not to hijack this thread but where are all of you guys sourcing your blitz S/C's from? It looks appealing to do down the road vs a T/C due t much less work required t install a S/C. I'm curious to the price and what it all comes with
#2 | |
conundrum562
Drives: Toyota Yaris 2007 S Join Date: Jun 2010
Price is around $3000-$4000 now a days, depending on where you get it from. It is sourced straight from Japan, the kit is a Complete Bolt on but I found out from the installation that you need a tighter belt and added the 1zz injectors to make it run efficiently, Since I have other performance parts. But I believe the kit should run fine if you have everything stock, so far I love driving this car now and it picks up pretty quick for a Yaris ha-ha. I got my S/C from A1-Motorsports and you can negotiate pricing. Took about (3-4 Months) to get... If you are planning to go (SPEED RACER) then no the kit is not worth it, but if you're trying to get an extra boost and a better driving experience with Fuel Efficiency then yes it's worth it. In the end to each their own. But I love it!
--------------------------------------------------------------- BLITZ SC | CERAMIC 6301 BEARINGS | MICRO-IMAGE CRANK | NST PULLEYS TRD 71C THERMOSTAT | 1ZZ INJECTORS | TB SPACER | BLITZ SRI NGK PLUGS, COILS & MAF | DC HEADERS | CUSTOM 2.25" EXHAUST GTSPEC STRUT BAR, MID & 4-PT LOWER BRACES TANABE FRONT & WHITELINE REAR SWAY BARS W/ POLY BUSHINGS TBW SKID PLATE | FULLRIVER AGM BATTERY | MOBIL 1 EP + PROLUBE
Bought mine used from an Edmonton member several years back.
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
I am experiencing audible ping/detonation even with 1zz injectors.
My only mods are a K&N filter in the stock air box and a Fidanza flywheel along with an aem water/meth kit. My afr at wot are around 10.5 and still I hear the audible ping/detonation. I am using ngk7 plugs and 95 octane fuel. When I check ing advance using techstream it is reading in the single digits at wot when I hear the ping/detonation. Can someone suggest what is causing this. I do have a check engine light on related to the egr thingy on the intake side of the head which was removed for the s/c install. Thanks |
Thanks for the info Azian, looks like i'll be saving up for an S/C down the road...
#6 | |
#7 | |
conundrum562
Drive regular, Drive regular then VROOOMMMMMMMMMMMMMMMMMMMMMMMMMM!!!
Wow, that's a damn good deal. The msrp in my opinion isn't worth it, but $1600 is great
conundrum562
Good evening my fellow YARIS-ians,
I was wondering if anyone used this injector before? They claimed it flows at 1497cc and I am wondering if that's overkill for us? FYI I upgraded to the 1ZZ and it's working but I just want to know, if it can get me more gains I might switch over. Anyways see link below and as always appreciate all feedback: http://www.fiveomotorsport.com/fuel-...toyota/?v=3880
#10 | |
![]() ![]() Drives: 2008 Red Toyota Yaris Join Date: Mar 2011
#11 | |
conundrum562
![]() ![]() Drives: Vitz & Supra Join Date: Jan 2011
Guys are celica 2zzge injectors recommended for sc 1nzfe or 1zz sufficient?
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
I use 1zz injectors in my Blitz'd Yaris. I run a AFe short ram intake and don't have any problems going lean with the 1zz injectors.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#14 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
![]() Closed loop boosting under light to medium load on surface streets still shows an AFR of 14.7. That's the whole point of closed loop... the ECU is trying to maintain a preset AFR. What is interesting is that when I get on the freeway and nudge the throttle just barely enough to go to 1-2lb boost, the car goes into open loop and the wideband AFR reads 10.5 or so. You can see from the graph below that I'm not accelerating hard anymore and my throttle position is around 34%. The AFR from the data logger drops to its minimum which matches what the widebande gauge states. I don't know why the car goes into open loop with such a low throttle setting.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
