![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
I was lucky enough to have another vehicle to drive, but the dealer had my car two days before the work was completed. I did tell them to not rush it as I really hated having the dash taken apart and was worried about dash rattles. So far three months later everything seems well screwed together again. So glad I had it done-I really thought the musty smell after using the a/c was something I had to live with-nope.
![]() ![]() Drives: Bayou Blue 2dr, AT Join Date: Jun 2007
I finally got out of there at 6:00, as the dealership was closing... and found that they put my console back together wrong!!!! They switched around the heat and blower controls, and now neither one feels exactly right. The whole thing doesn't look flush either. I am so pissed off.
![]() ![]() ![]() I guess I should have let them keep it and "not rush it." God damn it. |
Da Uncle
Drives: 2008 Toyota Yaris Sedan Join Date: Oct 2008
I called the dealer last week to ask about the odor from the AC. From the quick reply they gave over the phone I could tell this was a frequent problem with them.
I didn't mention the TSB (I am not in the US) but all they suggested is to take an appointment (earliest available is after mid January) and they would clean the AC with some chemical. It would take more than 3 hours to finish and would cost me 75 USD. what a rip off. ![]() I will call them back later this week ans ask why this is not covered by warranty. I mean the car is still under warranty and the AC is not functioning properly right? ![]() I bought an air system cleaning can. it comes with long tube. i used the tube and sprayed the inside of the AC for 5 to 6 seconds. I haven't used the AC since then, but the car smells extremely clean and fresh that it some times gives me and my wife a headache. |
#4 | |
Da Uncle
Have the dealer run your VIN to see if it falls under the TSB for a/c evap. replacement. The musty smell comes from the metals used to make the evap. core-it's defective. But once you run out of warranty you're out of luck to get toyota to cover it-and it's not a safety item, hence no recall on this problem.
#6 | |
Da Uncle
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Not a safety problem? Is it healthy to breath in these gases, especially if the A/C gas starts leaking?
Half a Bubble Off Plumb
The AC refrigerant gas is the same stuff used to propel the medical inhalants people with asthma and COPD use. The FDA says they're safe, in the small quantities they use. If you have a big enough leak to be breathing much of the gas, your AC's going to quit working shortly.
I like how they always start every TSB "some customers may experience" when in actuality usually all customers experience the problem but have not complained about it yet or are just afraid to bring their car into the dealer cause they are past the warrenty period.
Has anyone attempted to do this repair themselves? The reason I ask is i called the local dealership and because my car is JUST out of the warranty they would not cover it, not to mention the whole "we have to test to find out if thats the problem" routine. I know what the problem is and hate going to the dealership at all especially multiple times because of stupid requirements. I guess I would need to know what all the correct parts #'s are so I could have everything ahead of time.
#11 | |
As for the parts required, if you look at the pdf of the TSB (which is posted), it lists the parts that get replaced. |
Here is a picture of stuff you can get to fix stinky climate control systems.
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
#14 |
ok well at least that gives me something to work with. Still have to go to a shop to recharge the system but it should still cost less than getting the whole thing done there. i hope.....
#15 |
I just had the TSB about the exhaust/catalytic converter assembly replacement done. Sulfur/burning trash smell is gone! Burning oil smell introduced!
Last edited by swidd; 03-28-2010 at 06:07 PM. Reason: EDIT: it improved my MPG from steady average 37 to 39 on last tank! |
#16 |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
#17 |
Its a really bad idea to run your AC on recirc for long periods of time. Frequently change to circulate fresh air. Mold or something gets in the internal components of the climate control system. It stinks to high heaven. My wife did that to her Camry and its hard to sit in the vehicle it stinks so bad.
#18 |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
| Response from Toyota on my special order | drdavidr4u | New YARIS Purchase Forum | 14 | 04-27-2010 08:59 PM |
| service at toyota | THEDON | DIY / Maintenance / Service | 4 | 04-24-2009 01:45 PM |
| Does Toyota have a website for recording vehicle service? | YarisOwnersDad | DIY / Maintenance / Service | 4 | 04-04-2009 11:42 PM |
| Funny Business at the Toyota Service Centre | *MAD DOG* | DIY / Maintenance / Service | 10 | 01-10-2009 12:47 AM |
| Toyota Delays | Buckethead | General Yaris / Vitz Discussion | 3 | 08-26-2006 03:16 AM |
