| View Poll Results: Would you buy one? | |||
| No |
5 | 5.10% |
| Yes (for $75) |
46 | 46.94% |
| Yes (but it would have to be less than $75) |
7 | 7.14% |
| Yes (but I still want it to also display the time) |
40 | 40.82% |
| Voters: 98. You may not vote on this poll | |||
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
I'm way excited for these even though my yaris has gone to yaris heaven lol.
$10.25/hr frying chicken
so cool!
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
Wow,this is probably the coolest idea I have seen done in years for any car.....you sir are a Saint......finally a tach for the car....yes.
CTScott is tha MAN!!! Can't wait. Thanks again for doing this.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
Our off road vehicle
Drives: 2009 Yaris 3dr Join Date: Apr 2009
we all owe Scott a big THANKS!
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
This looks awesome I really want one! Great Job CTScott!!!
I'm impressed!
![]() I want it!
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
How does the unit install to the car Scott? Does it read from the OBD2 port?
#9 | |
It communicates with the ECM via the CAN bus, but it grabs it at the cluster, so you can still have a scangauge or other device use the OBD port. |
just too cool for words
And what about clusters with the clock on the other side? Will compatibility be similar?
I'm still trying to figure that out. The ones with the clock on the right, are either LBs with the cluster with the tach, or are sedans. In both of those cases the odometer and fuel gauge are part of that display, so I can't really replace it. For those, I am trying to figure out another mounting place that would still have the OEM integrated look.
#13 | |
1) Integrated as a clock in a small unit 2) Integrated via a single DIM unit like a scanguage? Just an idea! Keep up the great work Scott. |
I like that it will be able to maintain the stock, orange color.
I do have one question ... I noticed that in the last pics, the cluster brightnees is turned up to what seems to be to max but the modual seems a bit dimmer than the other displays. If you were to turn the brightness down a bit like at night, will the new modual still be as visible as the rest of the cluster? Will the new modual indeed be able to be dimmed along with the cluster? Last edited by RedRide; 01-10-2010 at 11:37 AM. |
#15 | |
Right now I am not using the dimmer feed, so the display would be the same brightness with headlights on or off. Now that it is in the car, that's one thing I'll experiment with to determine if dimming is needed (I have a feeling it won't, as the backlit LCD is not as bright as the speedometer). |
#16 | |
Since it is "not as bright...... Often in bright, anbient light, the stock gage cluster is hard to read. Is this also a prblem with the new modual? Perhaps abient light does not effect it as much? Is there an easy way to conect it to the dimmer feed? |
Is there still going to be a sedan version?
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Question: Can the temperature display read in celsius as well as farenheit?
| in dash clock as tach? | Cosmonaut | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 07-12-2010 11:27 AM |
| digital tach, 52mm, preferably blue leds | severous01 | Cosmetic Modifications (Exterior/Interior) | 5 | 05-15-2009 10:58 AM |
| Digital Tach | nqd | Performance Modifications | 4 | 05-17-2007 12:04 PM |
