Old 08-11-2009, 08:00 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
No dice... still no voltage I guess I'll have to wait for those 3 ohm resistors
MGargano is offline   Reply With Quote
Old 08-11-2009, 09:00 PM   #2
Those points are where the connector is soldered to the PCB, so you shouldn't have seen anything different than we were seeing the other day. I thought you were asking because Santa came early.
Old 08-11-2009, 09:15 PM   #3
MGargano
Unfortunately not...Santa's gotta come all the way from WI to NJ. Shouldn't be any later than Friday.
Old 08-16-2009, 12:48 AM   #4
vten
did you get the resistor yet? any update?
Old 08-16-2009, 02:23 AM   #5
MGargano
I'm really disappointed in the place I ordered them from. Their website shows the resistors as 'shipped' on Monday but I still haven't received them as of today (Saturday) so I hope to have them Monday.
Old 08-16-2009, 08:50 AM   #6
Which place did you order them from?
Old 08-16-2009, 09:00 AM   #7
MGargano
VetcoElectronics.com. And I paid out the a$$ since it was such a small order... $16.82 for 4 resistors
Old 08-16-2009, 01:56 PM   #8
Dang! I should have just dropped some of the ones I have laying around in an envelope and dropped them in the mail. You would have had them in a day or two for the cost of a stamp.
Old 08-16-2009, 02:00 PM   #9
MGargano
Yeah.. big mistake on my part. I know better now!
Old 08-17-2009, 05:10 PM   #10
MGargano
Resistors are finally here! This project is officially back on track!
Old 08-17-2009, 05:24 PM   #11
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
nice man! keep us updated
Old 08-17-2009, 05:52 PM   #12
MGargano
This is a 3 ohm, 1/2 watt resistor, right?
Old 08-17-2009, 06:03 PM   #13
MGargano
Nothing so far. I plugged the 3 ohm (presumably) resistors into the airbag sensors, turned the key, and all lights are still lit. Also, still no voltage to the weight sensors. I disconnected the battery and will try again in a few minutes, but I'm thinking maybe the SRS system needs to be reset/cleared.
Old 08-17-2009, 06:36 PM   #14
more than a few -- I've heard Toyota techs wait 20 to make sure the SRS system resets (it has it's own battery, btw)
Old 08-17-2009, 07:40 PM   #15
MGargano
I figured that out first-hand. I pulled the battery for about 10 minutes, reconnected, and still nothing. It's been pulled about an hour or so now. Think it's time for a second attempt?
Old 08-17-2009, 06:39 PM   #16
Correct on the resistors. Garm is correct on the reserve power for the SRS ECU.
Old 08-17-2009, 11:51 PM   #17
MGargano
Is there a definite answer for how long it takes the SRS ECU to reset itself with a battery disconnect? I want to make sure all the SRS reserve power is drained before trying this again.
Old 08-18-2009, 07:05 AM   #18
Here's what the SM says:
Wait at least 90 seconds after the ignition switch is
turned off and the negative (-) terminal cable is
disconnected from the battery before starting the
operation.
(The SRS is equipped with a back-up power source, so
if work is started within 90 seconds of disconnecting
the negative (-) terminal cable of the battery, the SRS
may be deployed).
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
