![]() Drives: 2009 Toyota Yaris 4D Join Date: Jul 2012
Thank again. Worked like a charm! CTScott, u r the man. Thanks bud!
Actually, one more question. Does the "Passenger Air Bag" light near the middle A/C vents always stay on? Or did I screw something up? If there's a problem with the driver air bag, another indicator light will come on in the dashboard cluster next to the speedometer right?
#3 | |
Sweet. Thanks man!! You've been a big help! With my alloy rims instead of caps, cruise control and new tint, my non-power Yaris just got upgraded haha
Drives: YRX NCP91R Join Date: Aug 2012
great info - thanks for everyone who provided photos and information.
I just wanted to hear from anyone in Australia who has added cruise control to their Yaris? From what this thread seems to indicate, the actual ECU on the Australian Yaris' are not able to have cruise control functioning. Therefore am i correct in my assumption that you have to "tap" into a speed control or sensor wire somewhere for Australian Yaris'? Does the instrument panel still have the cruise control indicator on the Australian models? I'd love to be able to just get this working on my Yaris YRX 2010 (NCP91R) automatic - preferably the kit shown here and not some other random aftermarket kit. Any helpful points would be great. p.s i did a search on "YARIS cruise control Australia" but didn't find the answers I was looking for. thanks! |
Many Japanese market vehicles do not support cruise control. The presence of only two male pins on the steering column end of the D3 connector tells me that your Fielder likely does not.
Drives: 2011 Yaris S Join Date: Jan 2013
I have a 2011 Yaris 5 speed MT, No power , Can i still do the cruise control
Yes you can. You will just need to do an extra piece (adding the connector D3 pins and running the wire from them to the ECM connector).
![]() Drives: toyota Join Date: May 2013
Dear Scott,
First of all received your wires 2 weeks ago and as I was out of state was only able to install everything yesterday. My car being a Thailand build Camry 2.0 was quite tight under the dashboard. It works like a charm.I am now happily crusing on my Malaysian highways. Thanks a million Scott for all the info I needed to make this happen.... |
![]() Drives: Toyota Yaris 2010 Join Date: Jul 2013
Will this be possible on european toyota yaris 2010?
Hmmmm got 89661-0dd90... No idea if it supports cc....
![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
Doesn't cruise control usually consume more gas than without it? I would probably start falling asleep if I had it on for too long
![]() Drives: Yaris Hatch,Celi 3SGTE,GC8 Join Date: Apr 2006
First of all thank you CT Scott for such helpful guide, I did it to my 06 PR spec Yaris and its been working like a charm for 6 months, I just have a question, Can I use a US S spec cluster (2010) to have the indicators working? I just ordered one from ebay.
#14 | |
I offer an indicator module, which can be used with 06-08 Yaris, which lack the cluster indicator. See my cruise control DIY below for more info on it.
Is the ecu plug n play? Or I have to look for one in particular? (US or PR spec), Thanks
It is plug and play if it is properly matched. You would need a PR spec one. You would also have to match the car's features - Transmission type, engine immobilizer or not, ABS, Traction control, etc.
Drives: Yaris Join Date: Aug 2013
Clear, concise instructions. Close-up pics. Couldn't have completed the job without this info.
Thank-you. |
![]() Drives: YRX Black 4 doors seden Join Date: May 2011
is anyone know, will the Rostra cc kit work on Australia model (2007) manual sedan,
Thank Lewis |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
