#1 | |
![]() ![]() ![]() Drives: Big Yellow Join Date: May 2009
![]() Drives: 2008 Yaris Hatch Join Date: Oct 2009
Clutches are designed with slippage in mind. If that is not built into the car then the designers weren't thinking far enough ahead.
Dumping the clutch is a shock to the rest of the drive train. The initial (breakaway) torque is much higher and stresses the components down the line. When initial torque is low (ie. when you feather the clutch) the stress on the passive drive train components is much lower. You should really be trying to make your ride as smooth as possible, since that is what modern passenger vehicles are designed for. That means feathering the clutch into 1st, probably 2nd, and also probably 3rd. 4th and 5th gears tend to be at such a high ratio (>1) that they don't put much load on the engine. All that aside, my 3rd gear requires a bit more force to shift into than all of the other gears (except reverse.) 1, 2, 4, and 5 pretty much slide right in, but 3rd requires more of a push to put it there. I bought the car used, so I'm hoping that it's just a quirk and not something that the previous owner did. |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
Hey, Wattz, welcome to the forum!!
I bought mine used, too, with 55K miles; 2d, 3rd, 4th and 5th are PERFECT (knock on wood). First is a pain, real stiff, especially first thing in the morning. Here is an article on clutch control in Wikipedia, in case anyone is interested. http://en.wikipedia.org/wiki/Clutch_control |
![]() Drives: 07 Yaris Hatch, Manual Join Date: Nov 2009
I had the same clutch shutter develop at around 17k miles. Dealer "couldn't reproduce the issue". 20k miles, shutter went away, turned into slippage when under throttle alone. Brought it into the dealer ready for a big battle (they were much better about it this time around). Turns out there is a faulty seal in the tranny which leaks oil into the bell housing - clutch and flywheel destroyed. Toyota knows about this issue, the replacement seal is a different one (and requires tranny to be pulled apart to replace). Clutch shuttering is not normal, bring your car in and make them fix it. I just hope the new seal holds up, its almost a $2k repair bill at the dealership if out of warranty
#5 | |
![]() ![]() Drives: Black 5-Spd Sedan S Join Date: Aug 2009
Thank you for the heads up
#6 | |
![]() ![]() Drives: 2007 LB Join Date: Jan 2009
#7 | |
nope, it seemed to be isolated in the bell housing - unfortunately means dopping the tranny to check. At first I thought it was just being difficult because of the varying throttle response, but then realized it was all clutch. The service manager had seen so few manuals, he was unaware of the issue. He heard about it after contacting some regional rep sorta person guy. When I got the car back, it felt more solid than when I first bought the car. New clutch engagement point was right at the floor, seemed a little weird, but felt like all the power was getting to the wheels. Now, a few weeks later, the engagement point is quite a bit higher and feels like a more "normal" engagement point. Not sure if this shift is normal break in for a new clutch or if its a bad sign of things to come. I sure hope it's the former. ooon look, a vomit emoticon, neaT ![]() EDIT: Forgot to mention, this was a definite clutch shudder with throttle applied, not the shaking one feels when bogging the engine down by not providing enough throttle Last edited by fastscutr; 11-13-2009 at 12:40 PM. |
Yep, exactly, this is what I think I had a hard time explaining in this thread lol, you know what I'm talking about!
Just give it the full beans it won't shudder!
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
Burnt clutch, warped pressure plate....this studdering can happen....often caused by new drivers of manual trannys, or anyone that does not know how to shift properly.
I've never had any issues with any of the 3 manual transmission toyota's I've owned my 87 mr2 is still good. I put 65k on my first gen xB and 6k on my yaris. They all have performed well without incident.
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
Sometimes happens to me but only when it’s cold, and if I release the clutch too quick I get the shudder in reverse is even trickier, but when the engine is warm it doesn't happen to me, I try to drive it softly while it warms up and it happens much less
I’ve driven all my life stick, this where my cars in the past and I experienced it in all of them 2007 Yaris LB (current) 2003 Nissan 350Z 2005 Scion TC 2001 Daewoo Lanos Sport 1989 Honda Accord 2 DR 1996 Renault Twingo For the Yaris and The Scion TC I had to re adjust to the clutch. It took me like a month to feel comfortable with the clutch. Is also good to mention that this feeling sometimes can be confused with a flywheel that needs must be resurfaced or replaced, this can happen due to exesive heat when clutch is not used properly or abused. |
#14 |
clutch is now starting to slip for me again after about 3k miles since last replaced under warrantee. Occasionally getting locked out of 5th (don't even feel the shift gate when that happens). Like the other time, dealer won't do anything till it gets real bad and destroys the flywheel... It is still under warranty, but no longer fits my needs as reliable transportation - think its time for a new car... (2010 Subaru WRX :D )
Can't believe I have a British car that has proven to be more reliable (powered by Toyota engine/tranny though) ;P I wish you all the best of luck in getting a final long term solution to this problem |
#15 |
Drives: yw calls me douche and racist. Join Date: Aug 2007
So I installed the TRD roll stopper mount. Shudder went away.
#16 |
My yaris has over 100,000km (~60,000mi) on it now, and does this in 1st when it is cold... only if you let it out either too fast, or dont give it enough gas.
The car is on its orig. clutch, so i doubt it causes any long term reliability issues. |
#17 |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
i find the same problem. i have learned to master 1st but revers....fml man, i back up on my drive way (up hill) and unless i'm riding clutch hard and RPMs atleast 1500 or doing 40km in reverse it looks, feels and sounds very bad.
also with the gearing ratio i find its awkward to slow down and take off again but not stop. too fast for 1st, too slow for second...... any advice? (other then learn how to drive, lol)
#18 |
![]() ![]() ![]() Drives: Yaris Join Date: Apr 2009
I definitely find this to be evident! I usually just shift into second and give gas but the car really doesn't want to go into 1st gear unless stopped.
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| 1st Gear Revs... | Masteraal | General Yaris / Vitz Discussion | 9 | 09-30-2007 10:22 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
| clicking into first gear | tekmoe | General Yaris / Vitz Discussion | 9 | 11-01-2006 02:44 AM |
