アキバ製
Drives: 09' White LB, Celica GTS Join Date: Apr 2009
Any good with electrical?
Im going to buy the power window and locks off A1 and I have a Clifford RS 3.5 laying around that I want to put on too. Anyone good with this kind of stuff?
Yoshi I remember you use to do your own woofer installs, do you know about alarms also? haha If not then can anyone recommend me to a shop? I called Jackson at Security and Sounds but they said they wont touch the aftermarket locks, they order the parts from toyota only. |
Where is Oahu?
Maybe call warren at mobile car audio, they did my alarm.
![]() ![]() ![]() ![]() Drives: 07 Blazing Blue LB Join Date: Jun 2007
wow you know warren? hahahah he used to work with me before. I think he moved to the pearl city one. BRing your ca around Taka, I can hook the alarm up. Power windows I gotta t ake a look. IF the 07 and 09 are same then I should be able to install the alarm.
Most Satisfying Crew Serious Business... MunkyWurks Garage - 8088488794 |
Where is Oahu?
^yeah he's a nice guy, very helpful with the alarm since he ran into some problems.
アキバ製
Sweet awesome! I didnt order the power locks or windows yet but ill do that tonight. Right now im installing my double din, tach, debadge, get my saftey check again, THEN put my HIDs, and if still have enough sun light my SRI. so happy
Where is Oahu?
post some pics!
アキバ製
my tach isnt working! :[ i hooked everything up and I get no reading. But got my double din done. do you guys know whats up with my tach?
tapped into the wrong wire probably. You probably tapped into nothing. Did you stick it into the D Connector? if you did and your car didn't come with tach, you don't have a tach signal going into your tach
アキバ製
Idk this guy and others with 09s said to tap into a wire, but when I did, still never got a read. It lights up so I know my other wires are ok, I tapped my ground to the stereo black wire, but tapped it to the car and still dont work.
I had the same problem with my celica, and I tapped it threw the firewall to the tach fuse under the hood. I want to try but cant find it on the yaris. Someone said I might have blew the somthing and broke it, MAN! this tach was super expensive! I would cry |
use a Multimeter to see if a signal is being sent into that wire or connector port
アキバ製
I have one, but like many other tools i have, I have no idea how to use it. Could i use a test light?
just put the positive where the wire goes and the negative to a ground. Then turn the car on. If you get power on the Multimeter it means its the right hole or wire if u dont it's a dead lead.
if u like meet me tomorrow at school and I'll take a look at it. I have time around 3 let me know
アキバ製
I end work at 4pm if your still free after that I can meet
I'm free after 630 I get final at 430
アキバ製
shoots works for me.
k just remember to call me tomorrow I'll try t call you too.
アキバ製
roger
| What trailer electrical connector required? | charles nelson | DIY / Maintenance / Service | 3 | 01-16-2009 04:51 PM |
| Need help picking a good indash monitor | BelleOfPistola | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 08-22-2007 01:25 AM |
| Any good lease deals out there right now? | sherryberry | Off-topic / Other Cars / Everything else Discussions | 5 | 07-02-2007 04:02 PM |
| a good slide show | derekjd | Photo-Video-Media Gallery | 0 | 05-10-2006 03:26 PM |
| Is this a good deal? | YotaYarisUSA | General Yaris / Vitz Discussion | 2 | 04-09-2006 12:29 AM |
