Old 01-11-2017, 03:56 PM   #1
pribek
Drives: Man
Send a message via ICQ to pribek Send a message via AIM to pribek Send a message via Yahoo to pribek
Hi Scott, I have a Yaris 2016 Hybrid with AT and TSS . The car is for European market (Croatia).
Can you send me the list of parts required for the cruise control and pricing?
If it helps I can send VIN number.
Sorry for my bad english
pribek is offline   Reply With Quote
Old 01-20-2017, 03:14 PM   #2
jra
Drives: 2015 yaris L
I bought a cruise kit from CT Scott about a year ago for my French built, 2015 Yaris L automatic, Took about 45 minutes to install, plug and play. Looks like it was installed at the factory and still works great.
jra is offline   Reply With Quote
Old 01-22-2017, 08:48 PM   #3
nvfool
Drives: 2012 sedan
2012 Yaris cruise control
I would like to get a kit for a 2012 sedan. Thank you
nvfool is offline   Reply With Quote
Old 01-28-2017, 10:39 PM   #4
jra
nvfool, when I ordered my cruse from scott, I had to send him a personal message to place order. I don't remember how I done that, clicked on his name in one of his posts or clicked on the quick reply in corner of one of his posts?
Old 07-22-2017, 03:37 PM   #5
mumairr
Drives: Toyota Vitz 2010
My Vitz 2010 model Japanese imported. It already has wiring upto ECM (saw it by removing the cover behind the steering )but my cluster doesn't have any indicators for CC. Do you think if i install OEM CC, my car would be able to handle it? irrespective of the indication on the cluster? if this is the case, i might change my insturmenet cluster.
mumairr is offline   Reply With Quote
Old 04-29-2018, 04:24 PM   #6
DanielNorrisII@Gmail.com
2007 Toyota Yaris with Blue and Brown Wire in D3
I have a 2007 Toyota Yaris with Blue and Brown Wire in D3 no A21 pin 40. What am I supposed to do with wire coming from ECM A21 pin 40?
DanielNorrisII@Gmail.com is offline   Reply With Quote
Old 04-29-2018, 05:18 PM   #7
Ok, I looked up the electrical drawings for cruise control. D3 goes to AD4, which is a connection between harnesses, and on the other side of the harness connection their is no wire coming out to pin 40 on A21. I got extra repair terminals, so I will put a terminal in the empty side going to pin 40 and solder it to the repair terminal I install in pin 40.
Old 05-13-2018, 08:35 AM   #8
Prakersa
Drives: Yaris
Can you share the diagram of CC. Still curious for the AD4 location... Tks
Prakersa is offline   Reply With Quote
Old 04-29-2018, 04:30 PM   #9
Also, where can I get a Cruise Control Indicator Module? Does CTScott still have some available or is their a wiring diagram that I could build one myself?
Old 04-09-2020, 01:06 PM   #10
reg_account
Drives: 2010 sedan
Hoping this thread is still alive. I am about to buy a base model 2010 4 door sedan without power locks/windows and auto transmission. Does this require just the stalk and wire? The guide seems to say it requires running wires to the ECM but a few posts here have confused me if that is needed. Since I don't have the car yet, I can't look but I wanted to get the parts.
reg_account is offline   Reply With Quote
Old 09-09-2022, 11:05 AM   #11
OCEANROADS
Drives: 2010 Yaris
My gf has a 2010 Yaris with a stick.
I installed a cruise control stalk I bought online. The dash light comes on showing cruise control is on, but it will not engage?
Do I need to add the clutch sensor?
Can someone please repost the clutch sensor wiring instructions?
OCEANROADS is offline   Reply With Quote
Old 09-09-2022, 08:11 PM   #12
sh0rtlife
yes you have to add the clutch switch, without it..the cruise acts like the clutch is stuck in...and just wont do anything
as for the wiring..a lil searching and you should find it
Old 09-12-2022, 01:58 PM   #13
thetut
Drives: 2007 4dr sedan
Read the last post here: https://www.yarisworld.com/forums/sh...t=33750&page=9
thetut is offline   Reply With Quote
Old 10-18-2022, 10:20 AM   #14
Xuanbinhktv
Drives: Toyota Vios 2011 MT
Hi every one!
I'm fom Viet Nam , my car is toyota yaris/vios 2011 Mt, Asia production, can I install cruise control for my car? thanks alot!
Xuanbinhktv is offline   Reply With Quote
Old 11-19-2024, 03:45 PM   #15
JustFPV
Drives: 2006 Yaris 2dr hb manual
Originally Posted by Xuanbinhktv View Post
Hi every one!
Your car does not have the programming in the ecu if it didn't come with cc from the factory. Only North American (Canada/US/PR) models have it built in and base models just dont include the stalk to activate it (or the clutch as well if MT). You'll need to look at aftermarket cruise control kits.
JustFPV is offline   Reply With Quote
