Old 11-29-2006, 07:40 AM   #1
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
sweetness, as for the MAF i was thinking something like plastic weld and a "nicely" made bracket, just a thought.
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 11-29-2006, 08:25 AM   #2
vodkalush
I drive a yarrrris
vodkalush's Avatar
oh yeah, waht length and diam is the PVC you used?
will work for parts
Old 11-29-2006, 03:37 PM   #3
spkrman
Drives: 1
the PVC is 3 ID, and approx 4" long.
Old 11-29-2006, 05:36 PM   #4
ProMotionTuning
ProMotionTuning's Avatar
Drives: Scion tC
Send a message via AIM to ProMotionTuning
spkrman:
Just some advice for you. I have spent many hours on a dyno doing R&D on intake systems. First of all.... Do not use 3" piping on the car... Very bad idea and you COULD throw a CEL or even worse damage the MAF itself. Weapon R and AEM wont use pipes bigger then 2.5" on these motors cause of that. Make sure that MAF is sealed 100% or you will have air leaks which will result in unmetered air and your car could run lean at High RPMs. As far as using 93 octane, definitely no need and you shouldnt be seeing any improvement at all. In fact the damage it is doing to the internals of your car could be worse then the HP you think you have gained.... Your spark plugs from the factory are not rated for the 93 octane and without boost, I am sure you are just helping clog your cats before their time :) Not knocking you just offering advice before your final design!
Pro-Motion Tuning, LLC
20 Commerce Pkwy # 101
Fredericksburg, VA 22406
1.877.724.6682
ProMotionTuning.Com
ProMotionTuning is offline   Reply With Quote
Old 11-29-2006, 07:27 PM   #5
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
Originally Posted by ProMotionTuning
spkrman:
I havent had a whole lot of experience building intakes but hope maybe you could clarify that and answer a couple of questions.
Is 3" considered a faux-pas because the throttle body bore dia. or actual flow characteristics? Doesnt the 3" just imply the flow could be increased dramatically over stock?
If 3" is bad what about guys who just bolt a cone filter straight to the throttle body?
Obviously if everything has been made in 2.5" dia thats whats been dyno'd but has anyone even tried to dyno a 3"?
The whole intake setup actually seems really similar to the old TPI setup on the old LS1. (Long runner intake ater throttle body, little to none before).
mikeukrainetz is offline   Reply With Quote
Old 11-30-2006, 01:52 AM   #6
spkrman
Drives: 1
spkrman:
The gas definitely made a difference, im not sure if it was bad gas before, or what... but it definitely made a difference :). If not these plugs, what plugs would I use for 93? Would there possibly be an increase in mileage?
The MAF is sealed as far as I can tell, and yea, it has/is throwing a CEL :)
What other options do I have here? I dont know where to get 2.5" PVC, I see 2.5" metal piping, but I have no way of working with it.
It looks like this kit may fit: http://cgi.ebay.com/ebaymotors/TOYOT...mZ220054255738
Its not loading for me now, but from the smaller pic it looks like it would bolt right in?
Old 11-29-2006, 05:46 PM   #7
vodkalush
I drive a yarrrris
vodkalush's Avatar
haha, i'm an a$$. you have the tube size listed like 4x's in the orig post. my bad.
will work for parts
Old 12-03-2006, 04:54 AM   #8
spkrman
Drives: 1
you guys think that might fit? Looks like the filter comes back up when it should stay straight, other than that I think it would work great.
Could also just wait on ebay for the piping, shouldnt be TOO long until its out? :)
Old 12-03-2006, 08:44 AM   #9
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Be carefull with any intake with the hose before the MAF sensor... read up/search over on the Scion boards as to why exactly.. but it was talked about at length.
Otherwise, looks like a better fit then most xa/xb short rams would...
Old 12-04-2006, 07:51 PM   #10
Chris07LB
Chris07LB's Avatar
Alright, to clear things up a bit......
Seems if the EGR tube is between the filter and MAF, the intake manufacture includes an inline one way sealed filter, to splice into the provided tubing going from the intake pipe, to the engine.
Reason for this, is to keep the gases in the EGR from contaminating the air being sucked into the filter, and messing with the MAF Sensor.
So turns out, as long as the EGR is between the filter and MAF, it should have an included inline one way sealed filter.
If the EGR is after the MAF and before the Throttle Body, then even better.
So looks like the green intake you posted up, would be worth a shot afterall, as long as the piping is the correct I.D.!
EDIT the piping is 3", so going back to that other home made metal piping someone used before, the car didnt idle right, or run right..
Old 12-03-2006, 07:40 PM   #11
spkrman
Drives: 1
the hose is after the MAF there, correct?
Old 12-03-2006, 07:50 PM   #12
Chris07LB
Chris07LB's Avatar
No, its not.
Stock throttle body > EGR Hose > MAF sensor > Filter.... is how the eBay intake is..
Old 12-03-2006, 10:46 PM   #13
spkrman
Drives: 1
Originally Posted by Chris07LB View Post
No, its not.
well, teh flow of air is the other way....
But either way, the EGR hoseshould be on the OTHER side of the MAF, NOT like the ebay intake, correct?
Is stock not the same exact setup?
Old 12-04-2006, 03:36 AM   #14
Chris07LB
Chris07LB's Avatar
Correct.. duh on my part.
You want the EGR tube between the MAF and Filter, acording to what Ive read from the Scion fellas..
Clear enough now?
Old 12-04-2006, 06:23 PM   #15
spkrman
Drives: 1
Clear enough now?
are there any aftermarkets that do this?
Old 12-03-2006, 08:07 PM   #16
vodkalush
I drive a yarrrris
vodkalush's Avatar
deal with my n00bness in that matter; but what is an EGR hose?
will work for parts
Old 12-03-2006, 08:10 PM   #17
johnnyfive
johnnyfive's Avatar
EGR = exhaust gas reciculation
http://en.wikipedia.org/wiki/EGR_valve
johnnyfive is offline   Reply With Quote
Old 12-04-2006, 11:33 AM   #18
vodkalush
I drive a yarrrris
vodkalush's Avatar
so, if I decide to go ahead and attempt make an intake, would it be wise of me to put/make a egr tube? or will it not really make a difference?
will work for parts
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
PICS OF TRD INTAKE INSTALLED! elsteverino889 Performance Modifications 9 03-03-2007 04:12 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
K&N Is looking for 2007 Yaris for Intake Development. Knfilters Performance Modifications 9 06-28-2006 04:34 PM
TEIN Basic coilovers C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 06-26-2006 01:57 AM
