Old 06-23-2010, 01:44 PM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
SQcomp had a big hassle with his headliner because of the side curtain airbags & sensors in the way. If you have an older modle (I think pre-2010, maybe pre-2009) you shouldn't have the curtain airbags unless you bought a special package or upgrade.
If you don't have the curtain bags, just go slowly, if you do have them, you may think hard about going to a stereo shop and having them install the CLD's for you... you'll pay a ton for labor charges i'm sure, but if they mess up they have to cover it.
Old 06-28-2010, 02:07 PM   #2
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
personally, i love that sub grill cover.
Old 09-17-2010, 11:33 AM   #3
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
Update: after nearly 3 months since I completed this project, everything is still working flawlessly! No burned out fuses, nothing rattling, no nothing! The only thing is that I need to secure that sub box in the back! It keeps sliding around due to my...errr...exuberant cornering. I picked up some heavy duty Velcro that I just need to take 5 minutes and apply. Then that should be that.
I do want to replace the stock HU at some point, so in the meantime, I think I will order that Toyota replacement HU bezel to allow an aftermarket HU to fit.
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 09-17-2010, 12:16 PM   #4
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Looking forward to see it.
hey how are the rear spring stiffeners doing?
D.
Old 09-17-2010, 12:32 PM   #5
Herbicidal
Herbicidal's Avatar
I haven't checked since I put them in. I'll have to look this weekend. At the time, they raised the back end by 1/4". Honestly, I haven't really noticed a difference in the ride. I think a 1/3" to a 1/2" thick, circular, flat spacer directly under the rear springs would lift the rear of the car up by that much without affecting the spring rate.
Old 09-17-2010, 12:36 PM   #6
derickveliz2
I know what you mean, it's very relative to the TRD springs you have compare to the NF210s I have. But take them out, and then you will feel the difference.
CLA 250, 4MATIC
Old 11-18-2010, 10:48 AM   #7
Herbicidal
Herbicidal's Avatar
New head unit arrives TODAY!!! Yaaaaay!!!!
I'm so done with my stock HU and my battery powered Blue Tooth unit for my cell phone . After a bunch of research, I've decided on a Kenwood Excelon KDC-X994 (>>>link<<<).
It has B.T and a rear USB port (which I want in the back, not in the front so I can throw a thumb drive on it and forget about it) and for the price, it has outstanding adjustability and control over the "sound stage". I wanted something more minimalist in appearance so as not to attract thieves.
Here's a quote from the product research team at Crutchfield, these are just some of the features that pulled me over to this unit:
Sound Excellence DSP: In order to optimize the sound quality, you can use the Sound Excellence DSP to set the type of vehicle and speaker sizes, locations, distances and x-over points. The DSP settings include the following:
Cabin Setting: Choose from Compact, Full Size Car, Station Wagon, Mini Van, SUV, Mini Van (Long), or Off
Speaker Setting: The speaker X'over is automatically set when the position and size of each speaker are select from the following items.
Front: Location (Door, On Dash, or Under Dash); Size: (6-1/2", 6-3/4", 7", 4"x6", 5"x7", 6"x8", 6"x9", 7"x10", OEM, 4", or 5"); Tweeter (None or Use)
Rear: Location (Door, Rear Deck, 2nd Row or 3rd Row; Size (6-1/2", 6-3/4", 7", 4"x6", 5"x7", 6"x8", 6"x9", 7"x10", OEM, 4", or 5")
Subwoofer: Size(10", 12", 15", None, 6-1/2" or 8")
Digital Time Alignment (DTA): Choose from 0.00 to 14.44 feet for the Front pair of speakers, Rear pair of speakers, and Subwoofer distances in reference to the distance between your listening positioning and the locations of the particular speakers.
X'Over: The Kenwood eXcelon headunit provides independent high-pass crossovers for the unit's front and rear speaker/preamp outputs, as well as a subwoofer low-pass crossover.
Front High Pass Filter: Frequency (30, 40, 50, 60, 70, 80,90, 100, 120, 150, 180, 220, or 250Hz); Slope (-12, -18, or -24 dB per octave); or you can also select full-range
Rear High Pass Filter: Frequency (30, 40, 50, 60, 70, 80, 90, 100, 120, 150, 180, 220, or 250Hz); Slope (-12, -18, or -24 dB per octave); you can also select full-range
Subwoofer Low Pass Filter: Frequency (30, 40, 50, 60, 70, 80, 90, 100, 120, 150, 180, 220, or 250 Hz); Slope (-12, -18, or -24 dB per octave); Phase (Normal/Reverse); or you can also select full-range
Equalizer Control: Equalizer Control allows you to use one of the System Q presets, or set your own custom settings using the 5-band Equalizer. The EQ adjustments are as follows:
Preset EQ: You can select from Natural, Rock, Pops, Easy, Top 40, Jazz, Game, iPod (you can select from 22 EQ curve types), or User.
5-Band EQ: The User mode allows you to adjust the following 5-Band EQ (62.5Hz, 250Hz, 1kHz, 4kHz, 16kHz) settings.
Band Levels: Independent front and rear EQ level of -9dB to +9dB.
Bass Effect: Enhances the bass response of Band 1 (62.5Hz).
Position Control: For a better sound-stage you can select your optimal listening position. You can choose from All, Front Left, Front Right or Front. You can also select to manually fine tune the sound stage by selecting the distance for each individual speaker in the vehicle compared to your listening position. You can select between 0.00 to 5.58 feet for the Left Front Speaker, Right Front Speaker, Left Rear Speaker, Right Rear Speaker, Left Subwoofer and/or Right Subwoofer.
Plus: 24 Bit D/A Converter: The Kenwood eXcelon KDC-X994 utilizes a 24-bit digital to analog converter for superior CD sound quality.
Additionally, there is free sofware I can download from Kenwood for the USB device:
Music Editor Compatible: The Kenwood KDC-X994 supports the PC application, Kenwood Music Editor Lite (ver.l.0 or later). Kenwood Music Editor Lite is a desktop software that helps organize, manage and transfer AAC, MP3, and WMA music files to your USB devices from your PC. When you playback audio files that have been stored on your USB device using Kenwood Music Editor Lite (ver.l.0) through this unit, you can search a file by title, album, or artist name using the headunit's Music Search function.
This guy should really help all my other components shine! After install, I'm going to have to reset everything on the amps and re-tune the whole system. I'm actually looking forward to it! And I thought it sounded good with the stock HU!
Old 11-18-2010, 12:28 PM   #8
derickveliz2
Congratulations!
with x-over features you only need to match gain the amps. By pass every thing else.
D.
Old 11-18-2010, 01:36 PM   #9
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
The 794 has basically the same options, i've spent about an hour of tuning and wow, these things have settings out the Ying Yang. Congrats on the buy !
Old 11-18-2010, 01:45 PM   #10
Herbicidal
Herbicidal's Avatar
Thanks guys! I'm really psyched about getting it! I've got a busy weekend ahead, but I hope to at least get it hooked up. The 'tuning' will come later.
_S7V7N_ - good luck with your tuning! Sounds (no pun intended) like you are pleased with your unit.
Old 11-18-2010, 07:45 PM   #11
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Now you guys know about some of the crossover and EQ capabilites Derick and I are faced with...
Add in a complete 1/3 Octave and another pre out...
― Thomas Paine
Old 11-19-2010, 12:11 AM   #12
Herbicidal
Herbicidal's Avatar
Yeah, I think I will stay at my level. Even with my relatively low-end components it will be the best system I've ever owned and I'm good with that. Especially since I did all the work myself.
Old 11-19-2010, 12:14 AM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I applaud the DIY work!
― Thomas Paine
Old 11-19-2010, 02:10 AM   #14
derickveliz2
There is nothing better than the feeling of doing it your self!
Old 11-19-2010, 10:33 AM   #15
Herbicidal
Herbicidal's Avatar
Yeah, I do too! You guys, however, took THAT to the next level and beyond!!! Way to go!
Old 11-19-2010, 10:58 AM   #16
Herbicidal
Herbicidal's Avatar
Oh, I did get the new Toyota bezel that gives me the double DIN opening since I have the factory integrated radio. I did a quick test fit of what came from Crutchfield and it fits the Toyota bezel perfectly! Whew! Now it should be pretty much plug and play.
Oh yeah, this little jewel (which served it's purpose) will be coming out too!
Now I'll be able to take advantage of the RCA outputs on the new deck and go right to the Eclipse amps. My little system will be able to breathe!!!!
Old 12-02-2010, 12:17 PM   #17
Herbicidal
Herbicidal's Avatar
I've installed my Kenwood HU and it has TONS of adjustability. I've barely scratched the surface. My two amps (Eclipse EA4200 and the Eclipse XA1200600W) both have adjustability for the crossover's and bass boost as shown in the pictures below. Since my new HU has built in control over ALL these functions, should I "zero out" the amps and do ALL the tuning through the HU? Looking for suggestions. Thanks!
XA-1200:
EA-4200:
Old 12-02-2010, 12:31 PM   #18
derickveliz2
In theory you would "by pass" the X-over and only adjust the Input Levels AKA Gains
In your amp I don't see an option to go "full" like in my amp.
But I'm sure the Masters will correct me if I'm wrong and give a proper answer
CLA 250, 4MATIC
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Rines 15 Yaris Sedan 2008 Marko_ec Central and South America 4 12-15-2008 03:02 PM
