Old 03-24-2013, 03:29 AM   #1
japle
japle's Avatar
Drives: Vitz S 2007 LB
I recently sourced a keyless systems from singapore that cost bout 600 singaporean dollars. Now if i could just find that darn email.
Aha! Its singtech systems, anyone heard or actually used it before? If not i am going to be the test subject.
japle is offline   Reply With Quote
Old 11-04-2013, 03:52 AM   #2
Wishy
Drives: 08 Yaris
Hi all,
I seem to be having some troubles with my drivers door (Factory) key-less entry.
It's an 08 2 door hatch, when ever I use the remote it will lock or unlock the passenger and hatch doors but nothing happens in the drivers door. Can't hear it do anything inside the door.
I tried the procedure posted by CTScott and it didn't fix, Dome fuse is fine which I expected.
I can use the key to enter, but I'm super lazy and I'm starting to get over it and the dealership just wants to take my money.
Any help appreciated.
Wishy is offline   Reply With Quote
Old 11-04-2013, 05:56 AM   #3
Originally Posted by Wishy View Post
Hi all,
In your case with just that one door not working, you are looking at either a bad lock actuator or a damaged wire leading to it.
Old 11-04-2014, 11:59 AM   #4
finnpoulsen
Drives: yaris 2sz-fe
Thanks a million CTScoot!
Had to go through the procedure a couple of times until i realized that the door had to stay open between some of the steps
finnpoulsen is offline   Reply With Quote
Old 04-19-2015, 01:19 PM   #5
nortonfb
Drives: 2007
This may help and here is a recall on that model.
http://www-odi.nhtsa.dot.gov/acms/cs...E045-5133P.pdf
nortonfb is offline   Reply With Quote
Old 05-22-2015, 11:42 PM   #6
island_Vitz
island_Vitz's Avatar
Drives: 2010 Vitz 9AE
nvm
island_Vitz is offline   Reply With Quote
Old 05-11-2025, 10:13 AM   #7
Clintondmb
Drives: '08 3DrLB.
Had this happen recently. Ended up pulling the battery cable and that corrected the issue. Probably the airbag recall was the last time the cable was taken loose about eight years ago. I have a ten year old optima in there.
Clintondmb is offline   Reply With Quote
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
Help! Keyless entry on a 2007 liftback?! sd_007 DIY / Maintenance / Service 4 05-28-2009 04:01 PM
keyless entry? / security? mem In Car Entertainment + Electronics (audio / video / alarm) 8 10-22-2008 01:29 AM
Aftermarket Keyless Entry - How does it affect the Warranty? aerock19 In Car Entertainment + Electronics (audio / video / alarm) 7 09-07-2007 02:11 PM
I want keyless entry!!! Lillydot General Yaris / Vitz Discussion 7 03-20-2007 10:46 PM
