![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
Use a digital gauge and check the tire pressure. With a wide low profile tire you might not even notice it being toward the low side. Try it for a week with 32psi (if not already there), and then a second week at something closer to the max sidewall rating.
Consider an ecometer or scangauge II. You don't think you are driving hard, but the near instant feedback may tell you otherwise. With some practice you can get used to coasting with the terain along your route and see your trip average Mpgs start going back up. Also as the weather gets cooler you will drop a couple Mpg. Look at your route and see if you can find a way to be on the side roads a few extra minutes before hitting the freeway in the morning. For the winter consider blocking the lower grille below the bumper. |
#2 | |
Scrubble with a poke.
Drives: 2009 Yaris LB Join Date: Jul 2009
Subarus use a program called open ECU where all you need is the free software, a Tactrix cable and a laptop to see everything and tune. My tuner used it reliably to tune my car at 21psi with 565cc injectors and still keep the IDC at around 75% and optimal AFRs.
"If you cannot find truth right where you are, where else do you expect to find it?" Dogen |
| Sedan better gas mileage than LB? 5 month gas chart included | flint_mica_manual | General Yaris / Vitz Discussion | 24 | 03-09-2009 09:24 AM |
| Economics of Price Gouging and Gas shortages | GeneW | General Yaris / Vitz Discussion | 1 | 10-31-2008 05:20 PM |
| Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 01:32 AM |
| Free gas for any vehicle. | ketel0ne | General Yaris / Vitz Discussion | 4 | 09-19-2006 09:07 AM |
