Just got back from Willow Springs, shaking down the 2012.
Considering how little it done to it when compared to the 99 car, it was fast. Just needs a little more tweaking, but a great first outing.
Stock pressure plate with hardware is 9lbs - the bolts made up about 3oz of that.
#3 | |
#4 | |
Started calling dealers today, nearest flywheel bolt is in San Fran. So the car will live on jack stands for another few days over a single blot.
Got the new Hoosier radial slick to test out.
Just got the new head with Jun cams back from Loynings... Oh how I wish I had time to install it and retune the car before this weekends race.
What's special about TRD bolts? Aren't they all grade 10 bolts?
Racer pricing from TRD.
WOW, the OS Giken Super Single was a bugger to install... Usually most clutch's have enough play in the splines you can pretty easily stab the transmission and bolt everything up. The OS Giken is so tightly machined you had to have everything lined up dead on. Working by myself it took an hour to get the trans bolted up, normally this is a ten minute job. I was beat.
So far I have only driven it in and out of the driveway, so driving impression is very limited. Pedal effort is high and it grabs hard. Would be great for a FI car, but I am not sure I would use it on a daily driver. Hopefully I will get a better idea of what its really like next week.
#10 | |
![]() ![]() Drives: Yaris & Supra Join Date: Nov 2008
^ with a trailer.
OS Giken is making a new diff with more plates for the Yaris.
#13 | |
Those tires...so much meat.
![]() How do you think (so far) the car compares with the one you race?
#15 | |
So far I am impressed. The longer wheelbase makes the car much more stable, and it does not get away as quick when it does break loose. The car exceeded my expectations for the day, it was nearly a full second quicker than I expected it to be... Still not as quick as the 99, but so far we have been unable to get the AEM mated up to the new ECU. Once we get the parts equal on both cars it may have a slight edge due to the lower roof-line and more stable platform. I sure do like the looks of it better than the old car.
#16 | |
We have had vendors looking for the plugs, so we could build an PNP like with did on the 99, but no luck. And so far we have not had a chance to try the hardwired method, we will likely start going down this road after the race next weekend. I hate to go hardwired because it is really nice being able to plug in the stock ECU if we had a problem, but we may not have a choice in this case.
#18 | |
| Hood Stay (lift) Instal | 1NZYaris1 | DIY / Maintenance / Service | 31 | 09-22-2016 07:56 PM |
| The opposite sex can't stay away with ssk | POORSHA | DIY / Maintenance / Service | 20 | 08-19-2009 10:41 AM |
| eTiMaGo Stay safe | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 20 | 12-02-2008 05:31 PM |
| Tuned a DBW Toyota yesterday | Turbo&Auto | Performance Modifications | 17 | 08-17-2007 12:04 AM |
| why am I always here?! wtf...i cant stay away.. | Blenjar | Off-topic / Other Cars / Everything else Discussions | 5 | 02-26-2007 10:51 AM |
