^ Yes. Did Peterpoop happen to mention that I'm the one who told him that recently? LOL
An example using World Electronics (Chris Rado) boost controller:
Micro Image forums, online store and shop are now closed. It was a great eight year run, but it was time to focus on other things. I'm still selling parts on eBay under micro*image seller ID and customers can still make requests for anything specific. Last edited by cali yaris; 10-30-2010 at 01:01 AM. |
Yes Garm.
My only question is why didn't someone point this out sooner? This seems like a huge improvement. Even that figure shows a stupid amount of additional power being made. Gonna look into some electronic ones. Any suggestions? |
Yes Garm, I mentioned you! My guru. lol. Bring those zage kits in! Let's do this
haha "Guru", I just learned from other people, I think we all do.
Focus, no one ever asked a question about boost controllers before. "the truth is out there" -- if you know how to Google.
I have a bit of a conundrum...
My car is stuck in open loop all of the sudden. I have no idea why it is, but now I can't boost because it goes LEAN. Anyone have any ideas why it suddenly decided to stay in open loop? My thought is it has something to do with driving cycles and the ECU seeing boost, as this is the longest I've driven without pulling terminals off the battery. I'm sure I could probably do just that and it would reset, but this is certainly a curious case. No CELs either, and my turbo timer is getting feedback from the AFR sensor still. |
Ok this situation is baffling, but incredibly awesome. My car is still doing the same thing. I pulled the AFR plug just to make sure the ECU throws a CEL, and it does. So... Something is happening that's forcing the car into open loop without any CELs! This is an optimal situation, and I wish I could figure out why it's happening for future reference. I have no idea where to even begin looking though.
I'm going to just tune the car instead of resetting the battery. If it swaps back to closed loop at some point - no biggie. EDIT: As soon as I plugged my FIC back in and started the car, the issue resolved itself. I'm still clueless as to what I just witnessed, but I would love to find out. There must have been some criteria the engine failed to meet to throw itself into closed loop. The catch would seem that whatever it is doesn't cause a code though... Oh and also - I was reading the service manual and noticed the AFR sensor heater operates between .9 and 10 Amps. A code is thrown if the current drops below .8A. Could it be possible to greatly limit the current that reaches the heater? My thought is that maybe, just maybe, we could limit its performance enough to prevent the AFR sensor from functioning correctly, thus putting the car in open loop. Last edited by Focus_Sh1ft; 10-31-2010 at 11:30 PM. |
I'm assuming no one understands what the hell I've been talking about lol.
Anyways, there must be something wrong with my AFR sensor. Started the car up today, and it did the open loop thing. It started open, warmed up, went closed, then around 115F water temp it opened again. ![]() Pulled my FIC bypass plug, put it back in, problem solved. Drove to class and got P2238 when I was almost there. The car went open loop, I cleared the code, and back to closed. On the way home, no code but it just suddenly got stuck in open loop again. The whole thing is so strange, but I can't be bothered with crap like this. I've pulled my AFR sensor plug and am going to tune the car in open loop. I should have done this awhile ago, instead of messing around with the FIC. This is tried and true, and a CEL that doesn't cause limp isn't the end of the world. |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
Sounds very similar to my problems. My car stayed in closed loop but my factory O2 sensor was going wacky. While driving it was OK but when hot at idle it was very slow to respond. Sometimes it would go so lean it would dye out. I think the location of the o2 had something to do with it. Mabe if it was located before the turbo it would be OK. I have removed the o2 sensor and tuned in open loop. Much better now. Still need some bigger squirters though.
^ Excellent! I got five more Zage kits in today.
![]() ![]() ![]() Drives: 2010 Yaris Bayou Blue 3DR Lift Join Date: Sep 2010
^ so it isn't closing tight enough, right?
I read somewhere that its the air recirculating and pushing the turbo blades backwards. someone was saying that it isn't THAT bad on a small amount of boost?
C'est la vie
I think peterpoop is right. The flutter sound is compressor surge [air going back through turbo blades]. IE: the bov may be a little tight. Mine was set to loose and my engine kept dying out because it was leaking out to much metered air and I went way rich. I tightened up the spring and now I get some flutter before I get the air rush sound when it opens. But now it almost never dyes out. I dont think a little flutter will hurt as long as when your on the gas hard you hear it open when you let off. Its hard to imagine the whole automatic trans. situation.
I've been playing around with my manual boost controller the last few days and haven't seen any noticeable improvement in spooling unfortunately, but I'll keep at it.
Was wondering about this though.... If my PCV hose has a kink in it, that would cause blow-by and oil in the intake, right? I'm thinking that's the reason I found oil in the intercooler. Looks like it could also be related to my P0101 code. |
#16 | |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Oil return
Left pic incorrect way, pic on right correct way
OilLine2.jpg |
The more I think about it, the more I think you're right...
PCV being clogged can't get oil in the charge piping, especially when there's none in the MAF piping. So this means one of two things. Either the oil level issue, or my seals are blown. I don't want to accept the latter, but I don't think that's the case anyways because I'd have lost more oil (?). I'm going to tap my block sometime this week. We'll see what happens. |
| FS: Autometer Cobalt 6170 Boost Gauge | Nexus1155 | Items for Sale by private party | 2 | 02-02-2011 04:08 PM |
| Multiple cylinder misfire under boost | LtNoogie | Forced Induction Forum | 13 | 11-02-2009 04:44 AM |
| Fill up with Super before starting your boost project | LtNoogie | Forced Induction Forum | 5 | 12-01-2008 06:41 PM |
| Supercharger Selection and Limiting Boost | Nexus1155 | Forced Induction Forum | 1 | 12-01-2008 03:51 PM |
| WTB: Boost Gauges | Teruyume | Items for Sale by private party | 4 | 11-12-2006 02:42 PM |
