Old 12-27-2010, 11:30 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by Focus_Sh1ft View Post
Throwing a meth kit in isn't a bad idea either.
On a side note, I'd really like to see someone with a low boost turbo do a flywheel swap.
I already had the Fidanza flywheel on my car when I boosted it. Why do you ask?
Old 01-08-2011, 11:33 AM   #2
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Did some more work today to clean up the engine bay a bit. Not perfect yet but looks alot better than how i had it before.
Old 01-29-2011, 11:49 AM   #3
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Sweet setup I like the "stock" engine view.
Good luck with your tune!
Parmas is offline   Reply With Quote
Old 12-27-2010, 10:00 AM   #4
Yoda
Yoda's Avatar
Gonna get it pro tuned then dyno
Old 01-08-2011, 07:38 PM   #5
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
wow... thats a very clean setup!
Old 01-27-2011, 07:25 PM   #6
Yoda
Yoda's Avatar
gonna try to run 9 psi if the injectors can handle it.... Let you all know Saturday what the deal is
Old 01-27-2011, 11:07 PM   #7
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Nice. I've been running 8.5-9 lbs of boost. Pulls strong.
Old 01-29-2011, 11:22 AM   #8
Yoda
Yoda's Avatar
Finally made it down. My wiring failed me bad it started to sputter on the way down. Had to bypass it :(
Old 01-29-2011, 11:43 AM   #9
^ Can't wait to hear, wishing you the best of luck with your tune!
Old 01-29-2011, 04:02 PM   #10
Yoda
Yoda's Avatar
Having them check the wiring
Old 01-29-2011, 07:56 PM   #11
Yoda
Yoda's Avatar
Pissed. So one my fic has some hardware malfunction. Two I have crazy boost leak. Three I ended up with 171 whp and 183 tq. It would not hold 9 psi... It feel right down to 6~7.
Only one good thing Rolo said when I get the stupid problem fixed he would retune for freez
Old 01-30-2011, 01:41 AM   #12
Bluevitz-rs
Now there's customer service.
Old 02-01-2011, 07:47 PM   #13
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
yea man the fic issue doesn't suprise me. If I were to guess I would say 3 out of 10 units are defective out of the box. We have sent back the clearly defective units and AEM claims there is nothing wrong ..... even though switching units right on the dyno solved the issue.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 01-30-2011, 03:46 PM   #14
that's awesome, and a great result!!
Post up the dyno and if you have one, a video clip. You know we want one!
Old 02-02-2011, 03:11 PM   #15
Yoda
Yoda's Avatar
Yea I gonna have to send it back to them. Cause it's just not working anymore. Car won't even start with it in.....'sigh'
Old 02-02-2011, 06:01 PM   #16
Focus_Sh1ft
Focus_Sh1ft's Avatar
^ Did you try swapping .z firmwares? I believe .z107 is usually the accepted firmware for toyotas/scions.
What exactly is the problem? Can you even connect to it?
Old 02-02-2011, 06:17 PM   #17
Yoda
Yoda's Avatar
I tried the firmware and failed. Talked to the AEM techs they said its very unlikely that its a hardware issue but I am welcome to send it to them. Only thing i can think of now is the wiring is bad. Something came loose or something. Next possible factor could be that the TPS has gone bad for some reason. Gonna go through the wiring again and make sure all connections are secure. Probably something up with the grounding wires i think.
Old 02-05-2011, 05:18 PM   #18
Yoda
Yoda's Avatar
tsk tsk tsk i found my problem with the fic. Now to the boost leak.
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
