Old 06-23-2011, 08:52 PM   #1
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Hey guys, I just bought the stuff to do this with.
I got the insulation and the zip-ties, and now I need to get the tape to reflect the heat.
I've got a few concerns though...
What if moisture gets under the insulation? The pipe won't rust will it? I'm rather worried about the long-term affects.
I'll give it a whirl anyway seeing as how nobody has said anything bad about it.
Black_griffin6 is offline   Reply With Quote
Old 10-15-2011, 01:29 PM   #2
poorsh2
Drives: 2008 yaris hb
ss Zip ties
I put the insulation on with ss "zip ties" you can get them at harbor freight
poorsh2 is offline   Reply With Quote
Old 06-29-2012, 07:02 PM   #3
Em_
Drives: 2007 Yaris
i tried it and it melted , it's a fire hazard from my point of view even with reflecting tape,
if the car burns the insurance won't cover
the only solution would be exhaust insulating fabric
Em_ is offline   Reply With Quote
Old 07-01-2012, 09:20 AM   #4
PatrickJohnson
Drives: 2008 Yaris LB
Then you did it wrong. I've had mine on for years now, with no issues.
PatrickJohnson is offline   Reply With Quote
Old 07-01-2012, 10:09 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
here's an example of what not to use and what you should've used...
http://www.thesolarshop.eu/acatalog/...nsulation.html
Old 07-11-2012, 03:18 PM   #6
swidd
Drives: Yaris HB
I've had mine insulated for 3 years or something now, and left it on during cold season, and have never restricted my use of A/C when cold outside. No problems at all, and the high temperature resistant tape holds up nicely.
swidd is offline   Reply With Quote
Old 08-13-2012, 03:50 AM   #7
yours_falsely
yours_falsely's Avatar
Drives: 2008 Yaris sedan
So now that some time has passed since it's first been tried, what I'm taking from this is that there don't seem to be any long term negative effects. Correct?
yours_falsely is offline   Reply With Quote
Old 08-13-2012, 11:40 AM   #8
PatrickJohnson
I'm at 2 or 3 years, and no problems here.
Old 04-20-2013, 07:17 PM   #9
yarisitis
yarisitis's Avatar
For those of you who first did this mod in 2009, how's it holding up? Any negative effects on the AC system? Foam melting?
yarisitis is offline   Reply With Quote
Old 04-20-2013, 07:54 PM   #10
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I did this a year or two ago. The insulation right above the exhaust manifold has melted slightly, otherwise it's help up fine. Didn't REALLY notice a big difference though, but every little bit counts!
Old 04-21-2013, 08:44 AM   #11
Alexrahl
Drives: 2007 Yaris sedan
I did this on my car. Aluminum taped rated to 300f. Wrapped the low pressure line over pipe insulation. It is definitely colder now.
Alexrahl is offline   Reply With Quote
Old 08-02-2016, 03:33 AM   #12
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Sorry for necroposting.
Can someone entertain some questions?
1.First does anyone have pics from the original post?
2. Has anyone quantified the change? As in a before and after. I realize the OP did it.
So I stuck a meat thermometer in various circumstances. 1. Idle with fan at low. 2. Idle with fan at max (4). 3. 3k RPM fan low. 4. 3k RPM fan max (4).
1. Gave me a reading of 44. 2. Gave me 47. 3. gave me 45. 4. gave me 45. ** I'll do the measurements again tomorrow these are off the top of my head. In all scenarios the fan is set to face and the window vents are closed. Thermometer is in the right center vent. *degrees Fahrenheit.
3.I've been reading a lot here and whatever google pulls up for me. It only gets cold after passing through the expansion valve. Where is the expansion valve in our car?
4. That cold piping that people say they are wrapping, isn't that piping that comes out from the evaporator which is the exit flow back to the compressor?
Here are some pics form a different member who applied insulation. http://www.yarisworld.com/forums/sho...sulating+a%2Fc
Old 06-09-2010, 03:36 AM   #13
*MAD DOG*
*MAD DOG*'s Avatar
Originally Posted by Echostatic View Post
Is this the "butt ugly" one or the other one?
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
