Old 10-22-2010, 04:46 PM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
solid state I think would be the way to go... probably more reliable.
Old 10-22-2010, 05:53 PM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 10-27-2010, 01:17 AM   #3
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 10-27-2010, 01:40 AM   #4
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Exclamation
So, I opened up the back ends and am "free air"ing the mid bass into the crumple zones. Yeah...the mid bass is BIG up front! Man those L8's move! I changed the time alignment on the sub and now it's all up front in a big way.
I believe you! even with my underpowered system I've been playing with Time Alignment on the Bachuka, and the results are amazing feels like magic.
I can imagine the feeling of the L8's must be a "Religious Experience" Like the song "Experiencia Religiosa" from Enrique Iglesias, try it it's a good song!
Why "Free Air"? did you test one side first? just curious, BTW your kick panels look so massive, I guess they need to be like that. Your friend Jim is going to send me a couple of MDF rings for my 6.5" midbass drivers so I can build kick panels.
D.
Old 11-11-2010, 11:37 AM   #5
derickveliz2
Exclamation
So let me see if I get it... (regarding the install for HAT L6s in kick panels)
You make a small kick panel big enough to fit the L6, but you leave the back open (or cut the back off) then vent into the crumple zones. Now the kick panel still attaches mechanically to the floor, but... Do you have to seal all the edges to the bear metal floor? This concept of "free air" it's a little hard for me to understand.
Thanks
D.
Old 10-27-2010, 12:18 PM   #6
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
You've got a very nice talent !!!! I'm really impress by your work!!1 Congrats (Y)
Interior:ALL red, black roof
Old 10-28-2010, 10:55 AM   #7
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 10-28-2010, 11:37 AM   #8
derickveliz2
Derick,The drivers themselves really dictate what enclosure they want to be in. I tried the closed back/sealed kick pod route. It just choked these drivers. The moment I decided to open the pod up and essentially make it a plate versus a pod...well, it was night and day.
Got it!
That is why I choose a pair of 6.5" midbass drivers specifically to work in a small sealed enclosure of 0.25 cu.feet.
So if I ever upgrade to HAT L6's I'm going to have to do the same like you did to the L8s have them free air.
Thanks
D.
Old 10-28-2010, 05:26 PM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 10-28-2010, 07:21 PM   #10
derickveliz2
The nice thing is you can do smaller kicks than I did OR you can fit them into the doors.
Smaller for sure! but NO NO!!! Not the doors!
D.
Old 10-28-2010, 07:48 PM   #11
packetrace
packetrace's Avatar
Where would you mount youre 6.5 ? make a kick panel like SQcomp did where our feet goes on the passenger side?
Old 10-28-2010, 07:58 PM   #12
derickveliz2
Yes I'm going to build kick panels, it's in my thread ... POST # 609
D.
Old 10-28-2010, 08:15 PM   #13
packetrace
packetrace's Avatar
niceee !!! waiting for Work in progress picture!!!!!
Old 10-28-2010, 08:25 PM   #14
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 10-29-2010, 07:53 AM   #15
derickveliz2
With yours Derick, I might look at anchoring THROUGH the stock kick. As a matter of fact, why don't you take off both kick panels and take a pic more directly of what's under there. You should find to molex stations...
Yes, my first option would be to use the kicks. The hard thing is the clutch pedal. If I can do an 8.5" mid bass...you can do a 6.5" mid bass.
Also, holler at me when you get the amp and sub.
Yes I'm going to attach mechanically the kicks to the frame using the threaded pin fixed to the chassis, also will drill through the wheel well and hold it mechanically too.
Yes I will contact you once I get the amp and the sub thanks.
D.
Old 10-30-2010, 01:22 PM   #16
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 10-31-2010, 02:11 AM   #17
derickveliz2
Wait...
Why do you need to drill through the wheel well? That threaded bolt will hold just fine without any other additions. It's holding my loaded kicks like a vice.
I wanted 3 points to hold on, but I guess I can live with 2!
If it's enough for the L8's my 6.5 will be a piece of cake.
Thanks
Derick
CLA 250, 4MATIC
Old 11-08-2010, 11:30 AM   #18
packetrace
packetrace's Avatar
With you two batterie upgrade....have you changed your alternator ? or keep it stock ?
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
Micro Image underpanel install DIY cali yaris DIY / Maintenance / Service 27 08-29-2009 09:48 PM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
where can i install these power locks? songa New England 1 12-04-2008 12:41 PM
