アキバ製
Drives: 09' White LB, Celica GTS Join Date: Apr 2009
This?!
![]() Wow I didnt even know that HUGE thing was a wire. haha |
yeah thats a constant 12volt wire
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
アキバ製
whoa sweet. Oh! also is it ok to tap the illumination wire to the red constant? just like we did with my tach? so the back light is always on.
edit: how would be the best way to tap that big wire? cut some rubber off and just twist the wire around it and tape it off? |
yup or you can find the alarm wires and tap into the red wire for the alarm thats also a 12volt constant that comes of the biggest harness on the alarm for the illumination wire i would tap it into the yellow wire off the alarm thats on the pack of wires that are all like stuck together so it turns off with the key
アキバ製
Ok! ill give it a shot tom'w and will put my wheels on my car! will report back later tom'w with the good or bad news. Dude thanks again devin.
no problem let me know when u get the alarm and stuff
![]() ![]() ![]() ![]() Drives: 07 Blazing Blue LB Join Date: Jun 2007
Is that 12 constant always on? I was trying to tap into a source that only turned on when the car was on but I guess it doesn't matter
Most Satisfying Crew Serious Business... MunkyWurks Garage - 8088488794 |
the big black wire yes is 12volts constant theres another wire that is ignition only when the key is turned on which is the one that he uses for the tach light
Ok from what I can tell on the manual it says the power gos to ignition and the illumination switch goes to headlight or something. I think he needs to take the two wires apart. I think its blowing the fuse cause we have both the illumination switch and power wire spliced together.
nah shouldnt not unless thats the main power it needs to move the windows
yups it is the main power.
oh ok if its the main power you need constant 12 volts so hook em to the big black wire or the red wire off the alarm and the illumination is off the yellow wire coming off the alarm
アキバ製
Ok when I tap to the big black wire it instantly blows the fuse, I did I twice just to make sure. Ill try tap it to the alarm red off the largest harness and the yellow off the one next to it thats all stuck together.
here we go! |
アキバ製
Ok hooked it up to the yellow and red wire of the alarm. and it blew the tach/radio fuse, but the power window was working, even with the car off it worked. then it stopped. Im not sure if I blew two fuses, but i replaced the tach/radio fuse and tried again.
It blew the fuse again, so i took the illumination tap off the yellow wire and replaced the fuse, and tried. It didnt blow the fuse but it still wont work. No power. But im not sure if I blew two fuses, everything seems to work. edit: Pulled and checked all the fuses in the inside and all good. quite confused Last edited by Taiyaki; 05-23-2009 at 10:20 PM. |
ok so one of two things either it draws to much current or something is grounding out in the unit itself
アキバ製
I was thinking. Could I tap it to a 25 fuse and put it in the empty power window slot?
try hool em up to the battery straight
アキバ製
ok ill try that now.
Ok total newb question, the wire wont reach to the engine bay, I dont know what gauge wire it is. could I use a smaller or bigger wire? or does it have to be the same gauge? |
| What trailer electrical connector required? | charles nelson | DIY / Maintenance / Service | 3 | 01-16-2009 04:51 PM |
| Need help picking a good indash monitor | BelleOfPistola | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 08-22-2007 01:25 AM |
| Any good lease deals out there right now? | sherryberry | Off-topic / Other Cars / Everything else Discussions | 5 | 07-02-2007 04:02 PM |
| a good slide show | derekjd | Photo-Video-Media Gallery | 0 | 05-10-2006 03:26 PM |
| Is this a good deal? | YotaYarisUSA | General Yaris / Vitz Discussion | 2 | 04-09-2006 12:29 AM |
