Old 03-25-2013, 01:07 AM   #1
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Derick your amps under your seats ?
Old 03-25-2013, 09:47 AM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
No, they are too big to slide under the seats, 2 are under a false floor behind the seats, the 3rd amp is in the trunk.
D.
CLA 250, 4MATIC
Old 03-26-2013, 12:10 AM   #3
derickveliz2
Work in progress...
Showing the Pioneer Tweeters as far apart from each other to acquire the widest stage possible:
D.
CLA 250, 4MATIC
Old 03-26-2013, 01:04 AM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The interesting thin about those tweeter locations is that is goes against the PLD theory/practice. That being said, depending on the crossover point, you may be fine.
What are your thoughts so far?
― Thomas Paine
Old 03-26-2013, 01:41 AM   #5
derickveliz2
Since my Mids (point source) runs from 250 Hz to 8 kHz the tweeter only picks up at 10 kHz and up. PLDs theory doesn't apply to tweeters playing that range I kind of use a little bit of T/A then L+R EQ with some L+R Levels to match the center image with the Mids, Honestly depending on the track the tweeters completely disappear in stage, I just can't localize them.
And compare the tweeters in the a-pillars the reflections from the windshield made tuning the tweeters a lot harder than next to the sailpanels, where I get a straight path to my ears with less reflections.
The Mids are taking all the T/A with L+R EQ I can get (it's not a lot though), taking advantage of only 9" of PLDs it's very easy to center the image and as far forward I physically can.
One more thing that I wanted to ask you: Talking about Subwoofer and Lows...
-What about tuning the Subwoofer and Lows? I've done it by ear moving around the x-over points and slopes, to the point the BASS is Natural and feels really good no matter what kind of music I play, but ...
there should be a good technic using low frequencies and what I've seen called swipes or some thing like that, playing low notes back a forth, but ...
How do I do this in a theoretical way?
D.
CLA 250, 4MATIC
Old 03-26-2013, 01:53 PM   #6
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I know what you're talking about with the crossover point on the tweeters. Take a look at the frequency graph that illustrates where the range of each instrument lays. That'll give you a reinforcement of the reference for your tuning techniques.
Phasing becomes an interesting beast when getting into the lower mid bass. At 60-75 Hz, location becomes much more challenging.
― Thomas Paine
Old 03-29-2013, 11:19 AM   #7
derickveliz2
What do I need to not embarrass my self in a show like this?
D.
CLA 250, 4MATIC
Old 03-29-2013, 04:03 PM   #8
sqcomp
Roadrunner Jr.
sqcomp's Avatar
First, do NOT enter any of the install classes just yet. Not that you can't, however it is more about finding what the judges are looking for according to the rules is what your goal should be in that type of class. When you can during the competition, shadow the judges for install and see how they judge. Also, it makes sense to have a copy of the rules so you aren't blind sided by anything. Also know that both sactioning bodies (Moe Sabourin for IASCA and Steve Stern for MECA) will "reward" you with points for being a member before your competition run. This is only a way of raking in the money for the organizations, understandably. I know you want to win straight out and never ever lose. That's the wrong mind set. You want to learn and gain objective opinions. Know that this is very difficult to do as we ALL have our biases. The same WILL happen the higher you get into competition, whether people will admit it or not. I've seen bias and politics rear it's ugly head all too often. I would take whatever "points buffer" that they offer and add it to your score if you decide not to join the leagues. Let's say you are off of 1st place by 3 points. If you allow for the IASCA "bonus" of 5 points for membership, you'll know you would have won out over the IASCA member in 1st place (for example).
Now, what I would do is to go to the show, and enter the IASCA Amateur class SQc. I don't think you're technically allowed to enter the Rookie class due to the modifcations of the pillars.
Now, the stinky part for you Derick is that in MECA SQL you'll be stuck in the Modified class because of the location of the subwoofer and the dash pad.
Still, enter those two sound classes and listen for the judges feedback. DO NOT change anything until you get back home and thuroughly review the feedback. Then and ONLY ten make changes if you deem it needed at that time. Why? I've seen MANY competitors change something the night before or the day of and even the day after the competition and completely wreck themselves over someone's subjective opinion.
Don't fall into that trap. Make changes only after careful review and scrutiny.
I still need to e-mail you SB's build log on the "expert" class G35. It's really a fluffed up pro class car honestly. Still, the insight will provide you with how much goes into a true IQc run. I have another build log from another IASCA "world champion" rookie vehicle I can send you. I can also get you a copy of last year's IASCA rulebook. I've been distracted with real life and have neglected to send those to you, I apologize.
Also note that joining either of those leagues will cost over and above the entry fees for the show.
― Thomas Paine
Old 03-29-2013, 04:53 PM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
One addendum regarding attitude...
The following is my not so humble opinion:
The reason why I blow off the membership to these leagues is because of the blatant politics that I've personally seen and even had to take part in as a judge for IASCA and event promoter. If some "big hitter" doesn't get their way or if you're beating them in the scorecards and they somehow get a peek...I've seen world champions throw literal temper tantrums at the mere thought of placing second.
Look, it's only a trophy...and a cheap one at that.
What really matters is that you have great sound. Don't get too wrapped around the axle about harvesting trophies. If you really truly want a trophy, I'll order one for you that says you're flippin' Superman for all I care.
Be and do the right thing. Be gracious to those around you and don't fall into the trap of uber-competitiveness. It just turns you into an elitist jackass and turns the kids who look at this as a future hobby away because of the bad example set. There are industry "giants" out there that will shake your hand and then turn and do whatever they need to to kill your chances at success. I've seen it happen all too often.
Don't be THAT guy.
― Thomas Paine
Old 03-29-2013, 10:10 PM   #10
_S7V7N_
_S7V7N_'s Avatar
Derick just go in there humble and have some fun. Talk to as many people as possible. Be nice and courteous. Expect a bit of bias for the guys throwing the show. Don't be surprised if they take 1st 2nd and 3rd. It's not right, but i've seen it happen.
Also you may hear a bit of crap about what equipment you use, or the car you drive. Some guys can be a bit snobby. To them it's all about buying and paying for high end audio, which I'm sure the shop sells some top of the line stuff, so anything else is " garbage".
So go in have fun, and prepare to hear alot of trash talk...Loll..
Old 03-29-2013, 11:24 PM   #11
derickveliz2
I've been dreaming or should I say I've been having nightmares about going to a competition.
I don't care if I'm first place, last or second, I enjoy what I've done to my car, to me sounds great! there isn't much that I would like to do to improve it even more; I'm happy and...
my little Yaris may not last long, so I would like to give it a chance and let him swim with other fish.
What I really would like is... to go over the experience of exposing what I created with the judges and having their opinion, talking to other enthusiast/professionals about their systems and to listen what have they accomplished and how they got there and why.
In the Auto-Audio industry there are so many variables, just thinking about it... every body has different ears. What I hear may not be the same for others. I know SQ it's not for everybody. Some people could care less about it, some others would go crazy, more people would go WOW! for a thumping system that you can feel hundreds of feet away... I go WOW too, but once I get inside in the drivers position, it's another story, I believe this is a selfish section of the hobby, because everything is set up for your driving position, your ears and your taste.
I read about MECA and modified class, for me it's great...! because I've accomplished with a simple, inexpensive solution get most of a system without going nuts! disadvantage?... not really I'm not trying to win. I just want to have some fun.
D.
CLA 250, 4MATIC
Old 03-29-2013, 11:33 PM   #12
derickveliz2
I forgot to mention that I will be taking lots of pictures!
D.
CLA 250, 4MATIC
Old 03-30-2013, 02:49 AM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Derick,
I just e-mailed you the sky drive link to the install photo book for the G35. It will provide you a great insight to what a top level phot book for an install challenge run would take.
Now, what did you mean in your other post regarding your Yaris not lasting too much longer? Are you going to be getting another vehicle soon?
What was said about the attitude of other competitors is absolutely true. Anyone that tries to deny it is sadly mistaken and/or trying to hide from reality. I've seen it as well at the highest level. Heck, Steve Stern himself made it known that HAT gear wasn't welcome at his shows. That may have died down BUT, it's not forgotten. There's a whole level of petty politics played at the top levels by the small minded people that run and compete. Heck I still have a copy somewhere of Stern's letter to Buwalda basically damning him from MECA competition...over money...
Stay as far away from it as you can Derick. I say this sincerely. Do what you need to do to have fun at the local shows but don't even think of becoming involved with anything bigger. It'll just drag you down, I don't want to see that happen.
― Thomas Paine
Old 03-30-2013, 11:08 PM   #14
derickveliz2
Thanks for all the info you sent me Sqcomp, I have one 1st question,
is there any way to be judged by Audio only
and...No I don't want to replace the Yaris, I just said that because it's getting tired and I see a lot of rust, wear and I can see my self changing disk-brakes, shocks and muffler, etc soon.
If I get to go... I'll have fun. for sure!!!
For example yesterday I gave a ride to a kid from church (teenager), once at his house I asked him if he liked music, I told him to seat behind the steering wheel, close his eyes and relax! That I had a special song I wanted him to listen.
I moved to the rear seat and play the song using the remote control of the HU, he was thrilled to the point that at the end of the song he was begging me for a copy.
That's it! he thought it was a magical song that according to him it had the singers and instruments sounds like coming from different places. jj
D.
CLA 250, 4MATIC
Old 03-31-2013, 05:09 AM   #15
sqcomp
Roadrunner Jr.
sqcomp's Avatar
That was the suggestion.
Absolutely, compete in the two formats but sound only. As someone who has competed, judged and put on sanctioned shows...it'll be less stress on you. Enter ISACA's IQc as an amateur and MECA's SQl Modified class.
What you should do is watch the install presentations if at all possible. If you find that you want to do the presentation for that class, I'll work with you on putting together a photo book and if somehow we can manage, we can practice the presentation to the judge regarding your system.
Thoughts?
I've also been looking at a different project. I really want to get to the racetrack more often. Last night I went to the local drag races and spoke with a few people about their rigs. I'm floating away from the import scene and gravitating to the old American iron. There are lots of cars I'd like to try my hand at. We'll see where these next couple years take me with the military.
I've also been talking with Garm about the Yaris as well. We'll see about building a mill that will do my spirit justice out on the road...
― Thomas Paine
Old 04-01-2013, 01:12 AM   #16
derickveliz2
If I can make it to the show, I will go for Audio and skip the Presentation.
Racing it's awesome, of course I race with the Yaris @ 44 MPG
I did enough racing when I was in my 20s LOL
But give me power and I'll be flying!
D.
CLA 250, 4MATIC
Old 04-01-2013, 01:21 AM   #17
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I wouldn't waste my time or money on the Yaris as a racing platform. Sorry to all the hardcore fanatics out there. I'd spend 20k to get a Yaris engine where I wanted it...the same amount in an 8 cylinder setup is just going to provide more potential.
I'm looking at a 1965 chevy truck 496 cu. in. power glide with trans brake, 513 rearend gear with spool, line lock and some nitrous plumbed in for $hits and giggles. It's set up for the pro street class in drag racing. I have a place to store and wrench on it and it's at a price I can't overlook...
― Thomas Paine
Old 04-02-2013, 12:40 PM   #18
derickveliz2
A Guru question...
I've notice that early in the morning the Center Image is slightly to the left and when I come back at the end of the day the Center Image goes back to the center.
It's very little but I can tell the difference and I tweak it back and forth on the road to bring it back exactly to the center...
Is this due to weather conditions, (Humidity, Pressure, Temperature, etc)?
I know some songs have the center image off by a little but I've seen this on specific tracks with Center Image right on center.
Just curious... I'm guessing the atmospheric conditions affect physical aspects of the speakers and so on.
or
My ears and my way of listening changes through the day/night?
D.
CLA 250, 4MATIC
