Old 10-12-2010, 09:08 PM   #1
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
^ Yep, eBay for mine. I swear the UPS tracking said it was in Anchorage yesterday. How'd it get thousands of miles in one day? Especially to South Jesus!
chrisj is offline   Reply With Quote
Old 10-13-2010, 08:37 AM   #2
enve1160
Drives: yaris
chrisj did yours have the harness for the rca outs? Looks like Dragracer didnt come with one.
I need this harness since mine will be connected to a 4 ch. amp.
enve1160 is offline   Reply With Quote
Old 10-13-2010, 10:27 AM   #3
chrisj
chrisj's Avatar
Yeah, there was thing huge harness of RCA jacks with caps on each one (about 8 or so) that I will plug into the back. I also got a camera with mine, but the cord is short and I have no idea where I would put it.
The back of mine looks exactly like Toys. Lotsa wires, GPS antenna, and stuff with it.
In the top picture, the left connector is for steering wheel controls, which I don't have. The wires for that came too though.
Old 10-13-2010, 03:13 PM   #4
chrisj
chrisj's Avatar
Just got mine installed. Factory fit and all the features that Toy showed before, so I won't bore you with them again.
I routed the iPod and USB cables into the bottom glove compartment until I figure out if I want to move them somewhere else. The GPS antenna still needs to be attached with 3M tape on the dash (ran that wire through the glove box also). I have the MicroSD of the GPS software that still has to be loaded as well. I like it.
Took about 15 minutes to do.
Some pictures below.
Old 10-24-2010, 03:40 PM   #5
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
congrats chrisj!
mine is still running smoothly, no issues and still luvin it. love the fact it has all the multimedia capabilities on the go - truly feature rich.
Old 10-13-2010, 04:07 PM   #6
Dragracer
Yaris Noobie
Dragracer's Avatar
Drives: 2010 Yaris 3 Door
It's there.
Calling an illegal immigrant an undocumented worker, is like calling the corner drug dealer an unlicensed Pharmacist.
Dragracer is offline   Reply With Quote
Old 10-13-2010, 10:20 AM   #7
sleey0
Drives: 2008 Yaris LB
Wow.
Dragracer- that thing looks high quality. did you measure it and make SURE it's 200mm wide?
Also can you take shots of the back and is that all it came with? I don't see many cables? BACK SHOT OF UNIT PLEASE!! lol
Lastly, is there an item # or model # on it anywhere?
Thanks!
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-13-2010, 04:57 PM   #8
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
That just looks soooo good. I'm salivating I want one so bad. Wish I could afford one right now but its on my short list of things I will be getting some day. Congrats on getting it installed and lookin' good!
PS> Is there the ability to hook up the little Aux port between the seats to this HU? Would be nice to still be able to use that if needed.
Old 10-13-2010, 05:28 PM   #9
chrisj
chrisj's Avatar
^ Thanks. I'm sure there is a way to hook up the AUX because on the menu is a selection for AUX. There are TONS of wires coming out of the back that I didn't use.
Old 10-13-2010, 06:10 PM   #10
chrisj
chrisj's Avatar
I am having extreme issues with the GPS part of mine. I have the chip and I stick it in the right MicroSD slot. Don't know why there is a right and left one. Anyway, how do I get the GPS software into the unit, or does the card have to stay in all the time? I was playing music on one of my MicroSD cards in the right slot, and that worked fine.
The left MicroSD slot says GPS under it, and the right one says DVD under that one. That manual is a joke, really. I go into setup and it says it cannot find the GPS software. Just wondering the procedure for using the GPS software.
Old 10-13-2010, 06:11 PM   #11
sickpuppy1
Drives: 2010 Yaris Sedan
Dang I wish I could find one of these with HD radio........
Old 10-13-2010, 06:32 PM   #12
chrisj
chrisj's Avatar
I got it. I have the GPS software in the left slot and my SD card in the right. It works.
Old 10-13-2010, 07:29 PM   #13
sickpuppy1
Do you need to leave the card in the slot or does it just load from that slot?
Old 10-13-2010, 09:27 PM   #14
Dragracer
Yaris Noobie
Dragracer's Avatar
Mine is installed! What a freaking nightmare!
The basic install was not too bad. I had to slot the original mounting brackets as the radio set too far forward. Once I did that, the install was easy. I mounted the GPS antenna on the black plastic filler under the wipers. I already had the XM radio antenna mounted there. The GPS antenna is similar in size and shape, and both blend in very well. Photos are below.
The manual SUCKS! It took me forever to figure out how to pair my phone to the radio via blue tooth. Then the GPS came up in Chinese even though the language was set to English, and all other functions were in English. Finally figured out the GPS didn't know where to find the software. After programing in the sd card to the gps, all is well!
On mine there is a pink wire marked "park". This wire must be grounded to get a dvd to show up on the screen.
Here's where my XM antenna is mounted.
Here's the GPS antenna mounted there as well.
Here it is installed and running.
And here's a photo of the back of the unit.
I'm having a drink now!
Old 11-02-2010, 03:05 AM   #15
amanda_84
Drives: 2010 Toyota Yaris YR
Send a message via MSN to amanda_84
Hi, i'm wondering how you mounted the GPS antennae under the wipers as id really like to do this but I've not really don't much in tinkering to cars! Did you have to drill a hole or 'grommet' somewhere to thread it through?? (I don't even really know what a grommet is!).
Also...does any one know if the pre-loaded GPS software is upgradeable? OP said he put different GPS maps on a bigger card - how do you get the maps?
cheers for any help guys,
Amanda
P.s. I'm about to go install the HD now yippeee
amanda_84 is offline   Reply With Quote
Old 10-14-2010, 12:26 AM   #16
chrisj
chrisj's Avatar
I don't know. I need to test that tomorrow (was getting dark on me). There are 2 slots, one on the left and one on the right. On the right one I have my music, videos, etc. The left one has the GPS software stick in it. If I have to leave it, I don't mind. It's not in the way.
Old 10-15-2010, 10:14 PM   #17
hyprmiler
It's cold in Wisconsin...
Drives: 2008 and 2009 Yaris Sedans
I have a 2008 and 2009 sedan, will this work for me? What parts do I need (silver plastics) to cover / go around the unit
hyprmiler is offline   Reply With Quote
Old 10-14-2010, 12:24 AM   #18
chrisj
chrisj's Avatar
^ Good job, Dragracer! Looks good! I was a little skittish for a second, peeling that trim up and away, and I just KNEW it was never gonna go back on right, but it did. I am happy with mine too! :)
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Decent eBay deal on harness and double DIN kit Sodium Duck In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2009 12:04 AM
