Old 12-09-2009, 03:06 AM   #1
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
What synthetic oil brands do you guys like to use?
Castrol EDGE
Old 12-09-2009, 06:38 AM   #2
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
I'm a big fan of Pennzoil Platinum. Returns great UOAs, is available almost everywhere, and is frequently on BOGO sales. What interval are you planning on using?
bearda is offline   Reply With Quote
Old 12-08-2009, 02:37 PM   #3
POORSHA
POORSHA's Avatar
Drives: 2008 LB
amsoil
POORSHA is offline   Reply With Quote
Old 12-08-2009, 08:57 PM   #4
severous01
i switched on my jeep at 175k miles. i had a valve cover gasket leak but that's only cuz dirt was actually clogging the leak and the synthetic cleaned it out. it was time to change that coark gasket to rubber any way.
Old 12-09-2009, 10:21 AM   #5
elmo
WFO
elmo's Avatar
Drives: 2008 hb
i switch my wifes Echo to syn. with 70,000 mile on her NO PROBLEMS why do people Bull Shit so much?
elmo is offline   Reply With Quote
Old 12-09-2009, 07:10 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
Old 12-09-2009, 07:39 PM   #7
toyo
Drives: toyota
now what you have to do is call that shop and tell them they should do some reading ;P
guys, what about changing from synthetic to mineral?
1st gen FTW
toyo is offline   Reply With Quote
Old 12-10-2009, 11:46 AM   #8
chai
Go Duke!
Drives: '09 Sedan AT
http://www.carbibles.com/engineoil_bible.html
There is no scientific data to support the idea that mixing mineral and synthetic oils will damage your engine. When switching from a mineral oil to a synthetic, or vice versa, you will potentially leave a small amount of residual oil in the engine. That's perfectly okay because synthetic oil and mineral-based motor oil are, for the most part, compatible with each other. (The exception is pure synthetics. Polyglycols don't mix with normal mineral oils.)
There is also no problem with switching back and forth between synthetic and mineral based oils. In fact, people who are "in the know" and who operate engines in areas where temperature fluctuations can be especially extreme, switch from mineral oil to synthetic oil for the colder months. They then switch back to mineral oil during the warmer months.
There was a time, years ago, when switching between synthetic oils and mineral oils was not recommended if you had used one product or the other for a long period of time. People experienced problems with seals leaking and high oil consumption but changes in additive chemistry and seal material have taken care of those issues. And that's an important caveat. New seal technology is great, but if you're still driving around in a car from the 80's with its original seals, then this argument becomes a bit of a moot point - your seals are still going to be subject to the old leakage problems no matter what newfangled additives the oil companies are putting in their products.
I just switched out from factory oil to Pennzoil Platinum and a TRD filter @ 5000mi. It is my understanding that "synthetics" like PP are compatible with mineral oil, and vice versa.
I strongly recommend a filter wrench cap... let's just say I had to punch a hole through the factory oil filter and shove metal through it to get enough leverage to remove it.
chai is offline   Reply With Quote
Old 12-10-2009, 01:02 PM   #9
Inspector14
Drives: 09 Yaris hatch, Meteor Metal
i got my car in December of 2008, i switched to Pennzoil Platinum synthetic at 500 miles. i ran that for 1000 miles and switched to Castrol Edge. i ran that for 3000 miles, and when i changed out for Lubro Moly, i did an oil analysis.
Blackstone labs said that the engine example i provided showed etremely low wear even for a new engine with so few miles. there was high silicon, but that was from a volcanic eruption.
you can switch to synthetic at any time.
Inspector14 is offline   Reply With Quote
Old 12-10-2009, 01:18 PM   #10
bronsin
bronsin's Avatar
Yeah no problem. Just make sure you change it every 6k miles/6 months like using conventional oil or youll void your warranty. (potentially)
Old 12-11-2009, 10:10 AM   #11
TheSilkySmooth
TheSilkySmooth's Avatar
I run HDEO Rotella T 10w-30. The engine runs much smoother with it than any syn I had in there(synpower, syntec). The GF4 energy conserving oils are very thin at high temp - high shear rate and can cause piston slap. Also, they are missing the generous % of antiwear agents that the earlier spec oil had. They removed these agents to protect the catalyst through the warranty period, since the agents can plate over the catalyst metals and render them inneffective. The Rotella has the EP antiwear anti-galling agents in good percentage to prtoect the engine. This engine will not use oil through a 5K mile Oci, so, catalyst poisoning is a moot point.
Old 12-11-2009, 03:55 PM   #12
SilverGlow
Drives: 2007 Yaris Hatchback
More BS from you, as usual.
The actual scientific data shows that 0w oils are not necessarily thinner at full operational temperatures.
For example 0w-30 and 10w-30 are both the same thickness at 212F.
Same for 0w-20, and 5w-20.
These 0w oils in fact have a lower shear rate then mineral...Grumpy, ArcoGraphite, and all the other many names you have, why do you keep posting BS here and other forums?
SilverGlow is offline   Reply With Quote
Old 12-11-2009, 03:59 PM   #13
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
OUCH.....
Old 12-14-2009, 04:33 PM   #14
TheSilkySmooth
Originally Posted by ROCKLAND TOYOTA View Post
OUCH.....
Ouch what? Lubricants 101. I said HTHS. Web Idiocracy
Old 12-14-2009, 04:23 PM   #15
TheSilkySmooth
Nice personal attack, silverworm -You know what they say about people who talk the loudest As usual you disregard my fine points about antiwear agents (SAPS) in SM/GF4 EC oils being reduced. Your absolute BS is about GF4 oils and "shear". Know that GF4 is under 3.0 HTHS on 0w/5w-30 weight; most all 10w-30 CJ-4 HDEO are over 3.5 high temp high shear rate viscosity. Read the FACTS on the product DATA sheets! In your world I should IGNORE the horrendous racket my car makes on syntec and just let it beat itself to death. Great advice!
Old 12-11-2009, 10:18 PM   #16
chai
Go Duke!
I think even Pennzoil Platinum is overkill for a Yaris. Time will tell, but I anticipate no problems related to engine oil... particularly because I will do all oil changes myself with OEM/TRD filters.
Old 12-14-2009, 04:30 PM   #17
TheSilkySmooth
Silver:
I know about low shear rate viscosity at 212degF - All classified SAE 30 weight must demonstrate a kinematic viscosity in a range between 9.3 and the 12.5 cSt - this is what DEFINES a 30wt motor oil. Duh.
Old 12-14-2009, 05:35 PM   #18
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
I have a salvage Saturn 1996 sedan sl2 and has a 172,849 mile on it, is it ok to switch to syntetic oil?
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Synthetic Oil Questions. Twistoffate0817 General Yaris / Vitz Discussion 19 07-15-2009 08:54 PM
