Old 04-30-2009, 05:51 PM   #1
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Well done, CTScott! Great post.
Old 04-30-2009, 06:20 PM   #2
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Scott, you are a true asset to this forum. Thanks so much for putting this together!
Old 05-01-2009, 10:30 PM   #3
uncleyaris
Fantastic!!!!!!!!!
Old 05-02-2009, 09:16 AM   #4
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
So even if my 07 lifty doesn't have those indicator lights, there's a chance I can still do this mod with the switches and some LEDs? And where did you get those little switches?
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-02-2009, 10:13 AM   #5
nickhjort
nickhjort's Avatar
Just reading all the other threads and posts on this topic and answered my own question :) I can't wait to start ripping $hit apart!!
My Car Rules!
Old 05-02-2009, 10:29 AM   #6
frownonfun
frownonfun's Avatar
subscribed
Old 05-02-2009, 10:48 AM   #7
TDB-1
Drives: 09 3-door 5speed
Just did this DIY on my 09 5 speed and it works great. I had to jump the clutch switch connector untill I get the switch, just dont step on the clutch while on cruise!!!
THANKS to all who helped figure this out
TDB-1 is offline   Reply With Quote
Old 05-02-2009, 10:58 AM   #8
nickhjort
nickhjort's Avatar
What will happen if you hit the clutch while in cruise (if you jump the clutch switch)?
My Car Rules!
Old 05-02-2009, 11:02 AM   #9
nickhjort
nickhjort's Avatar
I guess I should have read the other thread first :) You said it will over rev if you hit the clutch while jumping the switch in cruise control. Why would you need to use the clutch while in cruise anyway. If some $hit goes down you just have to hit the break to turn off the cruise then cluth after it turns off right? It's not gunna mess anything up mechanically just by jumping the clutch switch is what I'm getting at I guess.
My Car Rules!
Old 05-02-2009, 11:55 AM   #10
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
learning
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 05-02-2009, 12:02 PM   #11
momerath
Drives: '09 Yaris 2 door liftback
Hello. I'm eager to try this out next week. I just have a couple of questions.
Question #1:
You stated in step 6: "Connect wires from switch assembly to wires on connector D3. Red wire from switches connects to blue wire of D3 Pin 1. Black wire from switches connects to brown wire of D3 Pin 3."
It's unclear whether or not I connect the switch assembly wires to the blue/brown wires themselves or to the connectors. The picture isn't clear because I'm not seeing the added black and red switch assembly wires. Is the picture under step 6 a before or after? It is exactly the same as the picture under step 3.
Question #2:
How do you remove the "push button start" cover? I tried playing with it to see if I could snap it off but I had no luck. It seems pretty firmly in place. I didn't want to force it too much for fear of breaking it off.
Question #3:
How easy is it to run the wire from that cover to the steering wheel assembly? Is there a direct path from the cover into the assembly?
thanks!
momerath is offline   Reply With Quote
Old 05-02-2009, 05:59 PM   #12
Answers in red below:
Question #1:
Picture 3 and 6 are actually the same "after picture". The red tap-splices are how I connected my red and black wires to the brown and blue wires.
Question #2:
You have to pull the black vertical trim along side of the AC controls / radio (just get your fingers under the edge and pull it out). Once that is removed the cover pulls right off.
Question #3:
Very easy - When you come through the back of that hole you loop to the left and right up along the wiring harness for the steering column.
thanks!
Old 05-02-2009, 12:35 PM   #13
nickhjort
nickhjort's Avatar
TDB-1, to jump the switch connector, you simply put a wire from one terminal to the other (the switch plug only has 2 terminals right)? You didn't put a fuse or anything in there just in case?
My Car Rules!
Old 05-02-2009, 01:34 PM   #14
TDB-1
Correct, I actually used a small spade terminal and just pushed it into the connector. Just don't step on the clutch when using cruise!!!! I have not hit the clutch but think if you did it would rev the motor till the computer or rev limiter figures out what is happening.
Old 01-14-2010, 09:17 PM   #15
t2mike2
Drives: '10 Yaris 3 DR - Carmine Red
Where is the switch connector ?
t2mike2 is offline   Reply With Quote
Old 01-14-2010, 09:35 PM   #16
This thread shows the details on the clutch switch connector:
http://www.yarisworld.com/forums/showthread.php?t=23510
Old 05-02-2009, 02:29 PM   #17
nickhjort
nickhjort's Avatar
Gotcha. Thanks again man! And of course thanks to all the smart people who know how to do this stuff and make it easier for us dumb people to DIY :) I'm going outside right now to set this push-button system up. I'll let you know how it goes.
My Car Rules!
Old 05-02-2009, 06:47 PM   #18
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Wow... this is really really cool. I'm pretty sure I don't have the LEDs on the dash, but I don't mind adding some in the same panel as the buttons.
Excellent job, Scott and Pavel!
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
