welshdodger
Drives: toyoto yaris Join Date: Nov 2010
Multimedia Player
Hi to you all at Toyoto yaris forum
This is my second time i tried to upload this info the first time seems to dissappered I have bought a Multimedia Player like the one's you all shown I read the 16 pages on how to replace a works radio with the Multimedia Player, and with your great pic's i can see how to remove the unit and replace it with mine. The question i have is there,s no pic's of the back of the radio comming out with all the plugs On my Multimedia Player unit i have a load of female Phono plugs for speakers, Is there a load of male Phono plugs ready on the yaris for me to plug into, or do i use them at all. i going to uplload pic's of my Multimedia Player unit any help with please thanks rognewton Last edited by rognewton; 11-09-2010 at 01:19 PM. Reason: add pic's |
welshdodger
Multimedia Player
Hello all at toyota yaris forums
I cant work out how to add Pic,s to my Post i have managed to add Pic' to attachments i dont know this will work if any one can help thanks rognewton back.jpg backharness.jpg frount1.jpg harnes.jpg plans1.jpg topplans.jpg back.jpg backharness.jpg |
#3 | |
![]() ![]() Drives: toyota yaris Join Date: Jul 2010
Where did you buy yours and for how much? are you still happy with it? thanks brendan
Your standard speaker connections are made through the two wiring harnesses that are wrapped in foam. These will (should) just plug straight into the existing harness behind your dash.
All the other 'stuff' is for external devices such as DVD screens, backup cameras, iPods, etc. The grey and black extra speaker wires are probably of no concern to you at this time. Hope that helps you out some.
welshdodger
Thanks WeeYari,
I been puting off fiting this unit, just in case i messed up thanks for your advice rognewton |
welshdodger
Multimedia Player
hello all
Thanks WeeYari for your advice. I Need more advice I have started to swap my unit only to find thad the aerial lead has a recancle box with 2 wires attached wihch fits into the back of my radio not the standed round plug. The 2 two leads come from the same trunking one which is a small coaxal lead standed areial lead, the other thiner finer black lead thats attached to the recancle box to seprate pin Any help with this please rognewton |
![]() Drives: yaris Join Date: Jun 2010
Can u post a pic of what your having issues with. Im having a hard time understanding.
#8 | |
I really do hope this is what you are talking about. If not, post up quick.
welshdodger
Multimedia Player
Thanks for advice,
i am going to upload pic,s of the aerial plug plus the back of the radio that came with the car I think your right WeeYari that the other small black cable is for the power antenna When i tested the aerial out on my new unit the radio worked,but the EJECT on the CD PLAYER and STEERING COULUM controls did not work on the new unit. Replaced my old radio and EJECT and STEERING COULUM worked. Before i join the black lead to the blue POWER ANTENNA lead in the harness will there be problems like my new unit blowing up [/COLOR] I will email my supplier for help as well thanks to you all for your help aerial1.jpg aerial.jpg aerial2.jpg radio.jpg radio1.jpg |
So I installed my gps that i bought from ebay. Hooked it up to my 4 channel amp with infinity reference speakers. I am very impressed with the sound quality. No static/ engine noise. Very clean signal coming out of the RCA's. Now after a week of messing with it I found a few flaws with my unit.
First, I cant get the color of the knobs / LEDs to change to any color. They are all red. I need them to be green. The option for changing color does not let me change it. I dont know if any other settings are not letting this to enable the led color change. Second, the radio reception is bad. Picks up alot of static. Third, DVD player seems to freeze at random times for no more than 5 seconds. Im not sure if its because of bumps on the road or what. I also sat on my driveway to watch a movie and notice it doing the same thing, but it seemed like it would freeze for a couple seconds when it changed chapters. Other than what i mentioned everything else works great. The only thing I havnt messed with is the ipod connection. By the way I had to edit this post. I mentioned that the music from the sdcard sound harsh and overpowering, well it turned out the dvd gain controls the sd card gain.
Try turning you car lights on....I did this and then the other lights came on and I was able to change the colours...
welshdodger
Multimedia Player
Hi all at the Yaris Forums
Still need help with the new Multimedia Player. I have uploaded pictures of the new aerial system for yaris 2010 can any body confirm that the small black wire attached to the new recangle box next to the coaxed aerial is a power antenna wire and can i join this to my harness power antenna blue wire When i tested the new Multimedia Player without this wire i could not get my CD PLAYER to eject or my stearing wheel controls to work on the new Multimedia Player So for now i replaced my works radio As i dont wont to blow my new unit if i wrong hope some one can help thanks to those who have rognewton |
1 - Yes, the black wire will be the antenna power.
2 - Does this unit say it actually supports steering wheel control? I don't see any connectors for steering controls. 3 - Don't know what to say about your CD eject issue. Also, I think you should start your own thread. Your head unit is not the same as the one featured in this thread, and you've got your own unique circumstances to address.
Didnt someone else have a thread about this? European antenna being different than the US? Could be wrong. Where is CT Scot when ya need him,LOL
^ I think you may be thinking of a thread in which the OP had a similar question. It was European yes, but the vehicle involved was a 1st gen Yaris with a non-amplified antenna.
http://www.yarisworld.com/forums/sho...16&postcount=9
welshdodger
Multimedia Player
Thanks WeeYari for your advice again,
and others from the Forum Yes you are probably right about the power antenna I have had a reply from the people who supplied the unit asking me to sent pictures and give details of the proplems If i get some real answers off them, and manage to fix, and get the unit to work propley I will set up a full how to with pic's on the forum other wise, i will sell it on thanks all for your help rognewton |
![]() Drives: '09 Yaris Sedan Join Date: Oct 2010
can i get a link to where i can order the HU?
I realize there are a lot of posts in this thread, but there are already numerous links to ebay providers in here.
| ACRONYM thread | Shroomster | Off-topic / Other Cars / Everything else Discussions | 45 | 02-15-2025 10:30 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| Decent eBay deal on harness and double DIN kit | Sodium Duck | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2009 12:04 AM |
