Old 07-09-2010, 12:03 AM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by Alien Mantis View Post
My favorite systems are 4-way systems.
Are you going to track down and kill that external rattle?
Would that effect your performance in a competition, or do the judges only judge the sound INSIDE the vehicle?
Just curious.
as long as they don't hear the rattle inside the car he's fine.
Old 07-09-2010, 10:15 AM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 07-13-2010, 02:19 PM   #3
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
SQ... this looks very similar to your system, the vehicle it's a little bigger though!
http://www.youtube.com/watch?v=ol9Lvxmu11Y
CLA 250, 4MATIC
Old 07-15-2010, 12:20 PM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 07-15-2010, 12:24 PM   #5
derickveliz2
Sounds like a lot! and I'm 1000+ miles behind you.
Good job!
Old 07-15-2010, 02:12 PM   #6
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Update on the scoping of the P-01...
Off the RCAs into the amps we run 6.3 Volts of unbalanced signal maxed out at 1kHz. There's something interesting I'm seeing though. The higher I go up the lower the voltage. All my EQs are flat, T/A is off...everything is flatlined.
Now onto the gains...
It appears that at 4 Volts at the RCA the L4 is seeing 127 Watts on both sides at "max". I want to set the levels at 4 Volts because of the possibility of EQ boost at top end that I might want. What I'm seeing is that the deck likes to taper the voltage off slightly on both ends (bass and tweeter ranges). At full tilt boogie (volume 62) at the 6.3 volts the ends drop around .5 to 1 Volt on either end. When I lower the volume to 60 it is a little over 4 Volts on a 1 kHz tone. I figure this is safe to set the gains to...
The L1 Pro SEs are seeing 114 Watts at 4 Volts with an 8 kHz tone at my "max"...
The ML3800 is seeing 823 watts at 4 Volts with a 40 Hz tone at my "max"...
I was really hoping for a deck that would be even with it's Voltage output. What I'm hearing from the shop owner is that this isn't uncommon though. He said he sees this in a lot of high Voltage decks.
― Thomas Paine
Old 07-15-2010, 09:07 PM   #7
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 07-16-2010, 10:45 AM   #8
derickveliz2
Sqcomp... and others what do you guys think about "Diffractions" at mid-range and tweeters?
D.
Old 07-16-2010, 11:37 AM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 07-16-2010, 11:51 AM   #10
derickveliz2
Exclamation
I found this, and thought it was interesting but don't know how much of attention it's getting from professionals.
LINK to Diffractions
Old 07-16-2010, 06:24 PM   #11
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 07-16-2010, 08:27 PM   #12
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 07-21-2010, 09:18 PM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 07-21-2010, 11:11 PM   #14
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
I like over kill......honestly it makes for a better install to keep it all nice and neat,and if you have to remove it is also not a pain to do so.....looks great man
Old 07-23-2010, 07:30 AM   #15
FcukThis
Drives: yaris
jeeeebus christ, you're running some very very sexy stuff.
FcukThis is offline   Reply With Quote
Old 07-23-2010, 11:51 AM   #16
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 07-23-2010, 08:15 PM   #17
FcukThis
Drives: yaris
Threads like these are the very reason why i got into installs in the first place.
I can't wait till you finish, it's going to be killer. You'll definitely pull in trophies, especially with that kind of attention to the smallest of details.
Wish you lived in the Seattle area, *tear* it's just so beautiful. Really wish i had you around when i was starting my install. Definitely something you're going to be proud of for the rest of your life.
Old 07-24-2010, 12:16 PM   #18
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
OH NO!... I got dibs on John, been trying to sweetly convince him to help me out for the past year.
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
Micro Image underpanel install DIY cali yaris DIY / Maintenance / Service 27 08-29-2009 09:48 PM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
where can i install these power locks? songa New England 1 12-04-2008 12:41 PM
