Old 05-15-2010, 09:33 AM   #1
DailyDriver
DailyDriver's Avatar
Drives: 3dr Lftback (meteorite) Manual
Thanks for all the pictures!! Within the next couple of months i will be starting my car. These help a lot.
DailyDriver is offline   Reply With Quote
Old 05-17-2010, 10:07 AM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
You are welcome,
where in Utah are you?
Derick
CLA 250, 4MATIC
Old 05-17-2010, 11:15 AM   #3
derickveliz2
Unhappy Old subwoofer box is TOO HEAVY
I did a "TEST FIT" of my old subwoofer box that I had in my Tacoma (hey I'm a TACO-YARIS)
Bad news for me,... the box is TOO HEAVY! )o:
So until I upgrade my suspension I'm going to build a box and put only one of this Solobarics, The box will be very small (per manufacture specs... 12x12x12 To end up with 0.66 cu. ft) this is the LINK for more info about the box and subs. (note that these are a little old now but they are good).
My wife is going to love this, lots of space in the trunk! (amps will be behind front seats) so nothing else in the trunk and the little subwoofer box with 10" woofer should be very easy to remove!
Here is a picture of trunk with my old subwoofer box [man that's a VERY HEAVY BOX!] My back is in pain today . Hey I also have a 10" bazooka tube that I'm going to put in my wifes car (another Toyota) that I can use for testing or until I get to build the new box. LINK for 10" Bazooka
CLA 250, 4MATIC
Old 05-17-2010, 11:34 AM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I love those solo D's. Have fun with those.
― Thomas Paine
Old 05-17-2010, 11:40 AM   #5
derickveliz2
Thanks!
I will!
sqcomp... don't forget about my EM100's
D.
CLA 250, 4MATIC
Old 05-17-2010, 11:49 AM   #6
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I was about to suggest you doing dual 10's in glass boxes on each side of the trunk... but then remembered your wife is due in the near future..... if only you had a little more time, you could make some cool glass boxes that fit perfectly in those side nooks in the trunk.
Old 05-17-2010, 12:07 PM   #7
derickveliz2
Thumbs up
I've been thinking about that too.
I don't really need to be 100% done by July, so I probably will end up with something that satisfies me for a while and then in Fall I could start working on this IDEA!
Sounds great!
Thanks
Derick
CLA 250, 4MATIC
Old 05-17-2010, 02:51 PM   #8
derickveliz2
Talking
Look what I got in the mail today!!!
This will go after the head unit.
CLA 250, 4MATIC
Old 05-17-2010, 05:46 PM   #9
derickveliz2
Smile
Ok, so this is my Audio plan for now "to start with", until I learn something else or find out I can do this or that, please I'm open to suggestions
Thanks
CLA 250, 4MATIC
Old 05-19-2010, 11:23 AM   #10
derickveliz2
I'm trying to pull together my HU and other parts together, here are a couple of shots with the HU, adapter and bezel.
CLA 250, 4MATIC
Old 05-20-2010, 12:31 PM   #11
derickveliz2
Smile
Last night I took the panel that goes on top of the seatbelt (passengers side) and treated a little bit, I've been driving with out the panel and there is some annoying noise coming from the inside the structure, I describe it as a small guitar reverbering all the road noise into the cabin, I've thinking on how to approach this little piece and this is what I did:
Stuffed the inside with poly-fill and regular foam, stick some Mat and little pieces of CLD Tiles to the metal, covered with ensolite (the sticky one) then I cut to shape some MLV and started cutting with a knife to make it fit inside the panel.
This morning I was very happy with the results, now all the noise is coming from Pilots side and it's driving me crazy so I think this weekend I should take care of that area including the left side of the firewall.
Panel with some Mat + 1/8" CCF / Ensolite / MLV
This is a close up on for the treatment on this panel.
This panel was tricky because the seatbelt runs inside!
I did cut a mirror shape piece of MLV for the other side.
Thanks.
D.
CLA 250, 4MATIC
Old 05-26-2010, 09:50 AM   #12
derickveliz2
I've been a little quiet lately, not because I wanted but... I've been working 12-16 hours a day on this project that is due next week. BUT....
for the record, I would like to note:
I'm trying to be really honest and here are my observations in the last 2 weeks.... After driving more than 1,300 miles on new wheels and tires I can tell that I lost a couple of points here )o: how is that? whell some tires make more noise than others
in this case the General Exclaim are not so bad it's not a noisy tire but... I went up from 23.1 inches in diameter to 23.7 this brings the tire closer to the wheel wells, not a big deal but it's noise I can tell it's there and it wasn't there before, and all the noise comes from the
front left of the cabin (untreated area).
New General Exclaim tire:
So if you really want the ultimate deadening Yaris, don't upgrade your tires and rims, stay stock with smaller wheels (185/60/15) and better if the Tires you get are designed for fuel economy, rated high milage and of course very quite, one example that
I can speak of are the Good Year Assurance witch I have in my Corolla and they give a confortable ride and very quiet (warranty is 80,000 miles and I can speak about that too).
Good Year Assurance Tire:
In conclusion I'm sacrifying "looks" for "little noise" we'll see how affects the overal deadening treatment.
Yesterday I had the opportunity to go to Boston in a brand new Mercedez Benz.
so I was so exhited to compare the noise levels. I can say that we are doing the right thing, we can't compare these two vehicles head to head but what has been done here it's working. The noise level in the MB was really nice, my Yaris is close but not the same. All the way up to 55mph every thing seems to be almost the same if I don't rev up the engine on my Yaris, after 55mph all the way up to 80mph the wind noise in the MB is freaking quiet!
I'm sure the windshield on the Yaris is not as good, also I bet MB performs rigurous test in a wind tunel, so yes at 70-80 mph the MB is much quiet than my Yaris, wind noise coming from the windshield is louder and ofcourse 3,500 rpms to keeep up at speed makes the engine louder too.
I'm very satisfied with how everything is coming together, I'm not done with the cabin, and I still have plans to work on the hood and engine compartment.
I will never make my Yaris feel like a Mercedez Benz but the ride may end up been almost as quiet. We'll see.
CLA 250, 4MATIC
Old 05-26-2010, 10:39 AM   #13
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
that is why i chose to stay with a 15" rims the bigger the rim the higher the speed ratting on the tire to retain the like wise size of the stock tire hight you get a harder ride with more road noise . i say the michlin tires has the best ride and lowest noise but dont come cheap .
pennyracer is offline   Reply With Quote
Old 05-26-2010, 11:07 AM   #14
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
There you are Derick! I was hoping everything was OK. Glad to hear it was just work getting in the way. Personally, I've gone for looks/performance and sacrificed some road noise and mpg's with my tire/rim combo. I'm very happy with the noise reduction results I'm getting and I can always turn up the volume and tune out ANY road noise that way! I also came to realize that I like a "little" road/tire/engine/exhaust noise, I feel more in touch with the car and the driving experience. What I DON'T like is the little interior rattles, vibrations and stuff like that from inside the car. But those are all going away soon!
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 05-27-2010, 07:57 PM   #15
derickveliz2
Talking
I miss that a lot,
and it's been hard to get used to.
But on the other hand makes my commute so comfortable, can't wait to finish this deadening treatment and start with all the audio install. I hope I can get some work done next week. :thum bup:
CLA 250, 4MATIC
Old 05-27-2010, 08:18 PM   #16
derickveliz2
I think I should update my video for Yaris World...
http://video.google.com/videoplay?do...0404002868474#
D.
CLA 250, 4MATIC
Old 05-27-2010, 11:58 PM   #17
derickveliz2
Smile
Dash Mat!!!
Before heading home from work I cleaned the windshield inside/outside and I took out the Ugly Dash Matt and didn't put it back!
For the record: "I really like my Dash Mat now" it does makes a difference, so for people like me with a long commute on the highway, I recommend installing a Dash Mat.
I can tell the difference specially above 55mph.
my 2 cts.
CLA 250, 4MATIC
Old 05-28-2010, 11:42 AM   #18
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
i'm confused.... So you like the function of the dash mat, but hate the looks? But chose to keep it in the car????
