Old 12-12-2011, 02:33 AM   #1
boggydee
Drives: 2009 yaris 4dr hb
sorry guys for re-opening this thread... but doe anyone know where I can get wat toy got... with the gps, sdcards, bluetooth and remote? I cant find it anywhere on ebay... =/
boggydee is offline   Reply With Quote
Old 12-13-2011, 11:49 AM   #2
BennyLava
Drives: 1987 Silverado
Anyone know if you can use an aftermarket bluetooth in the aux slot of this unit? Somehow?
BennyLava is offline   Reply With Quote
Old 12-16-2011, 09:27 PM   #3
grelise
Drives: 07 YR Yaris 5dr Hatch
This the one I recently got for the car off ebay,
So far, quite happy with it, missus loves it.
Also, does anyone elses after a couple of seconds, on start up or turn on, give a little chirp before it continues as normal?
It's something I noticed first, but doesn't annoy me, just curious.
grelise is offline   Reply With Quote
Old 01-27-2012, 02:25 AM   #4
Spidermandud
Spidermandud's Avatar
Drives: Black '08 Yaris Hatch S
My unit's been doing great for months now, and then spontaneously it resets itself after a trip to Nashville from the 'boro. That didn't bother me any; i even learned some new stuff about the unit's gps as i getting all the options reset. . . . . However. The voice option is no longer the UK Thomas; but the Alima . . . spanish? . . . voice. Whenever I attempt to move up the menu to change it; an error pops up on the screen, and won't allow me to progress. When I click okay, it resets the GPS as well.
. . . Wondering if anyone else has had this issue to solve.
Edit:
I put the SD card up on my computer; deleted all the non english voices. I don't plan on needing my gps to speak dutch to me anywho. Put it back in; works great again. I'm taking a shot in the dark and saying one of the voice files was corrupted and when it tried to load it as I moved through the voices it would pop the error.
-Will-
Last edited by Spidermandud; 01-27-2012 at 02:59 AM. Reason: Figured something out; not sure what.
Spidermandud is offline   Reply With Quote
Old 01-30-2012, 07:13 PM   #5
Spidermandud
By any chance does anyone know how to change the buttons on the home screen? Their color or style or anything? Not the LED's, just the buttons, aux input, tv, dvd, etc.
Thanks in advance
-Will-
Old 02-22-2012, 06:10 AM   #6
nicodu78
Drives: Yaris 1 TS Ph2-Yaris 2 TS Ph1
Originally Posted by greyger View Post
Hi, there is no fan on the rear panel. It is only the opening (the hole) is present. I make a picture and post it here later.
Can you tell us more about GPS ? Where do you put the antenna ? Where is the sd card ?
Can you tell us more about USB ? Where is the connector ?
Where do you buy your product ?
Thanks.
nicodu78 is offline   Reply With Quote
Old 03-11-2012, 03:03 PM   #7
Spidermandud
I don't know specifically about that model; but the antenna on the first one in this thread the "Toy Toronto Especial" the gps is strong enough that you can leave it hanging behind the unit and it still picks up; but the common thing seems to be to route it to your glove box, or to your dash. It looks to me like on that unit they have the slots for the gps card and sd card covered by markers on the left and right of the unit. The USB connector should be in the back, and you would route it (likely) to the glove box or wherever you wanted. This one is the ebay model I think; just go to ebay and search "yaris gps"
-Will-
Old 03-25-2012, 06:14 AM   #8
Speedz
Will work for Yaris...
Speedz's Avatar
Drives: Yaris
Any one there tried this headunit before?
Just wondering if they are worth it and since its less than $300 bucks, wondering if the audio is better than stock...?
Speedz is offline   Reply With Quote
Old 04-28-2012, 03:01 AM   #9
Spidermandud
Looks like most the ones in this thread. Assuming it has the Toyota wiring hookup doo-dads it should be a bit better than the stock stereo. The one I installed which is the same as Toy Toronto's ended up being much louder, though I think the best way to get your sound quality better is through sound deadening and better speakers.
-Will-
Old 05-01-2012, 07:40 PM   #10
BennyLava
Alright guys, time for a final review of this unit. Short, simple, and done by me.
Its a wonderful unit for the price. You won't find better for the price. Everything works very very well save for just a few small inconveniences.
I can get over the volume of the bluetooth not being tied to the volume of the radio. In fact I've been able to tone it down so at least the radio isn't ear splitting when you hang up the phone on a bluetooth call. The sound quality of the voice calls on both ends could certainly use improvement as well. On both ends it sounds like you're on speakerphone, cause basically you are. But, there are some units out there that work to cancel this effect and clean up the sound quality when using bluetooth. This unit isn't one of them.
The sun is also a big problem for this unit. Yeah that's right, the sun. When you are driving around in daylight and the sun is on the screen, you may as well not have this unit. Hope you like whatever the unit is currently doing at that time lol. Cause you're not going to be able to see what's on the screen due to the horrendous glare.
There is a word for this in the screen world, I forget what it was exactly. But MOST companies in the automotive screen industry work to eliminate this effect. These people just completely forgot it existed. So to wrap things up:
Pros:
1. Excellent unit for the price. Does everything you'd want even a drastically more expensive unit to do.
2 . Can switch out various GPS programs until you find one that you like.
Cons.
1. Bluetooth sound quality. I'd give it a 4 out of 10. Maybe a 5 at best.
2. Screen becomes unusable in direct sunlight. A huge con for any screen of any type in any automobile.
Old 05-04-2012, 11:08 AM   #11
andrey8
Drives: yaris
Pros:
Cons.
hi,could you PM the link you bought again,i just read from first page,but cann't open the link.also is it a univeral one for yaris or toyota?i like this menu,but the link cann't open.
my friend bought from another shop,at present it works also nice,i am just considering buy which one?thanks.below is my friend bought.
http://www.autoadas.com/toyota-yaris...pod-p-296.html
andrey8 is offline   Reply With Quote
Old 06-20-2012, 04:07 AM   #12
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Cheapest I found is $332.
http://www.autodvdgps.com/car-dvd-gp...ies-p-565.html
Is the same one right?
caineroad is offline   Reply With Quote
Old 06-20-2012, 01:03 PM   #13
nicodu78
A picture of mine :
Old 06-20-2012, 01:23 PM   #14
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Pros:
Cons.
Agree on all of the above..
Mine unit is going to be exactly 2yrs. in July, still going strong without any issues and still pretty happy for what you get for the price.
Really enjoy the DVD/Divx for movies while I wait around for people or during trips where passengers love it. GPS for those adhoc trips or hard to find places, sometimes I even just leave the map running to see every shortcuts available to me when main roads are congested and still have the radio/mp3 running in the PIP window, etc.
It’s not perfect but it does everything I need it to do.
Yes it is.
Old 06-21-2012, 12:59 AM   #15
caineroad
caineroad's Avatar
I am seeing many people mounting the GPS antenna where it can be seen, where else can we mount it so it is not so obvious? Can it be mounted under the roof headliner?
Old 07-03-2012, 06:52 PM   #16
caineroad
caineroad's Avatar
So i bought the HU, it looks awesome, everything works no complaints.
It does take some time to get used to the interface, it is not the most userfriendly but is fine. It charges my iphone and play music via the ipod cable. I mounted the GPS atenna inside the driver side pillar, no problems picking up signal.
Mmusic are good(better than stock), video are good, bluetooth is fine, it wont pull up phonebook from iphone. it supports USB so i can put songs and videos in it.
my backlight is green red orange
great product. Worth the money IMO.
Old 07-03-2012, 07:23 PM   #17
caineroad
caineroad's Avatar
Just found out when I play movies via USB, often the videos (720p) lags and causes the video to freeze i had to unplug the usb to reset the system, not sure if it is USB related or hardware issues. Sometimes when I fast forward regular movies, after i click play they will freeze on me too. i'll try to buy a faster USB see if that helps
Old 07-18-2012, 02:44 PM   #18
caineroad
caineroad's Avatar
i bought a class 10 microsd 8GB for video streaming, no problems at all!
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 11:30 PM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Used Kenwood 7037 Double Din Touch Screen +10 Disc Changer ! micquek Items for Sale by private party 0 12-31-2009 09:31 AM
Getting ready to get a DOUBLE DIN touch screen player, NEED INPUT! Syroyizhka General Yaris / Vitz Discussion 12 04-08-2009 11:26 PM
Decent eBay deal on harness and double DIN kit Sodium Duck In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2009 01:04 AM
