Old 11-04-2009, 08:41 PM   #1
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Looks perfect to me. What did you use for cutting? I have a bolt cutter somewhere at home, do you think that would work? There is a metal strip inside the blade somewhere, isn't there?
fmicle is offline   Reply With Quote
Old 11-04-2009, 08:57 PM   #2
bladesmith6
Drives: 2007 yaris HB
Thanks guys, you will need a small flatblade screwdriver, wiss snips and a razor knife. You use the screwdriver to pop the end caps off and thats the hard part because you have to twist pretty hard but they will come off. Then take inner pcs apart(metal backer, plastic body and the rubber wiper) cut the metal pc with the snips, the plastic you can use the razor or a hacksaw blade, and rubber wiper with the razor, reassemble put a dab of adhesive inside each end cap and your good to go. You have to use a wiper with removable end pcs or I don't think this will work.
bladesmith6 is offline   Reply With Quote
Old 11-04-2009, 08:59 PM   #3
bladesmith6
oh and i think the rain x wiper works well. I also Aquapel the windshield to give myself a little extra help.
Old 11-04-2009, 09:11 PM   #4
Lafiro
Drives: 06 Yaris Sedan
Nice, maybe I will try this after winter, since I dont see the point in buying good wipers now that its getting cold.
BTW, GO YANKEES!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-08-2009, 06:28 PM   #5
MadMax
MadMax's Avatar
I just got a set of RainX blades and cut down a 16" one to 14" for my HB. It's on the car at the moment and fits nicely, but it was a real pain in the ass getting the caps back on.
I am letting the glue dry a bit more before I try them out (it's raining as we speak). They do look good, unfortunately it's hard to get good pics but here is my best try...
Cheers! M2
Old 11-09-2009, 03:26 PM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
mine do not have ANY space left for more than 13".
The reference book do say 14" on some and 13" on others though..
Heck, the reference book even says 24" on the drivers side. but 24" is too small for the sedan. It really needs 26"
Old 11-09-2009, 04:06 PM   #7
captainm27
Drives: 2008 Sedan A/T Silver
I also noticed that too...I've seen the 24" on certain reference books...,but it really indeed uses a 26". I wonder where the confusions come from. Could it be a year thing? I have a 2008 Sedan and it uses 14" and 26".
captainm27 is offline   Reply With Quote
Old 11-14-2009, 12:07 PM   #8
IllusionX
Impossible. The yaris sedan has been been larger since it came out in late 2006.
I don't believe you unless you put a ruler by your wiper and take a picture. lol
I am still using the OEM blades that came with the car... and it is 13", and no extra space to put anything longer...
Old 11-14-2009, 10:33 PM   #9
captainm27
lol, well, I don't have a ruler with me. But I'll take a picture of it for you. But for now, here's the exact same item on amazon that I bought at Advance Auto Parts, and had one of the employees install it for me. (yeah, I suck at installing wiper blades)
http://www.amazon.com/Trico-Products...8255854&sr=1-5
Old 11-16-2009, 10:41 PM   #10
IllusionX
I just noticed today my 26" wiper is shorter than my previous 26".
Old 11-16-2009, 11:04 PM   #11
captainm27
Huh....could it be some kind of miss reading on their side? Maybe they claim it's 26", but it's really 25"?
Old 11-17-2009, 07:29 PM   #12
IllusionX
I can assure you, my next set of wipers will NOT be viewmax wipers from waltmart. I don't like how the driver's side does not make good contact with the glass towards the top of the windshield.
michelin hydro edge wipers go for 15$ a piece at costco, even for the 26".
from the look of them, they can be cut down just like the rain-x. They may even be the exact same wipers.
My viewmax 26" was 20, and the 13 cost 15...
Old 11-25-2009, 07:50 PM   #13
Black Yaris
der Zeck
Black Yaris's Avatar
the reason you have some parts store say 13's and others 14's is because the OE size is 350mm (remember this is a Japanese car) which is 13.7795 inches long... so some round up and some round down
as for the drivers side is 650mm or 25.5906 inches... but no one makes a 25 inch blade
The OE blades off of a xD cost me about $50, about the same amount of money as any of the aftermarket replacements
and BTW inserts can be purchased at just about any autoparts store for $4-5 for a pair
Old 11-26-2009, 02:57 PM   #14
IllusionX
it is not.
hatchback takes 24 and 14 while the sedan takes 26 and 13. I don't care about the half an inch sticking in or out, the 2.5cm different is there on the 2 cars.
Old 02-12-2010, 10:25 AM   #15
jeff618
jeff618's Avatar
Drives: Mazda 3
Lightbulb
Why are there so many wiper threads on here??? LOL Ok...I just put this on another string but it totally applies here too...
OK...here's the ticket: As you probably know from reading this string, the Toyota Yaris' 14" passenger side replacement windshield wiper is very hard to find in the newer-style beam blades. The 12" rear is also very hard to find because its a special rear blade that fits the special rear arm.
After exhaustive research, I've only found one aftermarket set-up that works: 'Trico NeoForm Beam Blades' on the front (yes, they have a 14") and 'Trico Exact Fit Rear Integral Blade' on the rear. All of the above come with step-by-step, illustrated removal and replacement instructions - easy install. Got the whole set-up online.
First Time Caller, Long Time Listener, Great Topic, Love The Show...Thanks For Taking My Call
jeff618 is offline   Reply With Quote
Old 02-12-2010, 12:36 PM   #16
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Nice avatar.
DerFlosser is offline   Reply With Quote
Old 03-28-2010, 09:58 AM   #17
jeff618
jeff618's Avatar
Drives: Mazda 3
Arrow Take it if you want it...
As a follow-up to my post above, I just got an email from wipers123.com and there's a $15 rebate on NeoForms (including the 14") through 5/15/10. They also sent me an additional $5 instant coupon "springreturningcustomer" (orders over $30) not sure when it expires... I'm not ready to replace mine yet so take it if you want it!
Wiper blades .... Lafiro General Yaris / Vitz Discussion 81 02-02-2012 06:54 PM
Wiper Blades futdechenes General Yaris / Vitz Discussion 44 06-27-2010 11:08 AM
new pics thebarber Photo-Video-Media Gallery 19 08-27-2009 09:01 PM
What kind of wiper blades? buyah123 DIY / Maintenance / Service 9 11-25-2008 05:25 PM
