Old 06-27-2009, 07:04 PM   #1
texkid
The one with cheese on it
Drives: '10 Corolla S
haven't really got a chance to check, i got the aluminum foil mostly to protect the insulation from melting
Ah. I see. So far, mine hasn't melted. In fact, after doing some errands, I checked the insulation and it wasn't hot to the touch. But I did burn my left forearm from grazing the engine surface.......again.
texkid is offline   Reply With Quote
Old 06-27-2009, 06:33 PM   #2
mrbond
mrbond's Avatar
You can also find the aluminum tape at Menard's and Home Depot in the home ventilation section.
- A Toyota Yaris
- A whut Yaris?
Old 06-27-2009, 07:51 PM   #3
EasyDriver
Drives: 2008 Yaris Meteorite LB
I got half of this diy project done this PM and I believe that it helped already! At the only contact between the high and low pressure lines I slide a piece of thin aluminum pie tin. After a short drive today high pressure line was not even warm...but maybe I didn't drive long enough.
Great pics and a really good project!!!!! Thanks......
EasyDriver is offline   Reply With Quote
Old 06-27-2009, 08:07 PM   #4
mrbond
mrbond's Avatar
There's another section of the low pressure line pretty far down in the engine bay - right where the rubber hose ends and just before the a/c compressor. About an hour ago I spent about 20 minutes wrapping that in the foam insulator and the aluminum tape, then I drove the car for a while. The air temp dropped another degree. Just an fyi.
- A Toyota Yaris
- A whut Yaris?
Old 06-28-2009, 05:12 PM   #5
texkid
Sweet!
But keep an eye on it. Supposedly there might be a greater chance that section of the line could melt the insulation. If it doesn't over time then maybe I'll include in the DIY. I am still periodically checking my lines for excess heat or signs of damage/melting. Good thing I have a fire extinguisher in the car ready for anything.
Old 06-28-2009, 05:49 PM   #6
texkid
...for now everything is a ok , except my nuts are frozen
For that you should use Glad ziplock bags to prevent freezer burn to your meat. I'll write a DIY for that as well.
Old 06-28-2009, 06:10 PM   #7
texkid
i shall provide pictures.... i shaved no worries
ROTFLMAO!
Old 06-28-2009, 06:16 PM   #8
darthbauer
Not really here...
darthbauer's Avatar
This looks like something I should do but as of right now, I have no shade and its like over 100 here in Orange.
Liberate Tutemet Ex Infernis.
Old 06-28-2009, 05:51 PM   #9
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
thats what i do for now , i check each time i arrive home just to be on the safe side. for now everything is a ok , except my nuts are frozen
too much infomation , your nut's are not part of this thread ,
well they wheren't until now anyway
Old 06-28-2009, 06:44 PM   #10
firebob
Drives: 09 yaris
I keep looking at this and thinking about the way I covered my oil lines on my old truck. I split some “heater hose” slid it over the lines and use cheap electrical tape to cover it.
I have not thought about doing this and have not looked at the AC lines to see if this would work. But I do think it would look cleaner than what has been picked and what has been talked about.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 06-28-2009, 07:36 PM   #11
WD-40
07 Yaris RS
WD-40's Avatar
Drives: Red 07 Yaris RS
Thanks for the idea of aluminum foil tape .. I had the foam on last year for a trip to California .. made a huge dif .. then when I got home I removed it due to melting near the heat shield .. I just redid the lines but added the foil tape after reading this.
Yaris lover
WD-40 is offline   Reply With Quote
Old 06-28-2009, 10:02 PM   #12
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Since the tape is a little flimsy and a bit hard to wrap around the pipe, has anyone wrapped the foam around first and then wrap the tape around the foam? I was thinking this might be better...?
Old 06-28-2009, 10:24 PM   #13
texkid
I think that was the original idea?
Old 06-28-2009, 11:30 PM   #14
mrbond
mrbond's Avatar
Yeah, that's actually exactly what I did: wrapped the foam around the a/c lines, zip tied them down, and then completely covered all the foam with the aluminum tape. At least this way you don't have to worry about the foam degrading faster than need be.
- A Toyota Yaris
- A whut Yaris?
Old 06-29-2009, 01:53 AM   #15
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I just went to Home Depot - that aluminum tape is pretty expensive eh?!!
It was rated up to 260 degrees F. Is there any that's higher? 260 doesn't seem high enough.
Old 06-29-2009, 11:55 AM   #16
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
its rated for direct contact , it should be fine for what we use them. its about 5$ here.
What ... I just went to Home Depot and the cheapest I found was $15.
devinlamothe is offline   Reply With Quote
Old 06-29-2009, 12:16 PM   #17
mrbond
mrbond's Avatar
$15? Yeah, that sounds right for the foam aluminum wrapping. I got my huge roll of just the aluminum for $6.10 with tax.
- A Toyota Yaris
- A whut Yaris?
Old 06-29-2009, 12:24 PM   #18
hatchbackkid82
Drives: .
I'm gonna have to try this
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
