Old 04-25-2011, 11:16 PM   #1
scamihorn83
Drives: 2009 Toyota Yaris Sedan
Bought mine approx 8 hrs ago and already had it up to 103 on the ride home.
scamihorn83 is offline   Reply With Quote
Old 04-26-2011, 01:46 PM   #2
EPyarisdriver
...or Vegas for short
EPyarisdriver's Avatar
Drives: 2010 Toyota Yaris 3door LB
I was racing an accord on the freeway when i hit 128.
All stock so far.
and NO BS!
EPyarisdriver is offline   Reply With Quote
Old 07-26-2012, 06:58 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
All stock so far.
and NO BS!
The only way you were gonna do that is with either 18s and 225/35 tires with a stiff wind or going down a very steep LONG hill. That is the ONLY way that you will get that much faster than the 118 fuel cutoff and you would have been up to speed for a few miles at least with 0 cross or headwinds...in other words I call
Old 04-29-2011, 05:22 AM   #4
YarisLover09
Drives: 2009 Yaris Hatchback
80-85 while commuting
YarisLover09 is offline   Reply With Quote
Old 05-26-2011, 06:31 AM   #5
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
200 kph ! All stock sedan!
check my video!
http://www.youtube.com/watch?v=8wh5Cnn6mtM
BLOODY_STONE is offline   Reply With Quote
Old 05-29-2011, 01:33 PM   #6
aruester
Drives: 2009 Yaris 3D
Hmm... my gov doesn't let me go more than 113-114 mph. I've been there often and regularly run the cruise on the autobahn @ 100mph+. You want to talk about bad gas milage with a Yaris! It drops below 20mpg! lol.
I think I'm going to have to reprogram the computer soon though. Gotta make those Audi's and whatnot think twice ;-)
All Stock BTW save Eibach springs.
aruester is offline   Reply With Quote
Old 07-01-2011, 09:33 PM   #7
TRDblueyaris
Drives: 08 liftback 5 speed
80, any more and it's really unstable, haha!
TRDblueyaris is offline   Reply With Quote
Old 07-01-2011, 11:10 PM   #8
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Lower it, get some wider tires and add a rear sway bar. That problem will go right away. I cruise between 90 and 100 during as much of my 400 mile weekly commute as I can...LA/OC traffic permitting.
-Type 07 FFL-
My odometer 03/11
Old 07-01-2011, 11:20 PM   #9
str8Yaris
str8Yaris's Avatar
Drives: Yaris Sedan Supercharged
I hit 116-117 MPH Max..... LOL not for long
Blitz S/C @ 9psi
Vegas meet 2011
http://youtu.be/1IEebCmtvP0
str8Yaris is offline   Reply With Quote
Old 07-04-2011, 06:14 PM   #10
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Got it up to 80mph this weekend.. not much point in pushing it any faster
Old 07-26-2012, 05:23 PM   #11
dfhnpdx
Drives: 2009 yaris
Got er up to 100mph...seemed smooth....
dfhnpdx is offline   Reply With Quote
Old 07-01-2011, 10:55 PM   #12
ChitownY@Ris
ChitownY@Ris's Avatar
Drives: '07 Yaris Sedan
About 110-113 a few years back. Was driving from Chicago to Iowa on a clear sunny day. Road was straight and flat, and not another vehicle in front or behind me, and I remember just flooring it. Next thing I knew I hit the governed limit and cross winds were were making me feel just a little uneasy so I slowed it back down after several minutes at top speed.
ChitownY@Ris is offline   Reply With Quote
Old 07-06-2011, 01:48 AM   #13
Tylermayer
Tylermayer's Avatar
Drives: 2007 Toyota Yaris
100 :)
Tylermayer is offline   Reply With Quote
Old 07-10-2011, 06:40 PM   #14
bazb
Drives: Toyota Yaris 1.0 2006
I've had my stock Yaris 1.0 above 124 mph, the speedometer wouldn't go higher than 199km/h but my navigation did, 205 km/h. To be honest, it was downhill...
bazb is offline   Reply With Quote
Old 07-11-2011, 05:58 AM   #15
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
Does the Yaris have a governor or limiter I've gone 117 mph one day and the next over 120 mph with a serious back wind on the same stretch of road? For a car with around 100 hp; 115 mph is about right. We might have rpm limiter but that's more for engine life right? A speed governor is for an M3 @155mph and When you hit 155 thats it even down a hill. BUT I don't know I'm a simple lawyer from Kentucky this Post is more of a big what if as you will.
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 07-14-2011, 04:43 AM   #16
07YarisTypeS
Drives: 07 white Type S
116 mph, intake, header, dropped on trd's, and a tanabe strut bar.. hit it with ease too..
07YarisTypeS is offline   Reply With Quote
Old 07-26-2012, 07:01 PM   #17
fnkngrv
fnkngrv's Avatar
I have reached 129.734mph and have the timeslip (133 by GPS) to prove it. I have hit 146 on a dyno (have dyno chart) when the rev limiter kicked in which is actually not a rev limiter, but a secondary fuel cut off as the ECM leans you out to over 17 for your AFR and it retards the hell out of your timing too...knocking off the rev limiter is pretty unwise. The 145/146 IS the top speed that the car will go with a stock motor "safely". At this point you would need to build up the bottom end making sure to upgrade the rods because in order to bump up the rev limiter for uses at extended periods of time over the 6250 you would want to upgrade the head too. The limits of the stock transmission are still a mystery since you indeed hit the rev limiter before you "run out of gear". Unless something changes I won't be able to verify the limits of the stock tranny unless I was to find a way to get the car out to Bonneville since by the time I do the LSRs next summer I should (fingers crossed) have both motor and trans built.
Old 07-26-2012, 08:57 PM   #18
victorddr
Drives: 07 Yaris CE
Hit 195km/h when it was brand new back in 2007, now the top speed is 175km/h.
victorddr is offline   Reply With Quote
Stock Yaris as fast as stock 1982 Z28 Camaro/Trans Am!! 427chev General Yaris / Vitz Discussion 72 06-13-2012 02:20 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
Im trying to figure out a easy way to make my yaris fast... help! nsracing Performance Modifications 61 04-11-2007 08:33 PM
