Old 08-21-2009, 11:12 AM   #1
^ Nice. I was definitely serious about a bulk purchase for other people, so keep that in mind as you go along.
Old 08-21-2009, 11:15 AM   #2
MGargano
Drives: 2009 Yaris Hatchback
Me first! Me first!
Old 08-21-2009, 11:41 AM   #3
Definitely! Once I get it buttoned up and tested on a couple of cars (MGargano and mrrock will probably be our official testers) I'll package it for retail sale. Perhaps MicroImage could be the exclusive distributor.
Old 08-21-2009, 11:37 AM   #4
Yeah! What he said! Him first!
Old 08-21-2009, 11:44 AM   #5
MGargano
I was really starting to lose my patience with this yesterday thanks to my non-responsive system, but now I'm officially psyched again!
Old 08-21-2009, 12:19 PM   #6
Two down, two to go. The front right and rear right are now done...
Old 08-21-2009, 12:30 PM   #7
MGargano
Wooo! Halfway there!
Old 08-21-2009, 12:49 PM   #8
vten
great Jobs guy !! when the module is ready, let me know .... I'll take one for sure
Old 08-21-2009, 10:13 PM   #9
Complete Success!!!!
OK. After successfully emulating all four sensors, I moved from breadboard to a packaged prototype. For ease of handling the prototype, I mounted the switch to the module. For a production unit the switch input would be two more wires that could be connected to single pole switch (mounted to the dash, center console, etc.).
In the pictures below, you can see that the OC sensor connectors are not connected to the sensors. There are six wires connecting the bypass module to the OC ECU (four signal wires and two power wires). I tapped the harness at the sensor connectors, but one could actually make the connections, right at the OC ECU, eliminating the harness to the four sensors and making it far neater to install it under a race type seat.
Passenger airbag off:
And, on with a flick of the switch:
Old 08-21-2009, 11:57 PM   #10
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Waiting for head to explode , your a Genius
Old 08-22-2009, 12:13 AM   #11
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Dude your freaking great!!!
Old 08-22-2009, 01:13 AM   #12
MGargano
Does any of this effect the passenger's seat belt light and/or chime? For example, if you arm the airbag, does the seat belt chime go off if its not buckled?
Old 08-22-2009, 02:01 AM   #13
vten
I want it
Old 08-22-2009, 07:34 AM   #14
Yes. It is just like a person sitting there, so if you arm it and the seat belt is not latched the seat belt light comes on. In the pics, I had the passenger seat belt clicked. You really wouldn't want to arm it unless you actually had a passenger, to avoid an unnecessary popping of an expensive airbag, which also results in the upper dash having to be replaced.
Old 08-22-2009, 10:13 AM   #15
MGargano
Ok gotcha.
Old 08-22-2009, 06:02 PM   #16
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
So the plug (connector ) under the seat , how many wires do you have going to it .
My seat has 2 , and i don't have side airbags
Old 08-22-2009, 08:06 PM   #17
The OC ECU is the module attached to the bottom of the seat and has two connectors. One goes to the SRS ECU and the other goes to the fours OC sensors (gray 12 wire connector). My module taps that gray connector using six of the 12 wires.
Old 08-24-2009, 03:47 PM   #18
I received the Eggo Waffle box today (and it was lacking waffles). I did a quick test of your OC ECU and it is fine, which means that the issue is either with one of the sensors or a wire. I'll check it out tonight to find out for sure. Either way, it won't really matter, as I'll be shipping it back to you with one of my sensor bypass modules.
Do you want me to clip the harness off and tie it directly to the module, to keep things neat under your seat? (I'll ship back the rest of the harness with the sensor connectors).
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
