Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
'09 Yaris
My liftback w/ manual just started this in the last month and it's very intermittent. The first time I noticed it was when it was raining so I thought that had something to do with it but I've noticed it when the engine/transmission is cold or warm and when the weather is wet or dry.
:( S.R. |
Reluctantly Crouched...
Drives: 2008 Yaris HB M/T Join Date: Oct 2008
I agree with the previous posts that this seems to be related to clutch-engagement timing and rpm's rather than a design or clutch flaw. I've had no problems in either gear in 16,000 miles.
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
to avoid the shudder i just gun it in 1st gear and try not to even use reverse if possible. like others have said, it does seem that 1st shudders a bit less when the car has had time to warm up but doesn't help the shudder in reverse.
![]() I crush you like tiny clown car, because you are clown, yes? |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
I don't get the shudder but Yaris's 1st and reverse are horrible IMO, 1st especially is really touchy. OK, maybe not horrible but not the greatest.
To engage smoothly in 1st, I find that I need to give it a little more gas than I would in another car. |
#6 | ||
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
It also helps to make sure the car is at a dead stop before throwing it in reverse. Puts less resistance on the clutch and avoids the embarrassing scraping sound
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
Drives: yw calls me douche and racist. Join Date: Aug 2007
Doesn't make sense though. The revs jump to the same point on the RPM gauge. Still shudders when its cold, and stops when its warm.
#8 | |
![]() ![]() ![]() Drives: '07 Yaris Sedan/'03 Protege Join Date: Oct 2008
The OP never said it only happened when it was cold, at least not that I saw. That leads me to believe it's driver error, not a component flaw. |
#9 | |
Thats assuming hes a bad driver, which you couldn't possibly know for fact. |
Joey
Like I said, drop the clutch much more slowly
I'm sure alot of other manual cars have the same issue, just like the sluggishness before the engine warms up
![]() Drives: 2010 Yaris 5dr LB Manual Join Date: Oct 2009
I noticed the same thing in my 2008 5speed Sedan, more so in reverse. I had to let off the clutch very slowly and really give it some gas to reverse w/o the car shaking and jerking. So really, I had to reverse with some speed, which isn't always possible when backing up. I just traded the sedan in for a 2010 5dr 5speed and starting off in 1st and reverse is much more smooth, as is shifting in general. I don't know if it's something Toyota improved since 08 & 09 but I am pleasantly surprised.
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
Happens in first but not in reverse. I usually just throw the clutch back towards the floor, jam the gas, and release much faster
![]() problem solved |
DARK PHASE OF THE MOON
Drives: 07 liftback Join Date: Apr 2009
If you are used to driving a 5 speed, it goes away just as quickly as you can learn to properly feather the Yaris' clutch
#14 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
my car is a pain to put in reverse, very unforgiving compared to any other gear; even at complete standstill it sometimes won't drop into gear properly, or worse if I'm rolling even an inch you hear it scratch and chatter as it engages. once it is engaged, it's fine and dandy and feels solid.
in the morning, my first gear is very loosey goosey and does not grab well, but what I think the OP is experiencing is that the clutch not being fully engaged into position, and what's happening is probably slipping as you rev out expecting it to catch. I ride first gear partially engaged for a second or two, which seems to help (and I don't rev out hard unless I know it's fully engaged, and you'll know because if it isn't it will chatter and shudder like that or you'll have seemingly less pickup and smell hell for the next few minutes). |
#15 | |
try putting it in 1st gear first, then going to reverse. |
#16 |
Only Happy When it Rains
I just hate the Yaris' clutch. Way too light and just horrible. You definately need to rev it more in first gear than any other car i've driven. I can't tell you how many times I've stalled it... grrr.
Colin Chapman disciple |
#17 |
she was an American girl
See, I never have a problem with stalling or anything. I am kinda known for flying in my Yaris... even from a dead stop. I get a shudder, feels like tire shudder or maybe even a rev limiter kicking in, but I'm not high enough to have that!!! I usually let my foot off the gas for a quick second and everything 'catches up' and evens out. I've had the car for more than 34k miles. Did it from day 1, still does it now. Don't know if that is the same problem that any of you guys have been having.
![]() Overall, doesn't bother me too much though. And I guess I am a lucky one... no probs in reverse. |
#18 |
![]() ![]() Drives: Black 5-Spd Sedan S Join Date: Aug 2009
I know the reverse shudder you guys are talking about, but this is totally different :)
I'm not sure how to better describe it, but I haven't had it happen at all now that I learned how to drive Yaris-Stick-Shift®, It's re-assuring to see so many people notice this at least sometimes! |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| 1st Gear Revs... | Masteraal | General Yaris / Vitz Discussion | 9 | 09-30-2007 10:22 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
| clicking into first gear | tekmoe | General Yaris / Vitz Discussion | 9 | 11-01-2006 02:44 AM |
