Scubie Du
Drives: '10 SWP STi/'09 Escalade Join Date: Nov 2006
important question about 18's on a yaris (need some help)
Hi every body
I'm planning to buy some 18x7.5" Wheels for my hatchback Yaris i heared that the Yaris come along with TRD 18*7.5"wheels so I think there is no problem with the size but what about the offset the wheels that i wanna buy are +40 and here are some info. about the wheels ====================== 4 X Incubus Black Wheels Suit almosy all 4 & 5 Stud Cars Size 18 X 7.5 Inch Chrome Nuts Chrome Valves Offset +40 PCDs Available 4/100, 4/114, 5 x100, 5 x 114, 5 x 120 Suit Cars Such as: Lancer, Corolla, Civic, CRX, Commodore, AU, BA and much more 4 x Brand New Kumho Tyres, size to suit your car. ====================== so do they fit my car or no (without modification) and if they do fit what tire size do you recommend for the yaris need some advice from you waiting for your replies regards, Ashraf |
G'day
I'm using 18x7.5 on mine, with a 42mm offset. Tires are 215/35 I found there was a tiny bit of rubbing inside the wheel well at full lock, so you could do with a slightly wider stance.
#3 | |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
I'am on 35 40 may rub if you drop it (i have a sedan with the TRD 18' ans ther is no rubbing
I Drive a 129whp Yaris ;) |
Actually I just realized something, when they put in the new front brakes it spaced out the front wheels a little, and there's no more full-lock rubbing
#5 | |
50% borikén
Drives: 06 Mazda5, 90 240sx Join Date: Nov 2006
Scubie Du
i'm not very experienced in the wheels issue
(so you could do with a slightly wider stance) what do u mean by stance? so what do u recommend that i do? |
50% borikén
I'm no good at explaining stuff, so check out this link instead.wheel tech
#8 | |
A wider stance would mean a lower offset, but I may be mistaken, always get confused by that
#9 | |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
Scubie Du
thank u for your advice
but what about the offset is it ok to be +40? see ya |
der Zeck
I am running the stock +38 offset and I am running a 7 inch wide wheel and I am fine.... +40 will move the wheel inward 2 mm, which would look better on a 7.5in wide wheel... you should have no problems at all
Scubie Du
thank u black yaris for u r useful advice
and thank u guys also for trying to help me with the wheels see ya |
I have 215/40/18 and the same problem that etimago had. It's rubbing a little in a full lock. I had 225 tires in the back and rub some times. Maybe is better 205/35/18 to avoid problems. Because of some roads here in Puerto RIco is why I'am using 215/40/18. About the offset, sorry I don't now mine.
#14 | |
der Zeck
#15 |
This may sound stupid but my wheel / tire combo is WAY over stock - Im running a +40 offset on the wheels and 225/30/20 tire. I have full-lock rub (Ill be posting some pics later) If your going to run 18's with +38 offset and use a 215 tire with 30-35 series rubber you should be good. I have small amounts of rub on large bumps but thats probably due to the 80lbs of stereo in the back and having the whole family in the car (stock suspension doesnt help either)
http://www.cardomain.com/ride/2336679 |
#16 | |
der Zeck
#17 |
Ok Black Yaris, using 18 rims, what size of tire it's going to be near stock size. Thanks for your help. Ohh by the way I really don't understand the offset thing
#18 |
der Zeck
18's closest to stock would be a 225-30-18 on a 18X7.5 wheel with a +38 offset... off set determines how far in or out the hub mounts, in referance to the center of the wheel..... if the hub is dead center is is a 0 offset - offset set the hub deeper in the wheel and + more shallower.....
| Question on Yaris wheels | featherz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 10-17-2006 10:27 PM |
