Old 08-20-2009, 03:43 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
I've got the battery disconnected now since I tried the reset and ran into the same problems I had the first time. I can't get past the first step. The SRS light is supposed to come on solid after three seconds of removing the jumper, but mine lights up as soon as the jumper is removed. There's no delay.
Old 08-20-2009, 03:46 PM   #2
I think mine comes on pretty quick as well.
Old 08-20-2009, 03:49 PM   #3
Here's another thing that keeps the simulator simple - The sensors all "speak" at the same time. Here's the front right and rear right sampled together:
Old 08-20-2009, 03:56 PM   #4
MGargano
Reconnected the battery... still have codes 32, 55, & 56. I pushed the resistors in from the wire side as well. Is it possible to snip the yellow airbag connector and attach the wires directly with the resistor in between?
Old 08-20-2009, 03:55 PM   #5
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
except for that one little piece in the middle? it splts up the 2nd to last.. i have no idea what im looking at =D
Its a Chao!!!
Old 08-20-2009, 04:12 PM   #6
MGargano
Ok, I managed to get it back to just code 32 after fiddling with the SRS resistors.
Old 08-20-2009, 06:21 PM   #7
MGargano
I found an OC ECU on eBay for $69.99, but I want to make sure that's the problem before I go ahead and order it. Or have we already made that conclusion?
Old 08-20-2009, 08:11 PM   #8
It could be the module or one of the sensors. If any one is not working properly the OCS shuts down.
Why don't you ship me your module and four sensors and I'll test all of the parts out?
Old 08-20-2009, 08:33 PM   #9
MGargano
You rock! I was going to suggest that, but I didn't want to overstep my bounds or anything. You want the OC ECU, the four wires, and four sensors? Anything else?
Old 08-20-2009, 08:44 PM   #10
No problem.
That should do it, as far as the parts go. I'll PM you my shipping address.
Old 08-20-2009, 08:49 PM   #11
MGargano
No problem.
Awesome and thanks. Worst come worst, the auction for the OC ECU doesn't end for almost 30 days so I should have plenty of time to pick it up, if need be.
Old 08-20-2009, 06:34 PM   #12
Based on this I can easily build a module to simulate the sensors (and to switch between an empty and occupied seat).
How much for 50?
Old 08-20-2009, 08:13 PM   #13
How much for 50?
How much you got?
Seriously, based on how simple I believe it is, I should be able to put together a packaged module for under $50.
This weekend I should have some time to prototype it up.
Old 08-20-2009, 09:14 PM   #14
MGargano
Be on the lookout for an Eggo Waffles box in the next couple days.
Old 08-20-2009, 09:17 PM   #15
mmmmm waffles...
Old 08-20-2009, 09:44 PM   #16
MGargano
LOL. All kidding aside, though, please let me know how I can compensate you for all the help you've given me with this so far. I feel I owe you more than just $50 for a module (once you make them), so let me know what else I can do.
Old 08-20-2009, 10:19 PM   #17
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
you mean you didn't leave the waffles in the box
thats abit rude
Old 08-21-2009, 11:09 AM   #18
WooooooHooooo! It works!
This morning I prototyped up the sensor replacement. Initially I couldn't get it working, even though my output and timing were dead on. After a bit of head scratching I realized that the signal line is a one-wire bidirectional communication line. The OCS ECU polls the sensor, and then the sensor responds. Once I figured that out, I was good to go. I now have my device in place of the right rear sensor and have the airbag on light lit.
Next steps:
1. Bypass the other three as well.
2. Take the switch input for arm/disarm
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
