#1 | |
Yes, you need a wiring harness adapter: http://cgi.ebay.co.uk/TOYOTA-YARIS-R...3286.m63.l1177 |
#2 | |
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
Scott,
Can you give me two pictures of the bracket standing on its end as if it was in its mounted position. I would like one of both the inside, and outside of the bracket. It would be my intent to combine bracket photos, with one of the side of the HU so that I may draw arrows between the two to indicate re-alignment positioning. Thanks.
#4 | |
Stock Radio Mounting Brackets.jpg Both brackets viewed from front: Both Brackets.jpg Left Bracket: Left Bracket.jpg Right Bracket: Right Bracket.jpg |
Yarisomniac
Drives: 2009 5spd LB Join Date: Nov 2008
I had to do this too, in my case I took a ball peen hammer and bashed down the alignment bumps, and then I slotted out the holes so that I could slide my HU further back so that it is almost flush with the new trim - slightly proud. It looks much better this way. It did take some back and forth to get it exactly how I wanted it, but damn it looks sweet.
This pic should work for now.
It may have been blind luck that I was able to achieve the exact amount of movement required for my JVC HU.
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
No, 2 screws in each bracket.
In between cities
Drives: 2006 yaris ce Join Date: Feb 2006
Received it two days ago but doesn't work with my two single din setup. The radio & the bottom cover pocket are 182mm. I could cut the plastic to get the radio to open but as in the picture, the bottom cover is wider so that wouldn't open. So now I may have to get rid off it, if i can't think of anything after the weekend its gone. I wanted one so badly and i can't use it now. Here a pic of my setup so if anyone else has the same the 180mm radio trim wouldn't work.
#10 | |
How about pushing the headunit in deeper, per WeeYari's instructions above? The HU should work that way. The question is if the door on the pocket will fit within the trim. |
Thanks guys. I'll give this a try when I get the new trim piece.
Seems like none of the Pioner / Pioneer Premier head units fit properly in this double din trim piece. I wish Pioneer would create proper double / single din width head units.
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
It will fit if you trim the double DIN trim accordingly. I have the Pioneer AVH-P4000DVD which has the same weird face trim piece as yours and I made it work perfectly after a few trips back and forth to the garage to use the dremel tool.
Trimmed mine as well. A little bit at a time. Had to trim so much to get my P8000BT to fit that by the time it was trimmed enough, you could see the jagged edges I "trimmed" using my dremel. I posted a picture earlier in this thread.
By the way, I have an extra set of brackets.
If someone doesn't have to tools, or doesn't understand the grinding process to move the HU deeper, so the trim piece will fit with wider HUs, I can modify the set that I have and ship it to you in exchange for your set. |
In between cities
Still doesn't work due to the cover it the same size as the pionner unit. Because of pionner stupid din size i had to trim the double din metra brackets so it could fit. Guess i'm stuck with the 200mm opening. Unless i change the cover pocket to an open version. But then i'll have items out in the open which i don't like.
#17 | |
How do you grind the positioning stubs? Will a dremel w/ a sanding head do it? All I have to do is grind down all of the positioning stubs on the sides of the bracket that face the head unit, right? |
#18 | |
Yes, all you have to do is eliminate all 6 stubs on the HU side of the bracket.
| Dash destroyed in electrical fire. | purpleminx | General Yaris / Vitz Discussion | 79 | 06-12-2009 03:53 PM |
| [Recovered] Group Buy for Australia #1 (Badges) | harveyjai | Australia | 9 | 12-13-2008 03:59 PM |
