Old 01-08-2007, 10:02 PM   #1
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
whats the distance between the beginning of the filter too the clamp on the engine? aka how long is your tubing? and also the distance between the filter and MAF and MAF to engin?!?!
so to try and make sense of the post if you would be so kind as to give me some distances between the following:
Engine - ERG Tube
ERG - MAF
MAF - Filter
will work for parts
vodkalush is offline   Reply With Quote
Old 01-09-2007, 06:03 AM   #2
spkrman
Drives: 1
Engine - ERG Tube
ERG - MAF
MAF - Filter
all tubing is stock, the filter is 3" away from MAF.
and CEL is back on... damit
screw the dam MAF... its gonna make me buy an ebay intake :(
Old 01-09-2007, 08:52 AM   #3
vodkalush
I drive a yarrrris
vodkalush's Avatar
ahhh, I thought you where still rocking the PVC intake...
I didnt think that you'd be able to get a good seal from the aftermarket filter to the stock intake tubing...
will work for parts
Old 01-09-2007, 09:34 AM   #4
spkrman
Drives: 1
stock tube, pvc, filter.
now its stock tube, rubber hose, filter.
Old 01-09-2007, 10:16 AM   #5
vodkalush
I drive a yarrrris
vodkalush's Avatar
ummm, I still think that the issue has somthing to do with tube lenght and the force of the air hitting/passing the MAF... I'll add an extender between my MAF and Filter and see if it makes a diff. if anything I will be pulling colder air in.
will work for parts
Old 01-09-2007, 10:45 AM   #6
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
how are you mounting your MAF in these home grown intake's?
everything NEEDS to be air tight... duck tape and silicone should not be used to help the seal.
Old 01-09-2007, 11:48 AM   #7
vodkalush
I drive a yarrrris
vodkalush's Avatar
no, I'm using an intake "kit" type thing, sort of similar to what u'd put together (if i hadn't already bought the stuff i'm using now i would have just gotten the stuff from you...); I may just need to tighten everything some more..
will work for parts
Old 01-10-2007, 02:22 AM   #8
spkrman
Drives: 1
i'll throw on the NST pulley, see what happens, and then go back to the stocker until a cheapy tube pops up on ebay.
Old 01-10-2007, 03:29 PM   #9
Billstein
Whew Who..
Billstein's Avatar
Drives: 2 Yaris Hatchs and Tacoma
Little something I picked up.
"HERS"2007 Yaris Hatch BlazzingBlue Power everything Sirius Radio FullSyn Oil 50% tint windshild35% front 5% rear Keyless Entry Alum TRD Shift Knob
TRD Exh Tip 17" racing harts/Falkins TRD Cold Air Intake
"HIS"2007 Yaris Hatch MedSilverMetallicPower PQ Package 17" Wheels Spoiler TRD ExhTipStiletto100 Radio Armrest 50% tint windshild 35% front windows 5% rear Aluminum TRD Shift Knob Keyless Entry VIP Alarm TRD Cold Air Intake
Billstein is offline   Reply With Quote
Old 01-13-2007, 06:16 AM   #10
mcdaddy
mcdaddy's Avatar
Drives: Yaris 2006, 2NZFE 1.3L
patience is the key to make your DIY MAF mounting done!!
I decided to use this bling type filter coz i'm planning for CAI during summer.. I don't have all the fittings so I'll just stick to short ram type for now.
Here is what i did.. No CEL lit up..
btw, they are available at $10 each for those interested.. hahaha..
mcdaddy is offline   Reply With Quote
Old 01-13-2007, 09:23 AM   #11
Chris07LB
Chris07LB's Avatar
You have some sort of support bracket, or is the filter just laying there, bouncing around while driving?
Old 01-13-2007, 10:12 AM   #12
spkrman
Drives: 1
Where can I get one??? PM if need be :)
what the heck is that thing, btw?
Its worth $10, from there I should be able to get a shop to bend up some piping
Old 02-26-2007, 06:27 AM   #13
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Bro,
I need one for my Blue Yaris 07..PM me please
du2efs
ricepower is offline   Reply With Quote
Old 01-14-2007, 08:02 AM   #14
spkrman
Drives: 1
closer look... seems like regular rubber pipe, heated to have that flat space.
Old 01-14-2007, 08:47 AM   #15
Chris07LB
Chris07LB's Avatar
Doubt it. Looks like a MAF holder that you can buy... few places around with our I.D., just have to look.
Old 01-15-2007, 04:29 AM   #16
mcdaddy
mcdaddy's Avatar
Chris07LB – the end of the filter is stack just below the headlight housing.. though they aren’t finish yet, like I said I’m working on CAI & would put a bracket to hold the thing in place.
Spkrman – I’m just kidding.. I’m not selling this thing coz’ I know you can do it yourselves.. guess what? This idea is originally came form your first post .. it’s kinda ghetto!! It’s all made of a Hot Water PVC pipe with the reducers on it.. try again & you’ll see what I mean.. it’s worth to try.. get a vernier caliper to get things done..
* my next project is to look for a stainless steel pipe & replace the whole thing from throttle body to the filter..
Old 01-15-2007, 08:18 AM   #17
vodkalush
I drive a yarrrris
vodkalush's Avatar
mcdaddy have you/are you getting the CEL?
I changed my setup and it worked great for the first 40 miles (vrs's before where the CEL would come on after less then 10miles)... then after letting the car cool down (aka parked) I started her up again and I got the CEL.....
will work for parts
Old 01-16-2007, 01:16 AM   #18
mcdaddy
mcdaddy's Avatar
so far I did'nt get CEL on the dashboard but I'm keeping an eye on it.. I'll let you know when it comes up ..Anyway, I'm still looking for a stainless steel & will replace my current MAF mounting.
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
PICS OF TRD INTAKE INSTALLED! elsteverino889 Performance Modifications 9 03-03-2007 04:12 PM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
K&N Is looking for 2007 Yaris for Intake Development. Knfilters Performance Modifications 9 06-28-2006 04:34 PM
TEIN Basic coilovers C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 06-26-2006 01:57 AM
