![]() ![]() ![]() Drives: 2008 Yaris Liftback Join Date: Oct 2008
I put on 300+ miles in a day and have no complaints. If you're used to luxury cars you're going to see a difference. That goes without saying.
![]() ![]() ![]() Drives: 07 Yaris Liftback Join Date: Aug 2006
I was in my Yaris for about 10hr/day for 2 years and accumulated 150,000km in those years. I wish I had cruise control, on occasion I had to drive with my left leg cause the right one was cramping up. I'm 6'1 and 255lb and after a long drive, I don't have any upper body fatigue, it's the legs/ankles etc that get fatigued. The cruise control and a more reclined seating position in the Sedan should solve that problem. Also, my Yaris was an 07, I've noticed that quality of the seat's fiber/cushions can change over the years, so be ware.
If the priority is highway running and good fuel consumption, while cruising well above the speed limits, there isn't a better formula. On a side note, the Sedan is probably better for highway cruising, but I'd still prefer the Hatch for the better dynamic around the turns. |
![]() ![]() ![]() ![]() Drives: Yaris 5 door liftback Join Date: Jan 2009
Have you considered a Corolla?
Comfort and good gas mileage. |
#4 | |||||
I looked around at a used Tercel, but my head hit the door jamb when I tried to get in, so I walked away from that. The Yaris is 4-5" taller and I have no issue getting in or out of it. Quote:
so I might just tack on the $400 for the option, as I won't drive a vehicle long distance without cruise. As for sway, I don't travel more than 75mph on US Interstates. I like setting the cruise on all my vehicles around 110km/h or approx. 70mph. If time is of utmost importance I might speed a bit and set it at 76!Quote:
Which aftermarket cruise control setup did you go with? The ones that I can find are all in the US, cost about $250, but after I factor in exchange and customs it works out to the same price as a factory Toyota unit ![]() The Yaris has a better HP to weight ratio than my '99 Taurus does. Yaris (auto trans, approx.) 2450lbs / 106HP = 23.113lbs/HP Taurus 3740lbs / 145hp = 25.793lbs/HP Again, thanks for all the replies guys. I know the only way to know for sure is to test it for myself, but the dealer won't let me until I sign on the bottom line. With any luck the wife will make up her mind if she wants to get the vehicle or not. I've been taking her out for lessons in my larger Taurus, but the front end needs a lot of work as an alignment can no longer cure the problem. I just can't bear to put more money into it...so we'll see! |
![]() ![]() ![]() Drives: 2007 Yaris/2009 Phit Sport Join Date: Jun 2007
The seats are cheap and unsupportive. On long drives, my back hurts from the lack of support. I'm not fat, and I have no back problems. I work out regularly, and I'm 5'11, 170. It's the seats, not me. They suck.
Obama 2012 Re-elect the President |
![]() ![]() ![]() Drives: toyota Join Date: Feb 2009
god damn seats! I hate them, so uncomfortable
![]() ![]() Drives: 2009 Yaris with TRD parts Join Date: Nov 2008
A local upholsterer dramatically improved my seat's support for $125.
2009 Base model Bayou Blue 3 door hatch, 5 speed manual trans, Option Group D, factory floor mats, accessory mud guards, TRD shocks/springs/rear bar, TRD leather wrapped shift knob, Pioneer FH-P8000BT "double DIN" head unit & 4 Infiniti Kappa speakers, stainless steel license plate screws, Toyota stainless exhaust tip, enhanced driver's seat (professional upholsterer added spring mesh to lower seat cushion which DRAMATICALLY improved support/comfort and also built up lumbar region in seat back for more aggressive lumbar support. Seat Mod Cost: $125; the seat "feels" $350 better.) |
Chillin' out by the Bay
Drives: 2007 Yaris Liftback Join Date: Nov 2006
What did he do?
Gettin' all the way down. Meteorite '07 HB STILL completely stock; but.... checkin' out da other ones to see what's what. |
![]() ![]() ![]() Drives: 2007 MX5 Join Date: Feb 2009
I find it more comfortable than my miata on long trips
![]() ![]() ![]() Drives: 2008 Yaris Liftback Black Join Date: Oct 2008
I would say after 4 hours it's uncomfortable.... I wish I had cruise control! =*(
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL Representing The Midwest! http://www.cardomain.com/ride/3132598 |
I have a GPS and an aftermarket tach on my 08 Yaris. It has a 5-gear manual, but I have a true cold air intake, megan header, 3A racing muffler, 2" lowering springs, NST short shifter, pedal covers, Silver Star headlights, and lots of other little things that don't mean much to some people, or to the fact I drove 1500+ miles in 36 hours, including a 12 hour delay because of a snow storm on the 80 in Colorado. It was moderately comfortable, but the fact that it was a manual, my leg hurt in the traffic jam on the stupid mountain (3 accidents back to back). There is also no cruise control, so that made finding a steady speed a little harder to do. I also had a TON of stuff in my car, so it was weighed down really bad in the back, which killed my gas mileage. I averaged between 37 and 40 MPG's. I also had the engine at or over 3,400 RPM's for a very large majority of the trip. My car seems to be geared rather low for going 80 MPH. As for seat comfort, it was pretty good. My neck got a little stiff and stayed kinda sore the whole way, but not bad.
![]() ![]() ![]() Drives: Black '09 2dr HB Join Date: Feb 2009
I drove 8 hours last week, longest I've ever done, only thing I noticed was my leg was aching around the 6hr mark. I got out for literally 5 minutes at 4 hours but went straight back to my car. I don't know if it was the car, the way the seats are, or if thats just a normal side effect from driving for so long!
Also, yes the car gets really loud when you're going fast on the highway, I always play adjust the radio volume because when I'm on the highway I need it loud, and then if I need to stop or slow I turn the radio down because then the radio is too loud for comfort.. Be prepared for the sway when you go really fast. First time I went above 80, in my yaris or any car was during my 8 hour drive and omg, did it sway.. but also when you're going a regular speed like 55, it sways a bit too. Also, I've never had or driven cruise control so I guess I don't know what I'm missing! I never care that I don't have it. |
p.s.- the car tops at 117 MPH... in 4th gear on a manual. It just sorta stops for a few seconds, then kicks back on. Very strange. But yeah, 117 MPH is the fastest it will go.
#14 |
aka SDMF
just change the seats, thats what i did
#15 |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
I put on 125 miles/day and I do find the seat bottom a little flat after an hour. I simply got some padded seat covers from PepBoys and that seemed to help.
Someday I'll take the time to get some Scion XB seats from a salvage yard and put them in. Just that little bit of extra side and front bolster on the Scion seats seems to make a difference for me. I did put in the aftermarket cruise control on a Saturday afternoon and it helps when we go on vacation trips. We have driven over 6-1/2 hours at stretch without any difficulty. The Yaris has the same HP to weight ratio as some V6 vehicles. Off the showroom floor its not a racer or a super economy car, but you can tune it in either direction. |
#16 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
6'1" on a 3-hour trip. Very slight back ache, but otherwise no problems
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#17 |
I am new :D
Well, I was recently a passenger in a Yaris on a 4 hour trip (Ask AlexNet0 about it :) ) and I didn't become sore or aching during the entire thing. Besides for my left knee (which is always unreliable), I was comfortable on the whole trip.
#18 |
The upright seating and the short seat cushions make for a not-so-comfortable gas pedal address. If it had cruise control and a manual seat tilt adjustment, it would be much more comfortable. That said, by the time I need fuel, I'm ready to stretch anyway.
| Im in Yaris heaven..... (Special Edition Yaris) | YAR1S | Photo-Video-Media Gallery | 77 | 06-16-2010 10:55 PM |
| Find pictures of the Yaris based on color here | YarisBueller | Photo-Video-Media Gallery | 0 | 01-13-2006 01:24 AM |
