Yarisomniac
Drives: 2009 5spd LB Join Date: Nov 2008
Got mine today and stuck it in, it looks a helluva a lot better than my old Metra kit. I had to trim a little off of the back for my particular headunit with my Dremel but it did not take long. I have a lousy camera . . .
![]() ![]() Thanks CTScott and Steven (Danish_Yaris) for coordinating this
Where is Oahu?
add me on the list if you do another one :)
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
my yaris from uk will it fit? i would be interested but will you ship to uk?? |
#4 | |
PZ489-B0330-00 (The silver trim piece) 55436-52010-B0 and 55435-52010-B0 (The left and right vertical trim pieces) You may be able to get the parts directly from your Toyota dealer, since they originate from Europe. If not, it would probably be much more cost effective for you to go directly through "Danish Yaris", as shipping from Denmark to the UK would be more reasonable. |
#5 | |
http://cgi.ebay.co.uk/ws/eBayISAPI.d...%3DI%26otn%3D2 i have a alpine cda-9855
#6 | |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Been trying to install mine for the past 10 minutes, but can't get it in. I have to angle it to get one side in, but can't angle it the same way for the other side to get the other side in.
Scott, you have a 5-door '09 LB as well. Any tips on putting it in? |
Ok, figured out why it won't work. My HU (a Pioneer FH-P8000BT) has a small "faceplate" around the front. It's permanently attached (cannot be removed) and this faceplate makes the sides of the unit a little larger than what this trim piece can slide through.
Do you take returns Scott? Anyone interested in mine? I did manage to scratch it up a little when trying to get it on. There are three scratches on it now. Two are in spots that would be hidden anyway once a head unit is installed (the dark smudges on the the back corner in each pic.). The third is on the front right side of the trim piece. Pics.: ![]()
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
If the HU faceplate has any trim that sticks out behind the 7" width of the chassis, even if it looks like it can never come off, it can. That head unit can be made 'chassis flush' all around, as seen from this rear-shot of the fully stripped chassis:
![]() Or is this a matter of things not quite fitting just in the corners? Have you tried sliding the head unit into the trim, instead of the trim over the head unit?
I tried sliding the HU through the front and the back and it wouldn't fit. It's not just the corners. As I mentioned above, the FH-P8000BT has a faceplate permanently attached to it that can't be removed. I took the entire thing out and it does have screws to remove the entire front of the unit. When you do that, you find that the parts circled in red are permanently attached / molded into / is one piece w/ the entire front of the head unit.
I've circled it in red here:
#11 | |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
#12 | |
![]() ![]() ![]() Drives: Toyota Yaris 1,8 TS 5dr. 2007 Join Date: Dec 2008
Hi
I´m happy to hear all likes the trims. If Scott wants and there is enough, I sure will help you with more radiopanels. Lammy29: If you can´t get the part numbers that Scott wrote to you, I can ship it directly to you, no problem. Regards Steven. |
#14 |
So I swap mine last night.
I have a Kenwood-8120 and I had to shave off the inner side for about 15mm to make it fit. I guess for some bigger HUs like mine, there will be some modification work needed. It tooK me 1.5 hours but I am still happy!!! Thansk Scott and Steven ------------- Yup, I did it with a dremel. Last edited by JosephDoc; 05-13-2009 at 04:29 PM. |
#15 | |
Scott, add me to the list (if you have one) for the next group buy. I'd like another one of these since I damaged the first one. The damages could be easily fixed by sanding and repainting, but I don't have the time or skills for that. |
#16 | |
Can you pop off the existing trim and take a picture with the new trim aligned, so we can see how much trimming needs to happen for your HU? Looking at peoples' responses thus far, it looks like Pioneer and Kenwood units have required some amount of modification to fit. Eclipse HUs seem to fit without a problem. As people install theirs, please post your HU make/model and experience with the installation, and I'll start compiling the data on the first page of the thread, so we'll know what works out of the box, and what requires modification to work. |
#17 |
Yarisomniac
Yes my HU is a Kenwood DNX7120 and I had to trim the new trim piece (not the headunit) about 10mm on the back lip to make it fit - for those that are really picky the color of the new piece for my '09 LB is not a 100% match against the center AC/Air center gauge cluster trim but I am fine with that. The new trim piece is lighter than the slightly darker/smokier USDM center gauge panel.
. . . but it still looks hella better than the MetraŽ gap filler crap kit Last edited by pariahdecss; 05-13-2009 at 04:01 PM. Reason: felt like it |
#18 | |
That´s because the radiopanel is made for the non faceliftet model which is a lighter silver in color. Regards Steven. |
| Dash destroyed in electrical fire. | purpleminx | General Yaris / Vitz Discussion | 79 | 06-12-2009 03:53 PM |
| [Recovered] Group Buy for Australia #1 (Badges) | harveyjai | Australia | 9 | 12-13-2008 03:59 PM |
