Old 03-21-2011, 11:43 AM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
What is the contrast between this one and the I6SW?
― Thomas Paine
Old 03-21-2011, 11:23 PM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Question
I'm guessing...
Sensitivity and Mounting Dept. (about an inch more for the JL)
JL Audio 6W3v3-4 80.49 dB at 1 watt
I6SW 90 dB at 2.83 volts/1meter
My translation would be the JL is not as efficient as the I6SW and needs a lot more power.
Please add and/or correct me if I'm wrong.
D.
CLA 250, 4MATIC
Old 03-21-2011, 11:29 PM   #3
derickveliz2
I took out the Camber kit, no more uneven wear on the rear tires.
Uneven wear on tires produces lots of noise and if too much some vibrations.
I'm was able to squeeze the rubber rings a little bit more into the springs, this increases the spring rate and without a sub-woofer box in the trunk, the Yaris handles much better.
D.
CLA 250, 4MATIC
Old 03-22-2011, 12:01 AM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
You're looking at about 87-88 dB at 1W/1M on the Imagine. So essentially it'd be more than twice as loud (edging closer to three times) given that it's the same general cone area. I'd estimate that the I6SW is not only cheaper but it can fit into the same sealed enclosure and go ported and bandpass (not that you have to worry about the latter). The XMAX on the JL is 1mm more but given the difference in sensitivity, that JL still won't stand a chance.
― Thomas Paine
Old 03-22-2011, 12:05 AM   #5
derickveliz2
Talking
That's what I thought
did you have a chance to ask Jim and order a I6SW? should I call him tomorrow?
D.
CLA 250, 4MATIC
Old 03-22-2011, 02:47 AM   #6
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I'm not going to see Jim until Wednesday night.
I would call him tomorrow, yes. Mention that you'd like to order the Hybrid I6SW and have him make a nice trim ring for it, all flushed and everything.
With the being said, would you mind if we made some video of it? I would like to give it some break in time in our sound room for a night. Perhaps even put it in a small sealed enclosure and, like I mentioned, shoot some video of it in action.
Thoughts?
― Thomas Paine
Old 03-22-2011, 11:00 PM   #7
derickveliz2
Thumbs up
Thoughts?
ALL IN THE NAME OF SCIENCE AND SQ
PS. I called Jim, I told him I wanted an I6SW and he was going to call me back.
D.
CLA 250, 4MATIC
Old 03-22-2011, 09:35 PM   #8
sickpuppy1
Drives: 2010 Yaris Sedan
Hey SQ, Whats your thoughts on Eric and Matt leaving ID ? Any ideas on Eric's next project?
Old 03-22-2011, 11:04 PM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Well...apparently Eric couldn't get the other major partner to sell to him. I'm not quite sure of Matt's connection.
I know the shop is already liquidating the ID stuff. I'm also hearing that the rights to the compression horns are leaving ID as well...That doesn't bode well.
― Thomas Paine
Old 03-22-2011, 11:24 PM   #10
sickpuppy1
He apparently has plans under way for his new "endeavor" and in no way is he giving up his love of sound. He stated on another site Matt is no longer with ID and is going to work with him. So basically, he may not own ID anymore,but he will resurface with a new "project". He seems to be a genuinely good guy and they wont keep him down. Never know, He may have had some new ideas that never came to light since he knew this was coming........
Old 03-23-2011, 12:07 AM   #11
sqcomp
Roadrunner Jr.
sqcomp's Avatar
It's too bad, I know that Scott could probably use Matt on the development of his woofer line...
― Thomas Paine
Old 03-24-2011, 12:11 AM   #12
sqcomp
Roadrunner Jr.
sqcomp's Avatar
God help me derick, I just picked up a bit one for the system.
― Thomas Paine
Old 03-24-2011, 12:16 AM   #13
derickveliz2
Question
OHHH NO!
what are you going to do now?
D.
CLA 250, 4MATIC
Old 03-24-2011, 02:09 AM   #14
sqcomp
Roadrunner Jr.
sqcomp's Avatar
...I'm going to have a full 1/3 octave EQ'ing on each speaker, twice as much T/A processing, and 48 dB slopes. There's more of course but, you get the point.
― Thomas Paine
Old 03-24-2011, 06:59 AM   #15
sickpuppy1
right about then, i saw SQ doing this pelvic thrust thing and going ,"can ya feel it? huh? can ya feel it!!??" LOL
Old 03-24-2011, 11:09 AM   #16
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 03-24-2011, 06:55 PM   #17
sickpuppy1
LMAO,Exactly right....
Old 03-25-2011, 12:01 AM   #18
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Hey D,
Got a neat little project going on with audio IN the house:
One panel a night. I only have four bar clamps... :(
― Thomas Paine
