"Know it all"
Drives: Lancia Delta Integrale Join Date: Jan 2012
Are you still running VVT-i in this car? Does your tuner/management have control over the that?
www.microimageonline.com |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
Yes, still running it and the AEM controls it.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
"Know it all"
Great results! I'm real excited to see that these actually work. I'd be curious to see if any top end gains or benefit from disabling VVT-i and running set or manually adjustable cam gears. Might loose more torque though...
Can't wait to see what the turbo spec Jun cams do for boosted cars
#4 | |
![]() ![]() ![]() ![]() Drives: 2007 Yaris manual dark silver Join Date: May 2006
pics
From runoffs
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
2ZR swap. DO IT! Ask how!
Wow, I'm surprised to hear that there's so much involved in fitting those gears. The C-56 gears went in without much fuss, but I'm stalled on funding for replacement parts and the LSD.
#7 | |
![]() Turns out the gear itself is not to wide, but the collar at its base, that combined with the Yaris synchro made it bind up. And it is only the 3rd and 4th on the input side that is the challenge. They take a little bit off the collar and install the Celica/MR-S synchro its supposed to fit. Fingers crossed.
![]() ![]() ![]() Drives: 2010 Yaris HB Blazin' Blue Join Date: Feb 2011
Back in my Honda racing days this guy was the man for alternate gear sets, he can probebly help you out if need be. He is a multi-time SCCA Champ and really knows a thing or two about gearboxes.
http://www.housemanautosport.com/ racerb
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 |
#9 | |
#10 | |
#11 | |
racerb
#12 | |
C56B LSD You may actually have the same problem we did and not know it yet if you have not put it back together. You wont know until you jam it all in the case and measure the drag when you spin it.
It's definitely a C56A then, as it's an open diff. The assembly goes together at the moment, but I haven't checked the torque yet. I have to replace the output shaft inner bearing (the one in the bell housing) because the C56 has an inner race on the roller bearing, whereas the C50/C59 doesn't, and the groove where the snap ring holds the inner race on the shaft sits right in the middle of the rollers. I'm assuming that you weren't able to get the torque set properly with any of the shims, which prompted you to investigate?
#14 |
Do you know what the new ratios are?
#15 | |
#16 | |
Yes, 1st and 2nd stay the same, and I would not want them any shorter. With our final drive and tire size 1st is only useful for getting on the trailer. With 2nd good only to 62mph, it is only used on very tight turns, any shorter and we would have to use 3rd for the slow stuff. The new ratios are: 3rd 1.474 Kaaz 4th 1.208 Kaaz 5th 0.961 Kaaz With this setup on most tracks we will use four gears VS only two or three with the current setup, offering much better acceleration. We will see 120mph in 5th at our redline, perfect for Road America.
#17 |
just got my new issue of car and driver today....they did a b-segment racer comparo....kia, honda, mazda, mini....where was your toyota?
#18 |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
late comer i quess.....
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
| Hood Stay (lift) Instal | 1NZYaris1 | DIY / Maintenance / Service | 31 | 09-22-2016 07:56 PM |
| The opposite sex can't stay away with ssk | POORSHA | DIY / Maintenance / Service | 20 | 08-19-2009 10:41 AM |
| eTiMaGo Stay safe | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 20 | 12-02-2008 05:31 PM |
| Tuned a DBW Toyota yesterday | Turbo&Auto | Performance Modifications | 17 | 08-17-2007 12:04 AM |
| why am I always here?! wtf...i cant stay away.. | Blenjar | Off-topic / Other Cars / Everything else Discussions | 5 | 02-26-2007 10:51 AM |
