Old 05-12-2014, 02:57 AM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Have you placed the horn lenses yet?
― Thomas Paine
Old 05-12-2014, 11:20 PM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thumbs up
Here is the passanger side, I'm measuring how much I have to trim, mmm about 2 1/2"
D.
CLA 250, 4MATIC
Old 05-12-2014, 11:20 PM   #3
derickveliz2
Waiting for me at the parking lot...
D.
CLA 250, 4MATIC
Old 05-13-2014, 12:29 AM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Sure you want to trim versus mini horn lenses?
I'm picking my other car up tomorrow. We dialed it down to 409whp. Suspension comes next.
― Thomas Paine
Old 05-13-2014, 12:40 AM   #5
derickveliz2
Yes, I really want to have them cross at 600-800 Hz
The lower the better...
If I trim that section then I can slide them deep under the dash!
D.
CLA 250, 4MATIC
Old 05-13-2014, 01:33 AM   #6
derickveliz2
Using horns helps control the dispersion pattern of the speaker's sound wave preventing reflections; look at image A.
Image A:
A conventional speaker will have a wide dispersion pattern (Image B.) and by experience I can tell how bad reflections are inside a car. These "First Reflections" are a killer! when tuning!
Image B:
To me I can see how to take advantage of the Horns + the underside of the dash, if you look at the image below these almost become a bigger horn! taking the sound from a far distance and throw it towards your ears, preventing reflections inside the car.
D.
CLA 250, 4MATIC
Old 05-13-2014, 01:35 PM   #7
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Jason,
http://www.yarisworld.com/forums/member.php?u=764
fnkgrv
@Derick - The nice thing is you have active processing. That will be especially helpful. What was your midrange crossover set at frequency wise?
― Thomas Paine
Old 06-03-2014, 02:01 PM   #8
derickveliz2
I do have all the processing I need !!!
Mids:
HPF 250Hz - LPF 6.3kHz slopes 24
Some thing like that...
With the horns probably the x-over would be like:
HPF 800Hz - LPF all the way up to 20kHz
The Midbass will pick up from:
HPF 80Hz - LPF 600Hz (My Guess)
D.
CLA 250, 4MATIC
Old 05-13-2014, 11:32 PM   #9
sickpuppy1
Drives: 2010 Yaris Sedan
I wanna watch this build..... Horns have a distinctly different sound and I am wondering how it will work out in a car. Many feel they sound to "horny" if you will, kinda bright. I am a horn fan and have 2 sets of Klipsch reference loudspeakers, so I'm not hating. Just curious how it works out.
Old 05-15-2014, 07:10 PM   #10
sqcomp
Roadrunner Jr.
sqcomp's Avatar
^The nice thing for Derick is his EQ and level control. That will help tame the peaks the super efficient horns might give...
― Thomas Paine
Old 06-03-2014, 01:39 PM   #11
derickveliz2
Check what I saw the other day!
D.
CLA 250, 4MATIC
Old 06-03-2014, 03:24 PM   #12
derickveliz2
I'm impressed how simple and effective MB designs are, the way they deaden and the treatments to the different surfaces is very clever!
Any way... here is the rear left wheel well exposed bringing the cable under the car through the body ground effects worked really good.
Then I found a grommet on the top of the wheel well that gave me access to the Trunk!
D.
CLA 250, 4MATIC
Old 06-03-2014, 03:26 PM   #13
derickveliz2
D.
CLA 250, 4MATIC
Old 06-03-2014, 03:27 PM   #14
derickveliz2
D.
CLA 250, 4MATIC
Old 06-03-2014, 05:00 PM   #15
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Was that your Yaris?
― Thomas Paine
Old 06-03-2014, 09:57 PM   #16
derickveliz2
YES!!!
D.
CLA 250, 4MATIC
Old 06-04-2014, 12:26 AM   #17
derickveliz2
40 MPG is possible...
If I take the miles range 565 miles divided into 13.2 gal it's about 42 MPG, in real life I think I'm getting around 38 MPG at the gas station, because sometimes I just can't hold my self and I like to floor it down once in a while!
D.
CLA 250, 4MATIC
Old 06-14-2014, 11:17 PM   #18
derickveliz2
Originally Posted by BADIS View Post
Hi all. I have a 2007 Yaris Sedan M/T .On the dashboard I have no RPM and no temperature gauges. Can you please tell me where to find stylish gauges? And does that car come with harnesses and plug and play wires?
I'm planning to buy some gauges but I'm afraid I can't mount them.
That is a question for our friend CTScott I bet he knows!
D.
CLA 250, 4MATIC
