![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
You'd think that there must be other YARIS , 1st generation XBs' , or XAs' with the same leak . Why just ours . I really believe that starting the the use of synthetic oil at 1,200 miles for both is the cause . I've looked at 2 XBs ( 1st gen. ) and 3 YARIS with higher mileage for same leak and were bone dry . The '08 with 23,000+ miles leaks more than the 2010 with 8,000+ miles . Figure due to the longer run of synthetic for the '08 ( up to 21,000+ miles ) than the '10 ( syn until 7,000+ miles ) . Now using conventional motor oil for over 1,000 miles for the 2 . Talk about sh*t for luck .
Could it be that the factory fill of oil treats ( cures ) the gaskets and seals and dumping it too soon ( before 5,000 mis. as stated in O.M. ) could cause leaks ? Now that TOYOTA is going to 5w-20 ( dino and syn ) and 10,0000 mile O.C.s possibly more leaks will spring up . Maybe more cases of sludge or the gunk found in the pan above . Looks like plenty of deposits in the cynlinders and pistons as well . Longer intervals and lighter oil don't sound to promising from the pics provided by 2007tRD .
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Toyo is going 0W-20 synthetic for the 2010's.
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
My 2010 states in the manuel and on the oil fill cap....5w-30.Factory oil is not going to "cure" gaskets,the gasket,is as it is! no curing needed.If this was a conversation YEARS ago and a person used the old permatex form a gasket,then, yes there would be a curing time table.Synthetic oil has much better "flow" characteristics than dino...it will "find" weak points in old gaskets and funky set points in new gaskets. |
maybe we're being PUNK'd
. Be better if we were .
And, knowing some walmart employees, I bet that oil hasn't been changed in years.
They probably just slapped an oil change interval sticker on the car without ever changing the oil. Sad but it happens. So let's not bash the owner too much;) |
#7 | |
It's a crude and primitive device but, it can tell you a few important things about your oil. A good owner is aware of this
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
in the pics
the goo in the pan is water contamination the carbon on the cylinders looks pretty normal I do not see much sludge. sludge looks like shredded burnt toast covered in oil, ...black carbony grit....not much of that anywhere in the pics |
a slow internal head gasket leak ?
Thanks . Didn't notice the extra deposits in that cylinder nearest to where our leaks are ( circled in red ) . Makes you think that this may be an issue for these cars . The '08 has had a bit of rough idle when stopped ( idling ) since we bought it . Leaking head gasket from the factory ?
#12 | |
2007tRD , could you possibly ask the owner what brand of oil , the weight , conventional oil or synthetic or both , and the intervals they used ? Thanks again .
#14 |
A good synthetic can clean some of that engine out.
not the pan though... |
#15 |
Havent read all the posts but that blob is because of water and oil mixture. IE head gasket failure. Any valve cover you remove no matter how frequent the oil change will have that glob if there is moisture contamination. Old mechanic trick when checking for head gasket failure is to remove the oil cap if you see a bunch of yellow glob on the inside of the cap chances are its head gasket. Another tell tail sign is yellowish muddy oil on the dipstick.
#16 |
the glob looks to be in the oil pan . Wonder if the oil they mostly used was WAL-F*RT's SUPERTECH . Think that's from WARREN PETROLEUM PRODUCTS .
#17 |
2007tRD , what's the reason for the teardown ? Rough idle ? Coolant loss ? Smoke from tailpipe ? Fluid from tailpipe ? Oil in coolant ? Coolant in oil ? Oil leaking from head gasket ( if so , where outside of the block ? ) or a combination of things listed . Thanks Again
#18 |
I just switched over to synthetic today (royal purple 5w30!).
Hopefully it will prevent these kinds of issues. |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
