Old 06-05-2012, 10:37 AM   #1
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
I never let my car run out of gas, but I have the same thing as AAA included in my car insurance. It covers towing, flat tire changes, locksmith, battery jump-starts, and fuel/fluid delivery for $2.00 addl. every 6 months. So far, haven't had to use it with my Yaris for anything (knock on wood) but when I had the Cavalier I took advantage of it 3 times for flat tire changes.
DebbyM46227 is offline   Reply With Quote
Old 12-29-2012, 03:50 PM   #2
NEexpat
Drives: 2009, auto, 4dr LB
Trying to get my UltraGuage more accurate as it relates to MPG.
Currently it is set-up to an 11.1 gal. tank.
I always fill to the first click, round to the nearest nickel.
Based on CTScott's examination and testing I am thinking of resetting my tank size to 11.9.
Would I be correct in assuming that a first click fill up would add an additional .7 gal.,apprx.?
Or would increasing the the tank to 11.6 an additional 1/2 gal. be closer?
I am thinking .8, any thoughts would be appreciated.
NEexpat is offline   Reply With Quote
Old 12-29-2012, 04:03 PM   #3
For the first click, I would say that 11.6 - 11.7 is good. If you go a bit beyond that then 11.8 to 11.9 would be appropriate.
Old 12-29-2012, 05:35 PM   #4
NEexpat
Thanks Scott.
I think I will try 11.6 for a bit and compare to actual at the pump.
EDIT note: Would I be correct in assuming that a first click fill up would add an additional .7 gal.,apprx.?
That should be ".8"
Old 12-29-2012, 10:07 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
^ this
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 06:51 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
Fuel Level Gauge Stuck ? - 2007 Yaris Sedan kaboom New YARIS Purchase Forum 9 05-15-2007 02:58 AM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
