Blitz did do R & D, and many USA owners are enjoying their extra power without issues. The weird thing is that the people experiencing problems are all having slightly DIFFERENT results. No pattern, really -- unless you see one I can't see? What I do see is that the blitz kit was added to modified cars in every case.
Unless there is variability in the fuel controller from unit to unit (unlikely) or there is variability in the install and mistakes were made (also unlikely), this is not going to be easy for Blitz to solve. I would not think they would provide a different map for each owner's unique set of readings. This is an R&D session, please understand that it probably won't be a quick fix.
Vroom Vroom Beep Beep
what I wouldn't understand is why would blitz not figure other mods would be done. No one really goes I'm going to get a supercharger first then the rest only on rare occurences. If your buying a supercharger you aren't buying it for fuel economy your getting it to aide your lead foot. And either way if what your saying is correct then anyone with the kit can only run the kit and cannot add anything. I'm just offering possiblities. This whole thing is just weird. I actually want to know where the chargers were purchased from if it's the same place cause they could have sent a defective batch. It's extremely rare but it does happen.
Ever blown out an R-200 diff god know's I have
So they are supposed to try and create some universal map to account for every combination of aftermarket mods? That sounds problematic to me.
The weird thing for me is that only a few people are experiencing problems, and the problems aren't consistent. The chargers were purchased from Blitz in Japan, it's the only place they are made.
I wasn't talking about Blitz from japan I was asking where in the US ie what vendor. And I know its problematic to do a map for every app and I was not implying that but having a selection of a few wouldn't have been extremely difficult either.
i have always had a spark nock in my car from the beginning i use 91
so i took my car back to blitz and they changed the map and it ran better no nocking but i think that the car got used to the map and now it is back now i run 5 gallons of 100 octane and the rest 91. but now my car seems to be miss firing when hit the boast. but when you turn the s/c off it runs fine you can punch it with no studering at all i have gold air light pulleys header exhauest. i am taking my car back to blitz on the 18th hope they can fix it thanks laszlo |
#6 | |
Would they be willing to do a map that meets our mods? do you got any dyno charts or A/F readings? |
#7 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
![]() I for one appreciate your concern, but for the sake of those of us with an actual vested interest in the outcome, can we please keep this information gathering thread on topic? Discussion of symptoms and thoughts as to causes is potentially useful here, but random speculation about the manufacturer or vendor is not. |
![]() ![]() Drives: 2007 Yaris Supercharged Join Date: Nov 2008
mods- aem cold air intake, nst crank pulley, using factory plugs, using 93 octane gas and stp octane booster, 2.25" exhaust pipe and aftermarket muffler
boost-8psi-10psi problem-pinging noise when in low setting at lower rpm... i'm thinking of getting abit larger fuel injectors to see if the pinging noise goes away.... |
#9 | |
#10 | |
Ok Garm thats what I wanted to know. And Jo other then symptoms right now all you have is random speculation cause the problem hasn't been found. I think even blitz can't find a way around our ECU's without replacing them with a stand alone. I'm done posting here back to what garm intended it for.
#13 | ||
The effect of it's adapability is just much more pronounced with the supercharger... if I vary my driving style for even a day (say, slow-poking along at revs consistently below 2500) I can sense the slight adjustments it's made (drop in idle speed, rough running, etc). When its running well though, I couldn't ask for better, smoother, more predictable performance.I guess I'm just really impressed that Blitz has managed to deal with the intricately efficient, dynamic fuel system as well as they have! It seems to me the current fuel map functions well within reasonable tolerances of performance and safety, but I can't speak for others. However, if they can come up with a better map that takes my intake/exhaust mods into greater account, then I'll be more than happy to experiment with it. Quote:
#14 |
OooOo that'd be ideal.
#15 |
I just realized something, and you guys probably already brought this up, but I just realized Noogie and I are the only ones experiencing lean conditions with the s/c. We are also the only guys using the aFe intake with the kits. Is this true?
Noogie put your stock air filter on and give us some numbers! My gauges are ordered but won't come in until tuesday! |
#16 |
my question is, what was Blitz's target AFR under boost? They hsould know best what it should be, and the SC owners can then compare their results.
I mean, it is a relatively low amount of boost, it may make sense that Blitz didn't see the need to enrichen the mixture so much?
#17 |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
Guys, It sounds like Blitz did not do enough R&D to check compatability with other aftermarket parts (intakes specifically)
You guys really just need something extra (piggyback etc.) to tune the car with. I'm not sure Blitz is really going to be able to help with that. The TRD superchargers are very similar to the Blitz units (roots SC and a fuel controller box wired in) and they do not have these types of issues. Those with intakes - Measure the ID of you intake piping where the MAF mounts and compare this to the stock intake. |
#18 |
I used to have 1700 posts
my car runs fine under boost BUT when im cruising down the highway with the supercharger set at low(being the high setting) and the throttle is below 5%, meaning the supercharger is not engaged and i am not making boost, the car periodically seems to stutter and the a/f ratios go lean. im guessing this is preignition. this happens maybe once or twice every 10 minutes or so
now when i have the supercharger turned off this does not occur. |
| i have a q to US owners | FlyingDevil | New YARIS Purchase Forum | 33 | 03-26-2009 09:20 PM |
| Yaris owners in Edmonton,AB | 06vitzRS | Canada | 6 | 02-20-2009 07:38 PM |
| Doctors Vs Gun Owners | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 0 | 01-29-2009 07:36 AM |
| READ YOUR OWNERS MANUAL!! | MadMax | General Yaris / Vitz Discussion | 29 | 12-14-2008 10:38 PM |
