Old 01-04-2010, 03:56 PM   #1
upgradedyaris
Drives: Yaris & Supra
I got my cruise for 71 bucks from dealer today! 22 for the wire. :)
So, this works automatically once you hook this all up!?!
Duane
upgradedyaris is offline   Reply With Quote
Old 01-07-2010, 02:27 PM   #2
EricGSXR
EricGSXR's Avatar
Drives: Yaris NSP90 1.33 TTE
Is the Euro Yaris prepared for a factory cruise control and will it work?
Would be great because I've got the cruise control stick already
EricGSXR is offline   Reply With Quote
Old 01-07-2010, 03:51 PM   #3
So far we've found that European and Australian ECMs don't support cruise control.
Old 01-07-2010, 02:30 PM   #4
EricGSXR
EricGSXR's Avatar
Can somebody make a picture of this part (45184-52130-B0) because here in Holland we don't know this part number. I've looked today on EPC and I didn't find the cover with a hole in it
Old 01-07-2010, 04:07 PM   #5
EricGSXR
EricGSXR's Avatar
That's a pity.
That's the reason why it's so expensive to upgrade your Yaris with cruise control here, it will cost 850 bucks.
Old 01-09-2010, 07:29 PM   #6
birdman
Drives: '08 Blazing Blue Yaris LB
That was a great presentation. I think I'll install one in mine soon.
birdman is offline   Reply With Quote
Old 01-14-2010, 06:18 PM   #7
upgradedyaris
Added note:
If you plan to purchase the OEM rear panel of wheel so you don't have to cut the hole to fit the cruise stalk, you will need to remove steering wheel. It is better IMO since you have a factory look, AND, it's merrily a bolt away anyway. :)
Duane
Old 02-02-2010, 05:24 PM   #8
SmartYaris
SmartYaris's Avatar
Drives: '09 Yaris 3dr auto, '08 Smart
I did mine today. It was $112 from the dealer, down from when I originally mentioned Yaris and it was $109 for the switch alone then the screws and wire were extra totaling $156. I changed it from Yaris to Corolla and the price dropped and the kit had everything in it.
Drilled a hole in the lower piece then went to Lowes and bought a hole grommet to cover the edge where I didn't drill it perfect. Looks and functions great. Thought the wife would scream about the money spent but instead she asked when I was going to add the power locks/windows.
SmartYaris is offline   Reply With Quote
Old 03-27-2010, 10:51 PM   #9
3toys
hamchk
Drives: 10 LB
Thanks PeteZNY for the instructions, did my new 2010 today and works great. Saved $$$, and did not have to go with aftermarket.
3toys is offline   Reply With Quote
Old 04-02-2010, 03:44 PM   #10
bribri
Drives: white stock yris
one small question
I understand that you connect the cruise control switch to where the horn was connected. Do you just leave the horn wire disconnected ?
BriBri
bribri is offline   Reply With Quote
Old 04-02-2010, 07:04 PM   #11
BriBri
If you buy the "Cruise Control Wire" from Toyota, it is a Y cable with 3 ends that connect to: The cruise stalk, the connector where the horn was plugged in, and the spade connector on the horn switch.
Old 04-03-2010, 08:06 PM   #12
bribri
thanks
Old 04-11-2010, 07:34 PM   #13
bribri
cruise control wire DIY?
toyota in Barrie Ontario canada, Jacksons toyota wants $60.00 for the cruise control wire. I this wire something I can fabricate myself. I've never actually seen it.
Thanks bri
Old 04-11-2010, 08:21 PM   #14
Thanks bri
Here's mine. I bought a Scion TC steering wheel with the cruise stalk and the Scion CC wire for $45 off ebay. The steering wheel is of no use, but $45 for the stalk and cable was a good deal. (And, I can probably get $10 for the steering wheel, if I list it on ebay.)
The spiral cable end of the CC wire for the Scion was different because the Scion wheel has steering wheel radio controls. I was able to pop the two CC pins from the Scion spiral cable connector and stick them into 4 pin connector on my Yaris.
Old 04-21-2010, 07:29 PM   #15
bribri
I caved and the bought switch wire. 30 min install. Thanks everyone for this information.
I didn't disconnect the air bag to install. The only problem was the hole location which a sharp knife adjusted.
thanks again
Old 04-29-2010, 01:15 PM   #16
nawlinsprius
Drives: 2010 5drlb PP
done
installed the 4 parts from OP's list (wire, stalk, screws and steering wheel lower cover with premade hole) at the dealer in 30 minutes.
was afraid to install myself because of the airbag, but it did not have to be removed or disconnected.
it was free (they like me since i bought 3 toyotas lately) and the parts were ordered online for $130.
(2010 5dr LB)
works without any problems. good deal.
nawlinsprius is offline   Reply With Quote
Old 07-06-2010, 12:37 PM   #17
atebit
Drives: 07 Yaris Sedan
(2010 5dr LB)
Can someone explain how to do this without having to remove the airbag? It seems like you'd need to remove the airbag in order to get to the horn wire...not sure if you can get to the other connector by just removing the lower steering wheel cover cowling.
atebit is offline   Reply With Quote
Old 05-14-2010, 04:55 PM   #18
PhillyG
Drives: 2009 Yaris
im a little confused.. i want mine to be looking factory. but is there any one place online to buy all this instead of a dealer? just looking for a little cheaper is all.
PhillyG is offline   Reply With Quote
How difficult is it to install the aftermarket cruise control kit? grampi Performance Modifications 3 07-19-2007 08:06 AM
