, 04:25 AM   #10
IsLNdbOi
IsLNdbOi's Avatar
I tried trimming all around the back of the trim piece. Trimmed all the way to the line on the surface where you can see where the plastic was "joined" together.
Still no go. This is the best pic. I could take of it.
It's like this on both sides:
I do plan on getting the new version of the P8000BT later this year. They've released new versions of most of their 2008 models already. Hopefully, they don't add the stupid faceplate on the new model.
I do still want another of these DD trim pieces Scott so keep me on the list.
IsLNdbOi is offline
Old 05-14-2009, 10:42 AM   #11
If I understand correctly, you're trimming the lip of the trim piece to make it less deep? If that is the case, how close is it depth-wise from the trim piece being able to snap on? Also, if you were able to move the HU in deeper (by re-drilling the bracket mounting holes), would that help?
CTScott is offline
Old 05-14-2009, 04:53 PM   #12
IsLNdbOi
IsLNdbOi's Avatar
Yes, I thought that's what everyone was telling me to try in the previous posts in this thread. It doesn't look very nice though. You can see in the picture that the trimmed lip can be seen.
Not sure how close it is to being able to snap on. Didn't take that measurement. I don't think moving the HU in deeper would help. The problem is the attached ring / faceplate on the front of the HU.
IsLNdbOi is offline
Old 05-14-2009, 06:48 PM   #13
SHIT!!
It's not going to work without some jigging. Going to have to shave about a quarter of an inch off of the sides of the HU opening in the trim panel.
WeeYari is offline
Old 05-14-2009, 07:47 PM   #14
SHIT!!
What HU do you have?
CTScott is offline
Old 05-14-2009, 07:52 PM   #15
JVC
WeeYari is offline
Old 05-14-2009, 08:06 PM   #16
JVC
Looking at an unmounted picture of your KW-XG700, it has a similar lip to IsLNdbOi's Pioneer. Does the narrower part beyond that lip fit through the opening, or is that the area that needs to be trimmed for?
CTScott is offline
Old 05-15-2009, 12:31 AM   #17
IsLNdbOi
IsLNdbOi's Avatar
The manual for the P8000BT shows this for the dimensions:
Dimensions (W × H × D):
D
Chassis ..................... 178 mm × 100 mm × 160 mm
(7 in.× 3-7/8 in.× 6-1/4 in.)
Nose ........................... 170 mm × 94 mm × 8 mm
(6-3/4 in.× 3-3/4 in.× 3/8 in.)
I couldn't get the P8000BT in even through the front of the new trim piece.
IsLNdbOi is offline
Old 05-18-2009, 01:28 PM   #18
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
pm sent
ozmdd is offline
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
Double Din 180mm Trim Bezel esyres In Car Entertainment + Electronics (audio / video / alarm) 19 03-19-2009 09:01 PM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 03:59 PM
