Old 10-05-2010, 11:58 AM   #1
^ open loop doesn't kick in at a psi. It kicks in when the ECU senses a certain load, 75% throttle in our case, and maybe under some other conditions, I don't know.
Old 10-05-2010, 12:34 PM   #2
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Right, but wouldn't there be some sort of a trend where open loop usually kicks in? Or can you just floor it, be outside of boost still, and throw the car into open loop?
...Am I just not driving my car hard enough? lol
Focus_Sh1ft is offline   Reply With Quote
Old 10-05-2010, 12:49 PM   #3
we actually brainstormed and did some research about this a few years back, if you wanna take the time to sift through it:
http://www.yarisworld.com/forums/showthread.php?t=15350
http://www.yarisworld.com/forums/showthread.php?t=21431
Pay close attention to the excel files linked, PK did some good data logging, and yes, no matter what your car is doing, what gear you're in, mash the throttle past the 75% signal and it'll go open loop.
In my mind, the ideal "simple" setup around open and closed loop would be what I call the Jekyll and Hyde approach. A boost controller set up for very gentle boost (maybe 5psi) for use during closed loop operation, and higher boost for open loop, and this would be triggered by the throttle position sensor. Add to that a piggyback that can also have different profiles based on throttle input (such as the apexi SAFC mentioned in the second link above), so that it'll let the ECU do its thing in closed loop, but then mess with things once the throttle goes past 75%.
So, driving "normally", you get the benefit of added power without reaching the limits of the engine/ECU, but when you put your foot down, then you get extra boost, and the piggyback to provide more appropriate fuelling, to unleash the beast within
Old 10-06-2010, 01:02 AM   #4
we're going to figure this out this time around. I need my car running safely, and that turbo ain't coming out.
That's the spirit
Old 10-06-2010, 12:56 PM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I don't think you can do that with TBW. If the ECU sees more than what's input and the output of the throttle plate doesn't match, it'll go into failsafe.
Old 10-07-2010, 02:01 PM   #6
another (cheaper) piece of electronics to fiddle around with the MAF signal in open loop, the HKS AFR (Air Fuel Regulator). Very simple little box with a dial for the degree of adjustment of the MAF signal (leaner or richer). Nowhere as precise as a proper piggyback, as there is no RPM-specific or throttle-specific arrangement, but it could work well to get an *overall* richer or leaner fuel mix while in open loop, similar effect to getting bigger injectors, I suppose!
Old 10-11-2010, 11:16 AM   #7
Focus_Sh1ft
No updates on tuning unfortunately, haven't had time to deal with it yet. However, I did redo my oil pan as per Garm's observation about the removable stems. No leaks from it now
Unbelievably though, I'm now back to dealing with coolant leaks. I don't know what the hell I'm doing wrong. I switched to M12 adapters that fit on the turbo VERY snug, but yet they still leak! I was so pissed when I noticed this yesterday, because I really don't know where to go from here. I'm thinking about just yanking water cooling
The only thought I had was that the hole on the adapters is too small and is creating a huge pressure buildup, which causes the coolant to back out through the threads. I have some pictures, but they suck. Basically, the diameter of the holes is about half of the lines I'm using. The adapters were really meant to be used for getting a pressure reading for a gauge. What do you guys think?
This is all getting incredibly frustrating... I just don't have time to deal with this BS over and over again with my classes. Oh, and I'm not even going to begin on how impossible it was to get those stems off. Unless you have an M4 female torx socket, you're practically SOL.
Old 10-11-2010, 11:40 AM   #8
Focus_Sh1ft
Oh yeah also - read somewhere (MI?) that a 10% underdrive pulley decreases max boost obtainable or something?
Explain?
Old 10-15-2010, 10:48 AM   #9
Focus_Sh1ft
Here's some updates for anyone wondering.
I'm now 100% sure the size of the adapters needed for water cooling are M12x1.25. I'm currently running M12x1.0 with some high temp silicone sealant and I guess it's working.
Believe it or not, but after nearly two weeks of no CELs, P0101 has come back. I've cleared it and it continues to return. Confusing? Yes.
I bought a used AEM meth kit for $180 shipped.
It'll be sitting around for a couple months, but I had money in paypal I needed to spend and that was a decent deal.
This week, I'll be continuing to work with the FIC. The first thing I'm going to do is get the O2 wire hooked up and see how much I can manipulate the signal before I start getting CELs. I've thought about it, and that + a MAF clamp could very well work to get a decent AFR in closed loop.
Old 10-20-2010, 11:13 AM   #10
Focus_Sh1ft
Hey guys...
Why the hell is there oil in my intercooler? lol
It's not a lot, and it seems like it's been there for awhile. Could it be from when my return was clogged?
Old 10-11-2010, 11:57 AM   #11
only for a supercharger, which is belt-driven ;)
Old 10-11-2010, 12:12 PM   #12
underdrive pulley makes the supercharger pulley turn more slowly, DEcreasing boost.
no worries for you.
just YANK the water cooling and add it later. Just means you have to idle the car when you park it for now. Minimize your frustration!
Old 10-11-2010, 12:14 PM   #13
sleey0
Drives: 2008 Yaris LB
So if u yank the water cooling won't it overheat?
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-11-2010, 11:05 PM   #14
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
it is also oil cooled, the water cooling was just a backup so you could abuse the turbo and not worry.
Colin Chapman disciple
Old 10-12-2010, 05:21 AM   #15
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
As I was reading the last 2 pages it seems like there is a big ? on O2 Control, Open/ Closed loop etc...
Since now I am studying into standalone ecu management systems all this big questions aren't a taboo for me anymore.
The only issue with the information I am going to mention is that eventually I don't know for sure if the Toyota Stock Ecu works exactly the same but at least you can have something to refer on man
Below is a tab of information on my Platinum Sport ecu for my wideband. All settings are critical to have a good working engine at all conditions :
1. There are two types, Wideband and Narrowband. Usually wideband sensors are able to adjust fuel at higher rpm than narrow band
2. Target Voltage
- Only valid for Narrowband sensors. This is the sensor voltage that the ECU will try to target. This should be between the two voltages that the sensor outputs for below stoichiometric and above stoichiometric. Setting this target too close to either of these voltages may lead the controller to not function.
3. Idle Target Voltage
- Only valid for Narrowband sensors. This is usually set slightly higher than the above target voltage to help richen the idle mixtures to aid in idle smoothness.
4. Maximum Increase
- Maximum percentage increase in fuel that is allowed by the O2 controller. (Max 25%).
5. Maximum Decrease
- Maximum percentage decrease in fuel that is allowed by the O2 controller. (Max 25%).
6. Proportional Control
- This value alters the gain or sensitivity of the controller. The Proportional Control affect the sensitvity of the short term control.
7. Integral Control
- This value alters the gain or sensitivity of the controller. The Integral Control affect the sensitivity of the long term trim.
8. Sample Rate
- The rate at which the controller will read the O2 sensor and calculate the correction when above the idle RPM. If this is set too fast, the controller will over-react and a very unstable control will result. If this is set too slow, then the O2 controller will be slow to move towards its target and may not achieve the slight oscillations that are desirable.
9. Idle Sample Rate
- The rate at which the controller will read the O2 sensor and calculate the correction when below the idle RPM. If this is set too fast, the controller will over-react and a very unstable control will result. If this is set too slow, then the O2 controller will be slow to move towards its target and may not achieve the slight oscillations that are desirable.
10. Post Start Delay
- A cold O2 sensor voltage reading is always low. Set this value so that the sensor has enough time to reach operating temperature.
11. Delay Till Control
- This setting will delay when the closed loop O2 control will start when all the conditions are met. This helps the controller stop cutting in and out when on the border of one of the conditions that need to be satisfied.
12. Lower RPM
- The minimum RPM at which O2 control will happen. If this value is greater than this value then O2 control at idle will be disabled.
13. Idle RPM
- When the engine speed is below this value and there is zero throttle then the O2 Target Idle Voltage is used. To disable the use of this parameter then set it lower than the Low RPM value.
14. Upper RPM
- The maximum RPM at which O2 control will happen. Having O2 control off at RPM may be desirable if you are running a narrow band sensor.
15. Operating Temperature
- O2 control will only work above this coolant temperature.
16. Limit Select
- Choose if TPS or MAP sensor or Both will disable O2 control. If set to Both, then only one condition has to fail for O2 control to be disabled.
17. MAP Limit
- If load select is MAP or both, any MAP senor reading above this value disables O2 control.
18. Throttle Limit
- If load select is TPS or both, any throttle position above this percentage disables O2 control
Regarding open/closed loop situation. If one of these settings are above or below limits the system begins to get reference on a fuel basemap set by a tuner and that would be open loop. If all is within range then you are closed loop.
As I said, Toyota could have different, less or more settings in their own ecu so just keep this info just for your reference on not a 100% info yours works exactly with the same setup.
Cheers
Old 10-12-2010, 09:28 AM   #16
Sensors don't adjust anything?
Old 10-12-2010, 09:33 AM   #17
I think he meant "detect", in terms of giving more accurate information in order to make adjustments :)
Old 10-12-2010, 11:55 AM   #18
Wideband is faster sampling for one thing, therefore more responsive on the gauge. Maybe he meant that.
FS: Autometer Cobalt 6170 Boost Gauge Nexus1155 Items for Sale by private party 2 02-02-2011 04:08 PM
Multiple cylinder misfire under boost LtNoogie Forced Induction Forum 13 11-02-2009 04:44 AM
Fill up with Super before starting your boost project LtNoogie Forced Induction Forum 5 12-01-2008 06:41 PM
Supercharger Selection and Limiting Boost Nexus1155 Forced Induction Forum 1 12-01-2008 03:51 PM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 02:42 PM
