Old 11-22-2010, 09:09 AM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Exclamation
I'll have to deaden the kick pods as well as the A-pillars a lot more than they are now.
How in your opinion, how should it be applied to A-pillars and mid bass kick pods?
My answer is lead shot, sand, and resin (for materials).
What do some of you have in mind?
Well at least my self this is what I'm going to do (even though my drivers and amps are smaller than yours)...
I'm going to start with Clay, inside the spheres and kick panels. For the A-pillars I'll use CLD Tiles with some Mat. Since my spheres are mechanically attach to the a pillars I'll isolate them with some Extruded Butyl Rope to prevent vibrations and try to reinforce the way the A-pillars attach mechanically to the chassis; because the speakers and deadening add a lot of weight to them.
The Clay idea I'm not sure if it works or not, I read it online and makes sense but you guys are the PROS here, I just feel like the Clay can be removed if doesn't work, some other epoxy/glue/resin combination may be the best way to go, some times trial an error is my best friend.
I think it can't be very rigid or stiff it should dampen the vibrations, be heavy and a little flexible to tolerate changes in temperature.
Well, that's what I think, if there is a better way to approach it, let me know I don't want to re-invent (H2O)
D.
Old 11-21-2010, 08:55 PM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 11-21-2010, 09:05 PM   #3
Alien Mantis
Secret Agent
Alien Mantis's Avatar
Drives: 2008 Yaris Hatch
Thoughts?
The "Nits" are being "picked" to death.
It never ends... until you stop it.
There should be a 12-step program for this kinda stuff.
Old 11-21-2010, 11:55 PM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 11-22-2010, 11:19 AM   #5
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 11-22-2010, 11:26 AM   #6
derickveliz2
What clay are you looking at using?
I have no idea I got some at a paper store, but wanted to check what hardware stores carrie
Is there any special clay that I should use or not to?
D.
Old 11-23-2010, 11:17 AM   #7
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 11-23-2010, 04:51 PM   #8
derickveliz2
You've got advantages and disadvantages to using "clay". Modeling clay will kill vibrations but will not hold up to heat.
So it would work great inside the kick panels and not too good on the spheres/a-pillars
mmm
CLA 250, 4MATIC
Old 11-24-2010, 02:12 AM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 11-25-2010, 01:15 AM   #10
derickveliz2
probably correct.
...So you received your amp and sub? I'm seeing the pieces in your signature...
They should arrive Wednesday next week!
-me happy-
CLA 250, 4MATIC
Old 11-25-2010, 05:37 AM   #11
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 11-25-2010, 11:54 PM   #12
derickveliz2
[B]
Good good!
Now, I'd like to see those L6's installed more than anything. You realize that the equipment list you have now is vastly better and much different than what you started with? I'm particularly enjoying the contrast.
What step is next for you?
I'll start building the kick panels for the L6's once I get the MDF rings, they should be here next week.
Do I realized it???????????????
I was only going to add a small amp and a 10" subwoofer and keeping everything else OEM.
This is a product of the internet and spending way too much time behind the screen.
I don't drink or smoke or do drugs, but I do have an addiction and I'm glad it's all about YarisWorld!
My next step:... .????????? I'm already thinking about another class A/B amp to power the L6's properly maybe 150watts x 2 (instead of 60watts x2)
CLA 250, 4MATIC
Old 11-26-2010, 11:12 AM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 12-02-2010, 09:25 PM   #14
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 12-03-2010, 09:40 AM   #15
derickveliz2
How different it feels now when you close the last door open, windows up? is it harder?
I've been thinking about this for months now, I don't have the SPL you have but still, I did a second chamber on top to block outside road noise, but still will be a leak (bass)
Derick.
CLA 250, 4MATIC
Old 12-03-2010, 10:16 AM   #16
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
Old 12-03-2010, 10:52 AM   #17
derickveliz2
D,
You're probably within 3 dB of my output. How much power do you have?
The back deck used to have a "buzzing" when the bass would hit...
Right now I'm working on fitting some interior treatments for the windows while I'm in the lanes. According to the IASCA rules that I've gone through so far (I have the rulebook printed out, highlighter used), I cannot cover the front windshield. He he...It says NOTHING about the other widows...
Right now I'm running like 200 watts from the very old pioneer amp to the 10" Bachuka, will be 250 watts to the IDQ12.
That's why I made a second chamber, on the outside you can hear the Buzzing but not in the inside, and still benefit from the pressure valve, we'll see what happens with the IDQ12
Interior window treatment? looking forward to see this!
Derick
CLA 250, 4MATIC
Old 12-03-2010, 03:50 PM   #18
sqcomp
Roadrunner Jr.
sqcomp's Avatar
― Thomas Paine
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
Micro Image underpanel install DIY cali yaris DIY / Maintenance / Service 27 08-29-2009 09:48 PM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
where can i install these power locks? songa New England 1 12-04-2008 12:41 PM
