![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
I have a internal wastage .
So my choices are as follows:
Order new external mani from MI and find an external WG Have a manifold custom made Sell everything and just get a new car lol. This unforseen expenditure will delay me a bit longer. |
#3 | |
Sorry if I was not clear. The internal wastegate is what is preventing it from fitting. It hits the firewall.
Last few parts I was waiting on have come in. New manifold and wastegate. Just one more thing to get... AEM EMS with pnp harness.
I cant wait
Small update
Finally got all of the parts needed. Engine done and going in.
About 2 more weeks of work. |
looks awesome.
Went to the shop just to see how they were doing. Its pretty much all done but one problem is getting the TPS issue with the Haltech Sprint sorted out. The issues is that the Haltech is not reading the throttle position accurately. If he puts 50% throttle it reads between 70-100%. Tried a couple different settings but nothing seemed to fix it. Now were trying to figure out if it is tapped in the right location. I think its in C20-115 right now. Are there any other possible pin locations or settings I may have missed?
![]() ![]() Anyway here are a few pics
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
what does it read a t closed throttle? sounds like it is off keyed but further testing would be needed to determine for sure.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
Cant member what it was. I know the blitz guys use A21-55 for an input not sure it would work for me but I will try anything at this point. If I get this solved then by Friday i will pick her up.
Anyone have any ideas? Seems like the FI section went belly up.
Mr. 155 and climbing
Is this possibly a drive by wire issue? Are you still using the stock ECM for DBW?
#14 |
Have you reached out to Carlos to ask him yet?
#15 |
#16 |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
He's tapping the wire, not intercepting it, right?
#17 |
I am pretty sure. I am going over there in a couple hours and will make sure every thing is set up right. Did my research on some possible causes. Really hope it can be resolved today as I just need a tune and this beast is DONE!
On another note... How is that Tc of yours? |
#18 |
Alright so its about 90% done.
These are the problems I am having now: -High Idle of about 1500rpm. I hoping the ecu relearns the idle. If not I will need to switch from DBW to cable. -Car starts after 3 attempts every time all the time. Not sure why yet. -AFR at idle is off the scale lean even tho the vacuum its dead on at 19hg. When we add more fuel it doesn't even move. The sensor is fine tho as it read accurately when tuning and when tested. So hear are the numbers...259whp and 246tq @ 13.8psi on pump gas. Not sure how high I can go before I need water/meth so it was just tuned of the wastegate. I am driving it around to break it in and to see if the idle drops then its back to clean up the tune. |
| Turbo Project Yaris TS 1.8L | CASTREX | Yaris TS Talk | 40 | 08-21-2009 10:24 AM |
| HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
| Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 12:30 PM |
| delayed turbo project... | joey1320 | Forced Induction Forum | 8 | 09-26-2007 11:18 PM |
| Vitz Rs turbo vs U.S. Yaris add turbo? | weaponrcamry | Performance Modifications | 18 | 08-09-2006 08:45 PM |
